Showing results for tags 'real world model'.
In 2003 I got World City set 10027 (Train Engine Shed) and played with it for number of years, but it was sadly destroyed sometime around 2007 in an attempt to make it totally enclosed - this was because I didn't have the skills or the parts. (I also didn't know about Bricklink at the time) Then in 2014 I made it again, but this time it was far too large (96 studs long and 32 wide) and unwieldly when moving it - which lead to that MOC being scrapped in mid-2016. These two abortive attempts to modify the set were recently on my mind, so I decided another run through of the set was in order - with slightly-expanded length and enlarged entrances to allow for bigger modern locomotives (such as my steamers) to pass through, but yet small enough to not be a burden when transporting. (The total shed length is capped at 80 studs, and will not be extended.) The outside of the shed. I replaced the original expensive black sliding doors from the set with a brick built version. You may have noticed it's not a fully enclosed building: I didn't complete this MOC because at Gateway LUG shows in the past, I've gotten public comments about not being able to see inside my train sheds. So it's half a shed - but fret not! Unlike the original set, this model is modular and two copies of my MOC could click together using technic pins at both ends if I ever wanted to build another one. The five roof sections are removable, with the middle portion being the extension to the original set. Some of the tools of the shed (L to R): foreground: drill press Lathe big oilcan Octan 55-gallon oil drum (not shown here) Vise (not shown in this pic) background: lug wrench small oilcan socket wrench drill various wrenches The repair shed crew. The shed with my 7-studs wide yellow 4-8-4 loco in it in an atmospheric B&W shot for that old fashioned feel. I even wrote a story for it: 'It's mid-August 1944, and World War II is raging on multiple fronts across the globe. American trains run coast-to-coast nonstop, taking men and material all over the country to be shipped everywhere you can imagine to stop the Axis powers and win the war. The railroads are at their absolute peak during this conflict - never before have they moved so much so quickly. Still, regular maintenance must be done, even during the austerity conditions of war. Steam locomotives especially need servicing every once in a while, and here we see Brick Railway Systems 4-8-4 number 5086 just arrived for a light overhaul and tune-up. The staff of the servicing facility pause in their duties for the government photographer, get the publicity picture taken, and then get back to the grimy, greasy, dirty work of railroading. 'Keep 'Em Rolling to Victory' say the government posters - and this is exactly what this crew intends to do!' Thoughts?
- 9 replies
- 10027
- train shed
(and 7 more)
Tagged with:
This is a modified version of the flying car LOLA from LEGO set 76077 (Detroit Steel Strikes) which is based on a vehicle the Marvel's Agents of Shield TV show. The car in the show is a 1962 Corvette sports car from the C1 generation with flying mode added, probably by Howard Stark. I redid the color scheme a bit, added the correct quad taillights of a Corvette, and strengthened the design everywhere I could using parts not available in 2017. Flying mode activated! The front of LOLA in driving mode. The inside of the car was redone in white to better contrast the red bodywork. The rear of the car. Turning the left and right dark bluish gray knobs 90 degrees folds down the wheels for flight mode. Both left and right doors open and the car seats one figure. Sadly, Agent Coulson is very expensive on Bricklink, so he won't be driving LOLA anytime soon. (although I have a way of making an approximation of him when funds allow) Thoughts?
This LEGO version of the famous double-deck AEC Routemaster bus (Wikipedia link if you care to read up on this famous bus type) is a mashup of 2019 Harry Potter set 75957 - Knight Bus, albeit scaled back a bit. This model required a bit of changes to the originally purple triple-deck bus... more than you might expect, actually! Sadly, the original three-studs-long windows aren't yet available in red, (even after all these years!) so I made do with different windows. The rear of the bus. The sand green 1x4 tiles are advertising billboards. Sadly, neither the roof nor second level come off to seat figs inside. The family of Buses is complete! From left to right with a link to each bus's own topic: Knight Bus (from Harry Potter films), Routemaster (you are here), Bertie the bus (from Thomas and Friends). Thoughts?
