Showing results for tags 'passenger car'.
I know I've had a bit of a hiatus from building, but I can't believe it's four years since I posted anything on Eurobricks! I'm trying to slowly ramp up my building again. Here's my latest model: a Victorian Railways AE passenger car. There are more photos in my Flickr album. These passenger cars were found mainly on longer distance intrastate passes. AE 51 was air conditioned around 1962, was recoded to BE 51, and then in 1983 was recoded back to AE. This model was built for BMR's OcTRAINber competition. It's built in O-scale (1:45), which ends up being 8 studs wide and 63 studs long (coupler to coupler). The model contains 120 yellow flags. I have a love-hate relationship with flags - I love the thin line they produce and the building challenges they introduce (getting them into the doors was particularly challenging), but I hate the extra weight due to the extra parts needed to incorporate them in a build. Same goes for the modified plate with handles (this model uses 60 of those in rare dark blue). Purity Declaration: This is a pure LEGO build apart from the use of bearings for the wheels, vinyl for the yellow lettering and printed labels for the white lettering. The integrity of the model does not rely on any of these non-LEGO elements.
- 4 replies
- victorian railways
- train
(and 4 more)
Tagged with:
Greetings, Train Tech! About a year ago, I posted my Umbauwagen 4yg. Here is the 3-axle variant, the 3yg: The name Umbauwagen means "rebuilt coach" -- these coaches were built after World War 2 by modernizing prewar compartment coaches. More accurately, this is an AB3yg (first/second class) + B3yg (second class) pair -- these cars were nearly always found in close-coupled pairs. A few survive as single units in work trains, painted yellow. The body of the model is essentially constructed the same way as my 4yg model: studs-up construction for the main body (leveraging the train window and the 2x8x2 curved slope), SNOT construction for the doors, the details around the buffer, steps, and corridor bellows. Of course I designed new side frames, and there are a few minor details that are different such as the lights above the end doors of the pair. These cars were painted green in DB service, but as the train window does not come in green I elected to build the 3yg in a different color scheme. I believe that this livery corresponds to 3yg cars used as trailers for the ET 85 electric units -- someone with more knowledge of German railways may be able to shed more light on this. At the time I built the 4yg I also built some test models to research how feasible it would be to build the three-axle variant. However, I ran into difficulties designing the chassis and moved on building the 4-axle variant instead (which had none of these challenges). Earlier this year I circled back and spent some time looking into the problem. The first attempt was to articulate the chassis as 4+2, pivoting the body to reduce the overhang -- a technique I previously used on the tender for my model of the Gr670. However, the Umbauwagen 3yg not only has a long 3-axle wheelbase, but also has a long distance between the outer axles and the buffers: Articulating the chassis as 4+2 would allow the car to negotiate turns, however it would also derail any vehicle attached to it as the buffers swung out widely. Further iteration yielded the general outline of my eventual solution: The center and end axles are connected together with a 6-bar linkage, rather than a rigid frame, allowing the chassis to change shape when traveling through curves. It's important to note that the center axle is actually what actuates the system. As the car enters a curve, the center axle is pushed sideways to follow the curve, which in turn angles the outer axles to follow the curve as well. The track cannot apply rotational forces through a single pair of wheels on one axle, and so a similar design to this one without the center axle would not work. You can see the mechanism here: The outer axles are mounted on 2x2 round bricks riding in a 2-stud-wide channel, allowing them to turn and slide slightly towards the center of the car in turns. I experimented a bit to find the best places for the pivots and a construction that would be light and reliable. In the final model I removed the blue tiles shown in the screenshot, to avoid additional friction and binding in the mechanism. Thanks for following along! As usual, I've uploaded some additional images to a Brickshelf gallery, including some notes on and prototypes of the linkage mechanism. Thanks for reading, and let me know if you have any questions!
