Showing results for tags 'remote controlled'.
Hi guys Finally, I could continue with my Scania with Palfinger project. With the ordered parts I could finish the chassis of the truck. The truck is controlled with on PU Hub and a mechanical selector gera box for 2 x 3 functions. I tried to document the funtions in the following video:
Finished MOC Do you remember my Reform Metrac H7X ? Reform also produces the Muli: As the project of my Citröen DS doesn’t really progresses, I do this project in WIP, to compensate. ^^ The functions will be close to the Metrac ones: 4WD with a 4 cylinders fake engine Steering with 3 modes Front and rear PTOs And I add: A pneumatic pump to add pneumatic tools Central joint (it’s only the front axle on the Metrac) Openable cab with a lever and a pump actionning a pneumatic cylinder. The best function! But this MOC will not be manual, because there is not so much room in the chassis. (I think it’s possible, but the playability will be extremely bad) So it will be remote controlled, using the BuWizz. So: Driving by 1 XL by axle Steering: 1 servo by axle. To have the 3 steering modes: a M motors controls a PFs switch -> it changes the sens of rotation of the rear servo, or it stops it. The pneumatic pump is powered by a M motor That was the start: And now I’m here: On these two pictures, you can see the rear PTO. On this side, the pneumatic pump: And here is the mecanism which allows the possibility to get 3 steering modes: The chassis is very, very compact. I think you can put an elephant on it, it will not move at all. For the tools, I think I’ll make a pneumatic arm (The pneumatic cylinders of the Mercedes truck would be very helpful, but I don’t have this set) And for the front I don’t know, so if you have ideas, tell me!
- 40 replies
This is a MOC I have made based off of the steiger line of tractors. I have decided to put this project on Lego Ideas, and was hoping many you could support it. I am striving for this to become a Lego set. I do understand that there is less of a chance for this to become a Lego set because it is Technic. I would appreciate no negative comments about this Technic creation being on Lego ideas. Only constructive criticism please. If you could share this around, or just support it. Every supporter counts! Here are a few pictures of the model: Link: https://ideas.lego.com/projects/114366 This MOC functions include: Lights All wheel drive Articulated steering Working steering wheel Openable hood to reveal a in-line 6 engine Working PTO A VIdeo of the Tractor: Thanks for the comments and support!
- 10 replies
Hi everyone! I'm happy to present my newest Lego creation, the completely remote controlled K.I.T.T.! I'm still young, but old enough to know and like Knight Rider. It's the reason, why I recreated K.I.T.T., the main character of the series. Of course with a huge amount of Power Functions! Driving, steering, working scanner and headlights. Six motors, two extenision wires, two pairs of leds, two switches, two IR receivers and an AAA battery box. As many electronic parts, as possible! :D It is my third model at a bigger scale. The building was very interesting. There were a lot of technical challenges with the chassis and the body shaping was difficult, too, because usually I make smaller models. Hope, that I can make more MOCs at similar scales in the future. There are a lot of Lego replicas on the net. For example I found out, that I use the black minifig shields for the wheels. After it I saw, that Firas has already done it! The working scanner and headlights aren't new, too. But! As far as I know, this is the smallest K.I.T.T., which contains these functions! At first please watch the video! Below I tell some things about it, and later there are information about the fuctions and technical detailes! Hope you like it! :) At first I send a huge thank you the three persons, whose names are at the end of the video, for lending me some PF parts, a camera tripod and making the music! It's the first time, that I don't use downloaded music, so I'm very happy! :) Kitt has an enemy, called Karr. Karr was the first car, but he was evil. I built at first Kitt, but later it came into my mind, that it would be more interesting and unusual to build Karr. But almost everyone likes Kitt, and almost noone likes Karr. So finally I decided to put more Kitt scenes into the video and upload the car, as Kitt. I started shooting. I brought out to the street two reflectors, the car and the camera. There are scenes, where you can see two cars together. The truth is that I have only one. After every scenes I exchanged some parts of the body, and continued shooting, without changing the position of the camera. Later I cut the pictures near each other. And it was shocking to watch the scenes on the computer! I thought, that the red light in the dark night will be very impressive and will look very cool. But Karr looks much better. The overall look of him, and the yellow light definitely win against Kitt. I went out again, to make some scenes about Kitt, but the result wasn't better I don't know why, but my camera likes the yellow light better, than the red light. The appearance of Kitt is not so strong, as I thought at first. It is weak But the screenplay allows you to decide, who wins! :) Despite the difficulties, I really liked to make this movie and like the result. Hope, you like it, too! Driving: The car is drived by an L Motor, with a gear ratio 1:1, through a differential. Steering: It is very simple, too. I used a Servo Motor. The other two functions are more interesting. Working headlights: I used two M Motors. If I push the button on the remote control, I start to operate both ones. One of them opens the lights, the other one switches them on. It is impossible to push and release the button fast enough, so I had to use slippery mechanisms. For the opening I used a clutch gear, you can see it on the bottomview picture. But at this level of cramming, there isn't enough place for a clutch gear everywhere, so I found out a new solution. Between the two connectors, there is a small piece of rigid hose. If the switch reaches its end position, the hose can rotate calmly further in one of the connectors, and the mechanism waits my reaction time. Working scanner: Two M Motors again. One of them switches on the light and the other motor, which starts to move the light. The switching mechanism is very similar to one of the pneumatic autovalve. After it changed the position of the PF switch, it rotates further and doesnt cause damage. The construction, which transforms the rotation of the motor to the linear motion of the red light, contains three liftarms. More pictures on my MOCpage! Thanks for watching!
