Showing results for tags 'pop up headlights'.
  • Search By Tags
  • Search By Author
    • Frontpage News
    • Forum Information and Help
    • General LEGO Discussion
  • Themes
    • LEGO Licensed
    • LEGO Star Wars
    • LEGO Historic Themes
    • LEGO Pirates
    • LEGO Sci-Fi
    • LEGO Town
    • LEGO Train Tech
    • LEGO Action Figures
    • Special LEGO Themes
  • Special Interests
    • The Military Section
    • Brick Flicks & Comics
    • LEGO Media and Gaming
  • Eurobricks Community
    • Hello! My name is...
    • LEGO Events and User Groups
    • Buy, Sell, Trade and Finds
    • Community
    • Culture & Multimedia
Find results in...
Find results that contain...
Date Created
  • Start
    End
Last Updated
  • Start
    End
Filter by number of...
  • Start
    End
Group
AIM
MSN
Website URL
ICQ
Yahoo
Jabber
Skype
Location
Interests
Country
Special Tags 1
Special Tags 2
Special Tags 3
Special Tags 4
Special Tags 5
Special Tags 6
Country flag
Found 1 result
  1. Hello there, This is my dream car which I'll probably never be able to afford, so I built it myself This model is finished, so while I'd love to hear your opinion, it probably won't result in any changes Scale: 1:7.7 These functions are controlled in the inside of the car: -Pop up headlights -6 speed manual tansmission hooked up to a exposed fake Engine -front boot release (or whatever this is called) -steering (and HoG) Doors and trunks and glass engine cover can be opened. Double wishbone suspension all around Ackerman steering geometry Detailled interior and Engine bay Sariels Model Scaler helped me soo much to get all the proportions and angles accurate, I can only recommend using it. I tried to make the car look as clean as possible by replacing different colored pins and stuff with black ones, as far as possible. Instructions are now available on Rebrickable: https://rebrickable.com/mocs/MOC-30093/Gray_Gear/moc-90s-honda-nsx/#comments These pictures are not very good quality, because I took them with my smartphone in my dusty basement, and because I basically dont know anything about photography. Hope you enjoy them anyways. Gray Gear Here are some pictures of just the transmission, the shift mechanism will follow up soon ;) The green Gear is where the Crankshaft of the Engine is attached. This is the shift mechanism. The red parts are directly moving the Gear rings. Hopefully this helps to understand how things work. Blue = 1/2 gear Yellow = 3/4 gear Gray = 5/6 gear The Green Assembly is to stop multiple Gears to engage at the same time. It picks up the left and right movement of the shift lever and moves a sliding blocking piece in parrallel to the lever. Like this, it is impossible to engage a gear without moving the shift lever, and multiple gears cant engage at the same time and cause a block. Gray Gear