- 13 replies
- bricklink warrior
- interiors are overrated
- (and 7 more)
I wan't going to post this in it's own thread, but then i thought it would be bad to hijack another person's thread. If a MOD needs to move it, delete it, or combine it with another thread, feel free! This club car model was originally created by a Facebook user to the LEGO Train Fan Club group, (who seems to have deleted their post or been banned) as a MOD to set 60051, High Speed Passenger Train with simple throwback design to the Metroliner Club Car of 9V set 4547. (which was re-released as set 10002) I copied the model from some photos, and redesigned the roof to be more my style / feature more common parts. I also added the dark bluish gray stripe to the upper level via slopes. These connect the upper level visually to the rest of the train. The top roof section is removable to get at the upper floor, but the lower section is not accessible at all. (I did try unsuccessfully to make it work) LDD file: http://www.mocpages.com/user_images/80135/1449342682m.lxf Feel free to post your own models to this thread. They could be color-swapped models, or another club car, or even a lounge car with rounded windows on the rear for the end of the train!
Hello again, after so many requests to show some wagons for my GHH G7.1 - finally, here they are! Both wagons are in 1:33 scale. They feature detachable roofs and detailed interior. Although LEGO's large drive wheels are identical in diameter, I used BBB L drivers once again, as the counterweight on the LEGO wheels made them inappropriate for the use on cars. The first one is a third-class passenger car for the GHH pitmen: The interior: A rendering of the interior, showing the... eh... "silent little place", as we say in German: Furthermore, I built an old-fashioned little passenger car with brakeman's cab. I modeled this one after a photo I happened to see on ebay, showing a GHH G7.1 pulling such a wagon, and I have to say that I am quite proud of the result. Sadly, I didn't manage to get the mentioned photo, so I can't show it here. Another rendering: As usual, you can find larger versions of the images here. Last but not least, here is a video link showing the whole train running. Hope you liked it, best regards Sven
Greetings, Train Tech! I build a lot of locomotives, but I hadn't really built any models of rolling stock with the same effort as I put into my locomotives. Until now. This is a model of a German Umbauwagen, or "rebuilt coach". They were constructed in the post-WW2 period by modernizing prewar compartment coaches, as the Deutsche Bundesbahn was strapped for cash at the time. They came in two main "flavors": the three-axle 3yg, and the four-axle 4yg I've modeled here. I initially learned about Umbauwagen while doing research for this passenger car (which itself was found while doing research for the glaskasten...). Inspecting an engineering diagram convinced me that it would be possible to build the 4-axle variant at my usual scale of 15 inches / stud (~1/48) and have it go around standard Lego curves. The main compromise I made was to reduce the length of the body from 51 to 50 studs. An even length made it possible to use the 2x8 double curved slope for the roof and the 1x4x3 train window. Since the window only comes in a limited palette of colors I wound up building in blue. My understanding is that Umbauwagen ran most of their lives in green livery, but I found photos of models in a variety of colors. I'd appreciate it if someone more familiar with these cars could shed some light on this subject. Of course, it's not much of a train with only one car... ... so I built two. I'm pleased with how closely the cars couple to each other while still being able to make it around turns. While doing background research for this model I came across Duq's rendition. Duq's model features an excellent rendition of the Minden-Deutz MD 36 bogie. Rather than just steal those, I decided to model the my cars with the Schwanenhals ("swan neck") bogies. These bogies have a somewhat American appearance with their arched outside frame. The buffers and stairs are attached to the trucks and rotate with them in curves. The trucks use Big Ben Bricks wheels. This may mark the first time I've completed cars without a locomotive to go with them. Full Brickshelf gallery here (pending moderation). Thanks for reading!
- 11 replies
- umbauwagen
- passenger car
- (and 5 more)
In the past I haven't posted models I've made in LDD before I build them in brick, but I realized there's no good reason not to. Therefore, here's a model of a two-axle German passenger car: This model is "free-built" (compare "freehand") without a fixed diagram as a reference, but is based on this coach: This vaguely resembles a Donnerbüchse, but clearly isn't (it's much shorter). If anyone here knows more about the prototype, I'd be glad to hear it. The model has a removable roof and features a simple interior: Again, this wasn't intended to be an accurate model of the prototype, just a simple build that captures the spirit of it.