- 24 replies
- kitt
- knight rider
(and 5 more)
Tagged with:
I´m happy to present you my newest model, a not exact copy of the ferries on lake Balaton in Hungary. Hope you like it! As I was a small kid we often spent our summer near Balaton. If someone is younger than 6 and lives normally in a small village, it is really impressive to see cars which drive onto a ship and after that they come down on the other side. That´s why it was always a highlight for me to visit and sometimes travel by this ferry. Still nowadays if I´m there I wait the ferry once coming and going away. It´s still the same ferry as 25 years ago, I still find it really cool and it brings back the old memories. It took 9 months from the idea to the final MOC. The building process included some really cool challenges and was one of the most exciting developing projects in my entire MOC-life. The idea was to build a remote controlled ferry which can swim and drive on real water, can catch the coast reliably and my older tiny RC models (Milka truck and Flixbus) have to be able to drive up and down. The last requirement was to make it possible to show the whole setup on exhibitions. At first I searched on the internet for the biggest one-piece plastic box and ordered one of them. It was difficult because most of the big boxes has small bottom wholes to let water out. I needed exactly the opposite of it. Keeping water in the box. The measures of the box decided the measures of the model. On the beginning I tried to experiment with some LEGO boat hulls. The facts that these hulls are not completely closed and the ship is without vehicles already very heavy brought me to the solution to use empty bottles. They are the most reliable things to keep air in and protect the electric parts, like Sbrick from the water. Of course you can say I could put everything to a higher position, not integrated into the deck. But no, if everything would be in the building, everything would be on one side and the ferry would be completely unbalanced. On this side everything would be under water. What I could do was to integrate the motors on the other side into the deck. It was also not enough. I needed counterweights. At first some LEGO keels, but they were not heavy enough (they contain air, too :/). So at the end I used simply some pieces of steel. The real ferry has Voith Schneider propellers. We know that it´s possible to recreate it with LEGO bricks, but not at this small size. And he depth of the box is only 15 cm. That level of reality was also not the goal of the project. The draught of the loaded ferry had to be less than 15 cm, so I decided to use 4 propellers. Of course the available propellers of LEGO are like disasters, if we examine their functionality. If they are not, they are too big. So I built my own version out of Technic pieces. The propulsion uses two channels of the Sbrick, one for each side. You can turn with the ferry that way. I thought you don’t need this feature in this thin box, which is only 10 cm wider, than the ferry. But I was not right. You really need to do turning maneuvers to keep the ferry parallel with the walls. And yes, I hope I will have the chance to drive the ferry in a bigger pool in the future! Next challenge was to catch the coast stable enough for the buses and trucks. Maybe I said earlier that the ferry is everything else than horizontal. The counterweights are good, but not good enough. The proportion of the weights of the vehicles and the real ferry are also different than at the LEGO word. So the LEGO ferry has extremely strong reactions, if the vehicles come. The real ferry has also water tanks to balance itself. The LEGO ferry doesn´t have such a help. So I decided to build the ramp