Showing results for tags 'lego trebuchet'.
This topic has a lot of photos inside, to make it easier for everyone to see the updated version of my MOD, I have been editing this first post to show the latest version, 24 July 2021. From two sets of 31120 Medieval Castle; I built a Grand Castle, a trebuchet, and a four-legged dragon, no extra pieces required. It has been featured on Blocks Magazine Issue 83. Your feedback is welcome or share your MOD ideas please! A photo review is on Brickset, its format is easier to read compare to the forum posts. https://brickset.com/reviews/60120 YouTube photo video: Version 1 Design Notes please read towards the bottom of this post. Version 2 Design Notes Version 3 Design Notes Version 4 Design Notes Version 5 Design Notes Four-legged Dragon Design Notes LEGO 31120 Medieval Castle MOD, Version 5 by R Y, on Flickr LEGO 31120 Medieval Castle MOD, Version 5 by R Y, on Flickr LEGO 31120 Medieval Castle MOD, Version 5 by R Y, on Flickr LEGO 31120 Medieval Castle MOD, Version 5 by R Y, on Flickr LEGO 31120 Medieval Castle MOD, Version 5 by R Y, on Flickr LEGO 31120 Medieval Castle MOD, Version 5 by R Y, on Flickr LEGO 31120 Medieval Castle MOD, Version 5 by R Y, on Flickr LEGO 31120 Medieval Castle MOD, Version 5 by R Y, on Flickr LEGO 31120 Medieval Castle MOD, Version 5 by R Y, on Flickr LEGO 31120 Medieval Castle MOD, Version 5 by R Y, on Flickr Here is a summary of the modifications up to version 5. I started building both sets simultaneously bag by bag over a few nights. I find this is the most efficient way to build two of the same sets, learning the building techniques and sorting out the pieces by building them into the castle. I wanted to build up four towers on the castle, incorporated the pavilion roof of model B into the great tower next to the yellow wooden keep. The keep is built up using two flipped window and chimney yellow wattle and daub buildings, shortened to fit inside the rampart. I added a second 1x8 reddish brown brick as a beam to the floor, rearranged them both so they are spaced equally from edges, moved the grey bricks to fit accordingly. With the watermill and dark azure plates only on 2 sides of the castle, my castle is sitting on the bend of a river, so I placed yellow wattle and daub structures with windows facing that way to have a waterfront view. I studied the towers on the gatehouse, which is composed of two sections each on the ramparts, I can use three sections for the great tower and one section to raise the corner tower by one level. The great tower became five storeys tall, I added two dragon gargoyles at the lower floor above the watermill to balance out the heavier top design. The crenels on all the battlements are raised by one brick high, the slope tiles on the merlons are flipped so they face outwards. Merlons on battlements should be as tall as soldiers to shield them from projectiles. I put the weathervane on top of the great tower, plenty of flags already on the other three towers. The location of the old staircase is awkward with my modification, I decided to move it to the corner tower section. This allowed me to complete the flooring on the keep, add in a tapestry table, plus the well on the ground floor. I had the stone battlements on the great tower for the first three versions of my MOD, then I finally realised it does not need to be there, as the alchemy study is enclosed and has no use for the machicolations. It was an easy fix; I swapped the stone battlements with the yellow wattle and daub boards. I added a brick high of yellow and brown bargeboard to the watch tower roof to add a splash of colour to the otherwise entirely grey corner. Moving to the front of the gatehouse, I tiled up the entire footbridge and build up the outside moat bank with olive green round half plates and some other pieces for support. A protruding portcullis was made by a clipped-on horizontal barred door. I find the coat of arms above the gate fiddly; it moves around with slightest amount of motion. I swapped the two round bricks with two palisade bricks, topped them up with a pyramid tile, they lock in the crest securely and no more movements. The treasure chests have been moved to the gatehouse. I used two 22385 2x3 light bluish grey pentagonal tiles to replace the 2x2 dark bluish grey tiles above the gate. Those two dark bluish grey tiles went to the pavilion roof of the great tower, I didn’t like how the pentagonal tiles stuck out of the roof. The apple tree moved into the wall by one stud, has five 6x5 leaves, two green apples with four arches acting as branches, using a twig to connect two 6x5 leaves that are offset on top of each other. I changed all pink studs to yellow studs on the ground, so apple tree has pink flowers, and the ground has yellow daisies. I raised the ramparts to the same height on the second level of the four towers. I started on the section next to the five-storey great tower. I built a second set of clip and bar to secure the wall connections. I tried different arrangements of 1x3 and 1x4 arches, but only the 1x3 arches allow for the even spaced machicolations on battlements with no overhang onto the next section, I wanted to keep the castle in three sections for ease of move and storage. All hinge connections are removed from the model, so the plates are secure on both floors. The river is now connected on the two sections, as side walls can’t open up after I removed the hinges. I took out two round corners and one 2x4 plate, replaced them with one 4x12 plate, added some waves, an olive green slope and medium azure 2x2 round. The river is also lengthened by two bricks with a new green mossy rock tower base and buttresses. A phoenix shrine is built using round corner bricks. I used the 4x8 dark tan plates with 6x6 plates, so the footprint of the space is the same as a tower. Before I started, I changed the base of the corner tower section to the 8x16 tan plate, so there is enough depth for the columns. For the connection of the round bay window corners to the square battements, I tried a few variations, I decided