Hello, I would like to present my latest train MOC: a German steam engine. Steam engines appeal different from country to country. In Germany most steam engines had a red wheel undercarriage, steam engines in some other European countries too. For those who like steam engines completely black: all parts for this engine are already available. For those who like a red undercarriage: please support this set on LEGO IDEAS (https://ideas.lego.com/projects/133465). The steam engine bases on the steam engine https://en.wikipedia...i/Prussian_G_12. This steam engine was a goods train locomotive, and as goods train locomotives have small wheels for high traction force I used small LEGO train wheels. I did not like the plain, high gloss surface of the tender, so I decided to take bricks with studs on sides. These studs symbolize oversized rivets. I watched LEGO sets like freight train 60052. This set does not contain only a freight train, it also contains a truck and a fork lift. So you can transport something with the truck to the station, load it on the freight car and take it to the next station. At 1925 there were only a few trucks and no fork lifts, so I decided to add a horse carriage. Now you can play as you can play with freight train 60052: you can transport something to the station, load it into the freight car and transport it to the next station. Ludger
Hello all I want to show you some techniques I used for my MOC of the ÖBB Nightjet. Since this train consists of several different cars from different former owners, there’s quite some variety of cars. I want to show you the most important building techniques used for cars based on the UIC-X car and the Eurofima-car. There are two links to the respective German Wikipedia page. UIC-X Eurofima These two types of cars can still be seen on the major European railroads on InterCity lines and were also used on the legendary TEE Rheingold. So, with changing the colours and some details, a lot of cars can be built using the same techniques Now the first part I show you are the windows, since the original ones from LEGO only come in limited colours and are quite expensive: http://UIC-X by StefanEris, auf Flickr http://Übersetzfenster 1 by StefanEris, auf Flickr http://Übersetzfenster 2 by StefanEris, auf Flickr http://Bautechnik Fenster by StefanEris, auf Flickr The windows are built using SNOT-techniques and using plats with handles and plates with clips, one can achieve different spaces between the windows, as seen on the picture with the one stud wide window. This technique can also be applied to 6-wide cars. Also note the doors, here a minifig hand is used to model the door handle. (I’ve seen this idea on other MOCs, thanks for the inspiration) The roof is made with the slope curved piece and a lot of hinge plates. The next car is an SBB Eurocity car, which is based on the Eurofima-car. The story behind this car is, that several railroads wanted to order the same car with the advantage of paying less per car. Since the more were built, the less one single one would cost. In the end not everything worked like the railroads wanted, but a lot of cars are still based on the Eurofima-car. Also the Swiss Eurocity car you see below. The most challenging part here was the roof with it’s longitudinal beads (?) (please correct me if someone knows the right translation of “Längssicken” here, they are used to reinforce the roof). To get this shape right, I used tiles and hinges. On the other hand, the windows here are quite simple. There’s only a three studs height stripe (snotted) with trans black and black brick. http://EC-Wagen by StefanEris, auf Flickr http://Dach by StefanEris, auf Flickr http://Dach 2 by StefanEris, auf Flickr I hope I could inspire someone or help you to build some trains, even if train windows and doors aren’t widely available in the wanted colours. Stefan Edit: Added another picture of the roof technique.
- 10 replies
- snot
- passenger car
(and 3 more)
Tagged with:
After a recent trip to the local pick-a-brick wall, I found myself with a ton of 1x2x2/3 light bley curved slopes and set to work building an old-fashioned passenger wagon to accompany my recently renovated locomotive. I was quite pleased with the result, so I decided to build a second one and document the process for others. Please note that some parts used reflect my limited inventory and can be substituted. Here's a link to the Flickr album for reference. I'm undecided about red or dark red (or possibly brown) for the stripe - which one do you prefer? Thanks for looking and I hope this helps - feel free to post your modifications, improvements, and recolors here! Soli Deo Gloria
- 17 replies