so that it can take part in bringing the ferry into a better position at least near the coast. There is a hook on the ramp (see in the video). It catches the panels of the coast and don´t let the ferry go away. After that it goes down a bit more and forces the whole ferry to raise itself a bit. The coast is horizontal, so this force brings the ferry also closer to the right horizontal position. That is nice, but as the vehicles arrive, it changes. That´s why I had to develop a correct order, position and driving path for the vehicles, too. These small vehicles are not off-roaders. If you can´t follow the instructions, the vehicles stuck on the ramp. But if you do everything well, it works smooth! The most difficult one of the nonfunctional problems was to create the meeting of the deck and the curved walls without gaps. I used for it 1x2x2 panels. The deck goes actually into the wall (under the top of the panels). But the upper end of these panels is not equal high with a whole number of plates, so I had to sink the wall on the sides with a half plate. I did it by using different wholes on the Technic frame, as for the deck. 1 Technic whole is 2,5 plates, so using neighboring wholes gives us the 0,5 plate difference. The ferry had its first appearance on Bricks4Family 2021. It worked surprisingly well during the weekend. After the box was completely horizontal and the exact level of the water was also found. By catching the coast the visitors often thought, it´s enough to turn off the propellers and open the ramp. What they (and I on the beginning) didn´t realise was the fact that if the ferry drives, the water goes in the other direction under it. If the propellers stop, the water brings the ferry slowly back. One method is the perfect timing with opening the ramp. Other method is to keep the propellers on and opening the ramp at the same time. After Bricks4Family I made a few very small changes on the ferry, so on the second exhibition (Ilmbricks 2021) worked everything even better. I put for example a door on the side, so it was possible to switch on and off the battery box, without removing the captain´s deck, the life boat and the whole roof. The deck has also 4 invisible, but removable panels. If they are removed, I can hold the ferry by holding the really strong Technic frame. Now there are small Technic bricks in them. It became much easier to remove the panels with the help of a small bar or an axle. If you really read all of these, a huge thank you for it! Hope you liked the ferry! You can find the pictures in high res in my Photostream! PS.: The next exhibition where I plan to show the ferry is Bricks am Meer 2022 in Bad Zwischenahn, Germany. Hope we can meet there!
I made the 2021 LEGO 76240 Batman Tumbler drive (again) and upgraded the looks to be more real. full remote controlled motorization (drive and steer) independend suspension (front: moving liftarms!) moving front armour plates as in movie retractable roof complete do-over of side armor plates: finaly polygons very close to the movie (not flat as LEGO did it) front gunner seat "hydraulics" finally as in movie winglets fixed on both ends now (no loose parts as from LEGO) Mind the Gap - closed that gap between the rear tires (i think in danish LEGO rhymes on lazy ;) Instructions on rebrickable: https://rebrickable.com/mocs/MOC-95123 I already did this with the 2014 version. Actually it was my first LEGO set in years. But I was never really happy with this. There were still too many flaws (as with the 2021 version) This time i wanted it to look more close to the original, finally. So I upgraded the armour and some other details a bit, to fix LEGO's little flaws. This is the LEGO Tumbler Batmobile, I always wanted.
