Showing results for tags 'not purist'.
Hi! This is a small island made for the Medieval table of our LUG exhibition, Oeiras BRInCKa 2016, last week. The Mists of Avalegon by Jorge Pereira, on Flickr This was the second time we had real water in our table and since one of us brought a smoking vulcano (real smoke from a RC "portable" fog machine intended for parties) I've been researching ways of doing a fog / mist effect at small scale. Have been working with model train smoke generators and also custom made smoke generators but for this particular MOC I decided to use 3 USB bottle cap air humidifiers. Each unit has a wick that brings water from the bottle to a small metal part at the top that vibrates fast enough to disperse the water in small droplets that float in the air - one can see two of those metal parts at the left size of the island, near the cauldron and the dolmen, the third one is hidden near the pine tree. Each wick was cut to the height of the unit and I also opened a small hole near the bottom so water could reach the wick. Luckily the USB plug is near the top of the cap so no need to protect it from water. At the beginning of the exhibition I used just 1 USB power adapter and 1 USB hub to power all units but later opted to use 3 power adapters to give enough power to each one (I suspect each can draw near 700 mA). It worked very well all 4 days, except that after 8 to 10 hours I also found that I had to remove and reconnect power, not sure if there's some kind of timer or temperature protection in the units. Merlin by Jorge Pereira, on Flickr The Merlin minifig is using a custom made cloak, printed with an inkjet printer on canvas ("Reeves acrylic pad", A5-size paper for painting, 190 grams per square meter) and a Brick Warriors lyre. I forgot to put the elf minifig original cloak but after some hours of exhibition I decided it was best to leave that way, there was already to much water over the MOC and it would probably ruin it.
