Showing results for tags 'raise hob.'.
Some of you may be familiar with the Hob Rod, the project I was doing on and off throughout a few years. The idea was to pull a hot rod with some nice functions and details while keeping it in a ~35 stud size. Various other things and issues made it a long term project and I have no doubt this baby will be improved even further. Well, here's how it looks now. 37 studs long because of the exposed rolling chassis arms, uses Technic and System parts as you can see. Intended as a cruiser and salt flats racer - and a small tribute to the Kustom Kulture - it's based on the '30s trucks and features many details that won't let you forget about that. Raise Hob. Features: ► fake mountain V6 engine with moving pistons ► blower with chain-driven pulley (1:1.5 crankshaft-pulley ratio; 1:3.501 axle-pulley ratio) + Enderle-style bugcatcher + fake carburetor + external tachometer and oil pressure gauge ► working differential and transmission (2.334:1 crankshaft-axle ratio) ► coupled '30s style link steering connected to steering wheel and a HOG ► detailed cockpit with a steering wheel, dashboard, custom skull-shaped gear shifter and comfy channeled couch for two ► channeled and chopped body style with kustom roofline + functional bed with Moon tank ► classic radiator grille and "zoomie" exhausts, front tow bar and rear push bar and rear engine emergency shut-off lever ► locking suicide doors with internal handles and slanted edges + locking, chain-suspended bed gate ► exposed suicide front axle + wide, fake leaf spring-suspended rear axle, each wheel with fake drum brakes