Hi guys Recently, I finished another model. It is a tractor unit inspired by Scania S-Series trucks. It has 6x4 drive and suspended axles. The front axle is suspended with normal LEGO hard shock absorbers. The rear axles have rubber suspension which imitates air-suspension as used in real trucks. The suspension at the rear axles is a bit hard but chassis is in return flat. The fifth wheel as a self-locking mechanism so that you can couple a trailer easily. To open the fifth wheel a small linear actuator is used. For steering a PU L motor sits directly on the front axle. For propulsion I used two PU XL motors. But check the pictures and video: Instruction at Rebrickable: https://rebrickable.com/mocs/MOC-86508/FT-creations/6x4-tractor-unit-inspired-by-scania/#details
- 21 replies
- lego
- lego technic
- (and 11 more)
Johnny 5 needs your support to become an OFFICIAL JOHNNY 5 LEGO SET. Click the link below to support and feel free to share. - Link Removed - Who is Johnny 5? Hello, Bozos! Those who don’t know him, Johnny 5, also known as “S-A-I-N-T Prototype Number 5” or Number 5 for short, is a very lively and inquisitive military robot prototype who’s perpetually hungry for more “input”. He is the star of the 1980’s movies Short Circuit and Short Circuit 2 and a TV special called Hot Cars. He became sentient when he was luckily struck by lightning during a combat demonstration. Although he is designed to serve the military as a robot prototype, he has an adorable child-like behaviour and has a great respect for life. He is a peace-loving robot and refuses to use his military capabilities to harm others. Despite being very intelligent and inventive, his naivety and trusting nature has been taken advantaged of on several occasions. Why Make a Johnny 5 Lego Set? In Short Circuit 2, Johnny 5 set up a new business with his old friend Ben Jahrvi that builds and sells toy robots made in Johnny 5's likeness. This little robot never made it into actual production after the film. Johnny 5’s popularity and the unavailability of access to these cute little Johnny 5 robots made people clamour for this toy. To date anyone can google sites for 3D printing Johnny 5 robots and websites dedicated to producing both life-like and miniature Johnny 5’s. Johnny 5 is one of the iconic fictional robots in cinema to date. He’s part of every child who’s lived through the 80’s like me who are now AFOLs and longed for the Johnny 5 toy that never came out. Design This model is fully motorised using Powered Up motors and hub and controlled through a mobile device using the Powered UP App. It uses Technic parts to ensure stability of the structure, and System parts to capture the look and form of Johnny 5. The following are the playable features of the model: Movement – This model can move around on tank tracks and uses skid steer to change directions. Body – Johnny 5’s body can tilt using a Powered Up L motor and controlled using a mobile. Arms – Arms can be raised and lowered individually using the Powered Up App. The fingers can be adjusted manually as well as the elbows. Head – The head can be tilted and turned using the Powered Up App. Eyebrows – Eyebrows can be manually adjusted to suit the desired facial expression. Laser – The laser at the back can be raised and lowered using the Powered Up App. Total Pieces: 2,711 Dimensions: Studs: W 68.4 x L 36.1 x H 73.5 Inch: W 21.5 x L 11.4 x H 23.2 cm: W 54.7 x L 28.9 x H 58.8 Weight: 99.8 ounces or 2.83 kg
- 1 reply
- remote controlled
- moc
- (and 10 more)
A compact sequential heavy-duty 4 speed remote controlled AWD gearbox Each gear of this remote controlled gearbox approximately doubles the speed of the previous. The output shaft contains an integrated lockable differential for AWD. See the video for a WORKING DEMO | FREE INSTRUCTIONS below. GEAR RATIOS 1st 6:1 2nd 3.3:1 3rd 1.8:1 4th 1:1 FEATURES compact remote controllable sequential gearbox 4 transmission speeds evenly distributed gear ratios differential output (AWD) differential lock single rotary catch many mounting points no half studs INSTRUCTIONS [PDF] https://bricksafe.com/files/hdegroot/remote-controlled-4-speed-awd-gearbox---with-perfect-gear-ratios/remote-controlled-4speed-awd-gearbox-with-differential-lock.pdf [3D MODEL] https://bricksafe.com/files/hdegroot/remote-controlled-4-speed-awd-gearbox---with-perfect-gear-ratios/remote-controlled-4speed-awd-gearbox-with-differential-lock.io REBRICKABLE: https://rebrickable.com/mocs/MOC-83457/hdegroot/remote-controlled-4-speed-awd-gearbox-with-perfect-gear-ratios BRICKLINK: https://www.bricklink.com/v3/studio/design.page?idModel=244834
- 10 replies
- differential lock
- differential
- (and 11 more)