on the sloped version using 3665 2x1 inverted slopes; I used one 3676 2x2 inverted double convex slope for the connection of dark tan plates. There are ten furnished spaces inside the keep tower and the corner tower sections: most of the designs are taken from the original LEGO model and modified. - Double beer barrel dispenser - Kitchen with bench and fire stove - Fruit stall - Well with a bucket - Blacksmith workshop - Phoenix shrine - Dining room with a tapestry table - Throne room - Lookout room with a monocular - Alchemy study I still had enough pieces to make the trebuchet, though had to use some different pieces. Lastly, I modified the LEGO dragon to a four-legged dragon, built up the torso so the ball joints for the wings and front legs are three plates apart, new shorter and slimmer front leg, a longer tail and wingspan with a new connection for the wrist claw. ORIGINAL POST ON 9TH JUNE Following last year’s 31109 Pirate Ship, I was very excited to find out LEGO is bringing back the Castle theme via the Creator 3-in-1 set 31120, it’s not as expensive as the Creator Expert sets and it’s within my budget to purchase two sets to do my MOD. I purchased two sets on 1st June from Hobbyco, the best hobby store in Sydney, I started building both sets simultaneously bag by bag over the next week. I find this is the most efficient way to build two of the same sets, learning the building techniques and sorting out the pieces by building them into the castle. This time I decided to use only the pieces from the two sets, no extras from my spare LEGO for this MOD. My original intention is to combine Model B, The Watch Tower into the enclosed castle, as there is no tower on the yellow wattle and daub manor house corner, I wanted to add it there. I reversed the location of the chimney and windows as the blacksmith with the watermill remained on the corner. I connected the same building to create a two-storey house/keep and removed the doors and window covers, shortened the roof, to allow it to fit inside the length of the original rampart. With the watermill and dark azure plates only on 2 sides of the castle, I think the castle is sitting on the side of a river, so I placed yellow wattle and daub structures with windows facing that way to have a waterfront view. With the physical model in front of me, I realised that I cannot simply add the original LEGO Model B on top as its base section is too big. I studied the towers on the gatehouse, which is composed of two sections each on the ramparts, I can use three sections for the great tower and one section to raise the watch tower by one level. I progressed pretty quickly with the pre-built sections, making sure the arrow loops and red/white banners are arranged in the same manner as the gatehouse. Please be aware that the two battlement arrangements are opposite of each other, only two sides have machicolations and I used the wrong battlement on the great tower, I only realised that after looking at photos that the machicolations are facing the keep’s roof, not the outside wall, I had to fix that and retook the photos again. I removed the prison cell windows so I can have the black window pieces on the keep and give the gold pieces to the great tower windows. I moved the archery target range to the pop out cell wall. The crenels on the towers are raised by one brick high, both the crenels and merlons on the ramparts are raised by one bricks high each, the slope tiles on the merlons are flipped so they face outwards. Merlons on battlements should be as tall as soldiers to shield them from projectiles. I put the weathervane on top of the great tower, plenty of flags already on the other three towers. Moving to the front of the gatehouse, I find the coat of arms above the gate fiddly, it moves around with slightest amount of motion. I swapped the two round bricks with two palisade bricks, topped them up with a pyramid tile, they lock in the crest securely and no more movements. The well is now secured to the back of the gatehouse by swapping out the brick yellow 2x2 plate with a 2x8 plate, located next to the food stall. I was still able to build the trebuchet, just have to use some different coloured pieces. I didn’t build any animals from the set initially as I was rushing to finish the castle, I can build two dragons from the pieces but I didn’t like how it has one claw per wing and no front legs. I built the fronts legs like the hind legs, expanded the wingspan and lengthen the tail by one section. I also added some more 1x1 roof tiles as fins on the back of the dragon. The Disney Castle 71040 dwarfs the Medieval Castle 31120 side by side, the Disney Castle is still my favourite LEGO set! They are what I have done for the MOD up to today, hope to see other’s MODs and feedbacks. Please share with us on comments. LEGO 31120 Medieval Castle MOD of Two Sets, No extra pieces required by R Y, on Flickr LEGO 31120 Medieval Castle MOD of Two Sets, No extra pieces required by R Y, on Flickr LEGO 31120 Medieval Castle MOD of Two Sets, No extra pieces required by R Y, on Flickr LEGO 31120 Medieval Castle MOD of Two Sets, No extra pieces required by R Y, on Flickr LEGO 31120 Medieval Castle MOD of Two Sets, No extra pieces required by R Y, on Flickr LEGO 31120 Medieval Castle MOD of Two Sets, No extra pieces required by R Y, on Flickr LEGO 31120 Medieval Castle MOD of Two Sets, No extra pieces required by R Y, on Flickr LEGO 31120 Medieval Castle MOD of Two Sets, No extra pieces required by R Y, on Flickr LEGO 31120 Medieval Castle MOD of Two Sets, No extra pieces required by R Y, on Flickr LEGO 31120 Medieval Castle MOD of Two Sets, No extra pieces required by R Y, on Flickr LEGO 31120 Medieval Castle MOD of Two Sets, No extra pieces required by R Y, on Flickr LEGO 31120 Medieval Castle MOD of Two Sets, No extra pieces required by R Y, on Flickr LEGO 31120 Medieval Castle MOD of Two Sets, No extra pieces required by R Y, on Flickr LEGO 31120 Medieval Castle MOD of Two Sets, No extra pieces required by R Y, on Flickr
- 54 replies
- lego dragon
- lego trebuchet
- (and 4 more)
