Showing results for tags 'mercedes-benz unimog'.
Hello all! It's been a while, I posted here anything, but now I'll try to upload my works more recently. I start with this Unimog 401, which is the oldest Unimog with Merecdes-Benz star. This one has also an "Ochsenkopf" (ox head) in the hood, which was later removed in the next generations. The building time took about 2 weeks at all, and this is my first model which got the special dark green color, to get close to the original's painting. I ordered several types of these bricks, more models will come in this color. I chosed for building the 1:7 scale, with the 108 mm RC4WD rock crusher XT wheels. They aren't Lego, but as far as I can see nowadays it's normal in tyres, and the look is better imho with these. Goals: Llooking and working authentically, as close as possible to the real thing, beside of off-road capabilities and remote control. Main functions: Motorized: driving, steering, gear change Automatic: steering wheel, piston engine, PTO in front and rear Manual functions: openable hood, doors, rear side Working: One Lego PF L motor drives, one M steers. The 2 speed linear gearbox is operated by a M motor. Steering wheel and suspension also works. The original has rigid axles with torque tubes, so I chosed also them. Four of 8466's springs were taken apart, so I got 4 coil springs to get the authentical look in machinery of axles. I also attached differential imitating disks. The rear view mirrors work a little. One L motor drives the whole thing, it's sliding in two axles, because of the 2 speed (1:3 and 1:1 ratios) linear gearbox. This way there is no need for driveshaft length adjuster between the driving motor, and the incoming axle of the gearbox, but the rear PTO has one from 6 holed pulleys. There is a PTO also in the front with a pulley, like in the original. The working L4 piston engine has mini pistons from 2L axles and half bushes. Details: I wanted to build as details as possible both inside and outside, like: detailed interior, steering wheel, stickers (for instruments too), gear change levers in the cab, handbrake lever, mudguards seen from inside, fuel tank, number plates, lights, seats, rear wood cover, detailed engine room, tanks for brake, exhaust, etc. Pictures I made it in the winter season, that's why you can see snow as background: https://www.flickr.c...157667176594155 http://www.brickshel...ry.cgi?f=563725 With dark green wheel covers: There are anti-roll bars to prevent rolling, the vertical 6L links connect them with the axles: The diff imitators: Of course I made a video, too: Hope you like it.
- 26 replies
- Unimog
- Unimog 401
- (and 7 more)