Hey folks, another Motorization: all Functions of the 1989 Batmobile (LEGO 76139) RC controlled - yep the Batman again... Without sacrificing any of the nice details: Cockpit is still there, steering wheel works, just all motor driven and I motorized the guns and the roof and even made a tailored sbrick profile. Building instructions: Motorized LEGO 1989 Batmobile on rebrickable Driven by 2 LEGO Power Functions L-Motors (1:1 transmission) steered by a LEGO Power Functions Servo Motor guns engaged/disengaged by Motor roof opened/closed by Motor special Sbrick profile with programmig and grafics included a lot of space for up to 2 battery boxes/control hubs easily reachable under the trunk hatch (details on my rebrickable MOC page) Watch a Review of my motorized 1989 Batmobile on youtube: The Batmobile from Tim Burton's Batman 1989 with Michael Keaton is definitely one of the coolest, it's not as funky as the 1960s TV version and not as tank as the Nolan version but in my opinion it's simply a beaute! The 1989 Batmobile is using over 3,300 pieces, and over 60cm long. I added a few hundred bricks, mainly LEGO Technic and reused some others. So I ended up with over 3500 parts and (batteries included) almost 3.5 kg. That's heavy! So I needed a powerfull drive. I was thinking about the buggy motors but these are large and I wanted to put the batteries into the trunk. So i went for a pair of LEGO Power Functions L-Motors. These are some of the strongest LEGO motors and very small and efficient for their power and speed. The 1989 Batmobile is sleak and lies very deep on the road so it is geometrically impossible to move up any small hills (or even carpets). It will get stuck with its floor height of less then a brick. So it will only drive on a flat surface anyway. So it can be build for speed instead of torque power which the 1:1 transmission of the two L-Motors will do: It's a speed build, literally. One reason to put the batteries into the trunk was, to reach it easily for changing/recharging or simply switching on. Another reason was, to not put them into the beautifull cockpit with its nice self opening windshield - self opening? Yes, now it is motor driven ofcourse. And you hardly see the mechanics on the floor. Okay, the Batman minifigure included is way too small for the car but I found a Batman LEGO LED light, that fits into the car. Just be carefull when closing the cockpit to not get stuck. Slide-open is no problem. The car’s turbine exhaust by the way does not drive the machine guns anymore (it does in the original) because now a motor engages them. So I could make the jet exhaust it look like a real jet engine - the only exterior I changed. To make the two machine guns hidden, under the hood pop up, just press a button now. The Batmobile comes with nice little Bat emblems printed on the wheel rim - try not to lose them while driving, they are rare parts. The set of specially designed tyres for the front wheels is steered in a very specific geometry. I took care to keep that working the exact same way because it works very well for steering. The Build was complicated, took me weeks to get it right. I didnt want to change the exterior and as few as possible from the cockpit. You shouldnt see the opening mechanics. And I wanted to have all the features working, even the steering wheel (though steering is handled by a servo motor now) Every time I thought I got it, something else made problems, untill finally it all worked out. You can skip the trial and error (and breaking old LEGO gears) part: I made instructions and made them easily readable, so you can have it speed build in no time. I believe everyone should be able to build a LEGO set and try to make my instructions like that. Now it's hard to say, which one is the best batmobile motorization I ever made: The Lego 76139 1989 UCS Batmobile has more functions: motor driven MGs and a motor driven roof, the remote controlled motorized Lego 76023 UCS Tumbler I modded however has a full steerable front suspension for the independen wheels. my special Sbrick profile with some automated scripts is included I even made a cable layout for the power functions cables and extentions if you ended down here you may also be interested in or
Hi everyone! I´m happy that I can present my newest creation! It´s the next piece of my minifig scaled RC collection. This time I decided to build a Flixbus. After Flixbus bought the rivalry Eurolines, it became maybe the cheapest way for poor students from Hungary (or not only from Hungary) to travel across Europe. At least for me it was the perfect method at that time! Hope you like it! Unfortunately the last time I travelled somewhere by a Flixbus was in August 2019. But hopefully it will change in the near future! Flixbus came often in the middle of the night, just as the Knight Bus did in Harry Potter. That´s why it stands on the destination screen Before you start reading about the boring technical facts and irritating things during the building period, please watch the video! It took approx 4 months long to build the bus. It´s not the first tiny RC I build. Despite of it I can´t say it didn´t challenge me. Yes, I´m speaking about the lettering and arrows on the sides. Maybe you still remember of the Milka Truck. That lettering has only vertical or horizontal building techniques. That´s why it was possible to do the lettering on each side only 1 stud deep. It was important, because it allowed to put the battery box (the biggest and most inflexible element) between the two walls and staying with the width in 6 studs at the same time. But “FLIXBUS” is more difficult. It is also not always possible to have stud connections (for example letter X, or the diagonal arrows). In this case the letters have to have inside some bigger parts on them, which simply doesn’t allow them to fall out. It means it stays only a two-stud wide space in the middle. That’s enough for the technic chassis, but not for the batteries. And also not for the motors… So only the half of the lengths stayed for the functional parts. For the steering and propulsion I stole the method from the Milka truck (with vertical motors), where they´ve already proven, that they work really well. The only possible (long enough) space for the battery box was at the back. Fortunately right above the driven wheels. They need the weight on them to increase the friction between the tires and the street. Another positive feature is, that the Sbrick is small enough to be above the letters, so I didn´t have to make the whole bus longer. Another part of the challenge was to create the diagonal white lines on the front. There was almost nothing inside, which they could be attached to. The reason is, that the moving parts of the steering are there, so it´s simply impossible to put there any other parts without disablement of the steering. Other reason is, that the upside-down parts of the front have already used the space there. At the end I decided to use the rubber bands, without being irritated by the fact, that it´s possible to see them outside, too. The bus has three axles. The third one is again an axle with some kind of fake suspension. It is just hanging there and doesn´t hold anything, so in theory it can never happen, that the driven wheels leave the ground. Please notice the detail that there are brackets instead of plates on the top of the third mudguards. It creates a bit bigger space in the mudguard for the wheels with the fake suspension. It means, that the bus can win against bigger obstructions. All in all I really enjoyed working on the bus. Hope you like the result, too! Thanks for watching and reading! Feel free to visit my Photostream on Flickr, to see some of my other creations: https://www.flickr.com/photos/gabor_horvath/
Hello everyone, I want to share a new creation. This time it is an alternate build (B-model) for the Liebherr LR 13000 Crawler Crane set #42146. You can find instructions here to build the model by yourself. 100% made out from parts of donor set 42146 with no additional parts needed. 100% controllable with official Control+ Application. In order to all functions of that Liebherr HS 8300 Dragline Excavator, you get a complete overview in the following article on how to build, control and calibrate this alternate model. Summary of Functions & Features remote controlled tracks and 360° superstructure rotation remote controlled boom remote controlled independently hoist-rope and drag-rope controllable with official Control+ App for Smart Device using 6 motors and 2 hubs spinning radiator fans detailed cabin playful details like fire extinguisher, ladder, railings and exhaust pipes brick-built bucket 133 cm / 52 inch long 100 cm / 39 inch high high-quality premium PDF instructions includes guide how to calibrate the model Impressions Main control The Liebherr HS 8300 Dragline Excavator is designed to work 100% with official Control+ Application using the already known interface from its main set. Driving tracks and rotating the superstructure works exactly like the LR 13000 does with the original designed buttons on the app interface. Boom control The giant boom of this alternate model is controlled with the right app lever. It drives the longest rope (shown in blue) through pulley mechanism to raise and lower the boom. The highest and lowest position of the boom depends on the limitations of the app after proper calibration of the model. The boom stops automatically in the lowest position to always ensure a 360° rotation of the superstructure without colliding with the tracks. A linkage mechanism slightly moves the nose who is helding the drag-rope and ensures that the app can detect the highest boom position during calibration. As a nice addition, a spinning radiator fan is connected to the same motor that drives the rope for boom. The second fan spins freely. Hoist-Rope & Drag-Rope Controlling the bucket works like the real machine with an independently hoist-rope (shown in green) and drag-rope (shown in red). The hoist-rope is controlled either up or down with the left joysticks vertical movement. By horizontal movement with the same stick, the drag-rope goes in and out. Since this two ropes are controlled by just one joystick, combinations with both ropes are possible and also needed for proper playing. This requires a bit practice though, but makes it possible to control the bucket and two ropes together with just one (steady) finger. The length of the hoist-rope depends on the app limitations for that joystick movement, meaning that the hoist-rope can't go too long before the app stops the motor. On the highest position of the boom, the bucket can reach the ground with fully extended hoist-rope where boom and hoist-rope are in limited positions controlled by the app. During calibration the app also detects the most inner position of the drag-rope. Working under ground With lowered boom and extended hoist-rope, it is actually possible to dig something below the model. This makes fun by placing the model on a table for example. Calibration For a correct calibration by the Control+ app, it is required to separate the hoist-rope from the drag-rope. In the instructions there is a full guide included how to calibrate the model during building. Additionally there is an extra PDF guide included that explains how to calibrate the model at any time. Please make sure you have completed the calibration to ensure the best playing experience with this model. How to build Building the Dragline Excavator starts with the base from the LR 13000 main set. Make sure you build the undercarriage with book 1 until step 343 is completed. Before you continue building, check the tracks und turntable function. After the correct calibration with Control+ app, the instructions for the HS 8300 takes over to complete the alternate model. The premium instructions for this model comes with 338 pages of high-quality images and building steps to ensure a satisfying and slightly challenging building experience for a 18+ set. Make sure to test all functions and alignments of ropes through the building process. Happy people with sealed parts can open bags 3 to 5 to complete the build. Connecting ropes with spools and making nodes can be an annoying thing even for the main model. If you already have built the LR 13000 main set, you can let the spools with ropes connected. The alternate model starts with wound up spools during the building process. Controlling quick guide To become a real Dragline expert under the sun, here are some quick tips for controlling the model: 1) Place the model from the left to the right At the beginning, place your model driving from the left to the right to match the joystick interface for the Control+ app. 2) Sliding bucket over ground This is some basic control for Dragline Excavators. Slide the bucket over smooth surface by controlling the drag-rope winding inside simultanously with the hoist-rope slightly going down. 3) Moving bucket along the boom As advanced controlling, this requires a bit practice but also avoids loosing cargo when the bucket moves along the boom. The drag-rope should go out simultanously with the hoist-rope going up with a bit tension on both ropes. 4) Unload the bucket On a loose drag-rope, the bucket always hangs in the air on the hoist-rope. Simply give some length on the drag-rope to tilt and unload the bucket. 5) Keep watching the drag-rope The app itself cannot detect outer limitation for the drag-rope. In case the drag-rope goes out too far, it is possible that the rope slips over the spool. Treat the drag-rope always with a bit tension. 6) Avoid tension on same direction This case is also not detectable by the app. When the drag-rope goes in simultanously with the hoist-rope going up, there is too much tension at any point. As a result, the parts holding the bucket are going apart at the weakest pin connection. Giving some length on both ropes and connecting them together solves this. Final note Goal with this alternate model was to create something else from the hard discussed Liebherr LR 13000 Crawler Crane. Rebuild, re-calibrate and having fun is exactly the way how this model works. The app goes hand in hand with the design with a large learning curve on controlling the model. Let's find it out by yourself. Think out of the 42146 box and have fun with this replica of Liebherr HS 8300 Dragline Excavator. If you like the design and you even own the 42146 LR 13000, go for it on rebrickable and build your own.
- 31 replies
- control+
- remote controlled
- (and 6 more)
Hello everyone, this model of a Tower Crane is made only with 1166 pieces and controlled with either smart device or physical remote. In order to all functions of that model, you get a complete overview in this article how to build and how to control this crane. You can find instructions here if you're interested in building this model. Summary of Functions & Features remote controlled with PoweredUp 2-way-gearbox to select between functions motorized hook, trolley and 360° crane rotation Hub with batteries as counterweight modular building with extendable tower Minifigure scale to fit City layouts openable cabin 83cm superstructure length 70cm tower height Impressions Electronic components The crane uses the newest PoweredUp electronics to power all the functions. In order to remotely control this model, a physical remote pad is not mandatory because the crane is also controllable with optional smart device and PoweredUp app. Shaped with some system pieces, the PoweredUp 2-port hub with batteries included fits perfectly as counterweight and is easily replaceable. Simply turn on the hub by finger press and connect them to either PoweredUp app or physical remote to let the fun begin. The official set 76112 Batman RC Batmobile offers all electronic PoweredUp components they are needed to control this Tower Crane. Trains (60197, 60198, 60336, 60337) from the City theme are also nice and welcome starting packs for electronics, because they all include one PoweredUp hub and a physical remote pad, which then requires only 2 additional medium motors. Controlling the crane Heart of the design and probably the most interesting part building this model is the controllable gearbox behind the cabin. Where motor A controls the movement of the trolley, the functions of motor B are selected through gearbox. The following configurations are possible when playing with this crane and two motors together: Motor A - Motor B Trolley - Hook Trolley - neutral Trolley - 360° rotation For the crane it is very important to have a neutral position for rotating the superstructure. In case this function is unselected, the crane can freely rotate and prevent from falling. This is a feature that can be also seen on real Tower Cranes. All functions are secured with clutch gears to prevent damage. The winch for the hook has also a safety mechanism included. This holds the cargo even when the function is unselected. Controlling the crane is thinkable easy. In the PoweredUp app it just requires a profile with two slider - one for motor A and one for motor B. That means that this crane is controllable with a custom profile or even with the available one from Batmobile. Keep in mind that controlling the model does not require a smart device by using the physical remote pad. Building the crane Splitted in separately parts, building this Tower Crane feels like constructing the real thing. Official strings (part 37597, 56823) are used in this model that are widely used with many lengths in other Technic sets. Of course you can use any other strings you want. The crane uses a modular building style where each part of the tower fits to each other. The inventory includes all parts that are required to build exactly one middle section, but it is still possible to omit and to create a crane with a lower height of the tower. Furthermore the height of the tower can be extended by replicating a middle section stacked to each other. A higher tower then requires a longer string for the hook for sure. The following inventory shows only the parts they are needed to build one more middle section: Made with Minifigure The cabin can be opened to put a Minifure (without hair or hat) inside. Since this Tower Crane is made in Minifigure scale, it matches perfectly each layout with Trains or Construction vehicles also in the City theme. Instructions Premium instructions for this model consists of 283 pages with high quality images and building steps very close to the Lego Technic ones. The instructions helps alot on how to connect strings and wires correctly. Following are some example pages to show the quality of instructions: Goal with this model was to create a Tower Crane that is not that big and expensive and buildable for everyone. Tons of hours are spent to experience with balancing and stability. The end result is pretty neat, the crane works just perfect but dont expect too heavy loads on it. The model fits all standards for easy building and color-coded components. If you're interested in building this model, you can buy instructions here and support me and my future work. Have fun with this Remote Controlled Tower Crane. Follow me on Instagram for updates and news
- 2 replies
- rc
- remote controlled
(and 7 more)
Tagged with:
Hi everyone! My newest creation is remote controlled! It's a bus and it's my fifth tiny RC at minifig scale! Hope you like it! My previous RCs on Youtube: , , , Of course I visited the intercity bus station with a camera and the bus again, as I did recently! The type of the bus is Ikarus, but only the body is Ikarus, the engine and chassis is Scania. That's why you see the word 'Scania' on the front. It's possible to travel by it in Hungary. At the area, where I live, the bus company has I guess three of them. So we have more chance to catch it, than to catch . If you read the technical things below, you will see, that it has some disadvatages. But I like it very much and I'm really satisfied with the body! It has some crazy building techniques in every directions. As far as I know, they are my own inventions. Maybe they are already exist, but I didn't know them. My favourite detailes are the headlights, the taillights, the upside-down windows near the gear rack, the covering method of the destination screen and the air conditioner. Technical detailes: It is more difficult to build a bus at this scale, than a truck. For example at a the truck we can use five stud wide frame, and after that we can cover it by tiles, so it won't be too wide. But for a bus we have to use panels to make the windows, they are 1 stud wide on both sides, so if we want to stay in 6 studs, the frame can be only 4 stud wide. And Technic prefers the odd numbers... It's not good if the driven wheels leave the ground, so the rear wheels are not completely fixed. Looks like, if I make something better, something becomes worse. It's the first time, that I used servo motor for steering. The steering features are better, the frame is worse. Below you can see an image without the body. You may notice, that there is an arch in the frame, like a bridge. The AAA battery box is at the back, and its weight causes this deformation. Furthermore there's no possibility to fix the body by studs after the servo motor. Therefore the mudguards touched the rear wheels. I had to raise the rear part of the body by half plate. It causes some deformation, too And finally I have to tell you in secret, that the servo motor moves the gear rack on a little bit longer distance, what the inner things allow. So the motor twists the frame. You can see it in the video at . Therefore one of the front wheels sometimes leaves the ground.And almost all of the weight is on the driven wheels, so sometimes the bus wants to go straight ahead, instead of turning. But it's very rear. And finally you can see the small piece of pneumatic hose, which holds the window in upside-down position. The base and the top of the window panel has a different thickness. It depends on its position, in which height the more space in the body is. If I use the window on a normal way, the gear rack pushes it out, during steering. All in all it looks cool and works well, so I'm happy with the result of my fifth attempt! More pictures: http://www.moc-pages.com/moc.php/425778 Thanks for visitnig!
Hi everyone, Here's my modification of Lego Technic 42024 Container Truck set. In addition to original functions (steering, outriggers and container lifting) it has: - 6x4 driving, - 90° tilting of the driver's cabin, - Working & tilting steering wheel, - Fake V8 engine (working), - Led lights, and is completely remote controlled. I used: - 1 L-motor for 6x4 driving - 1 Servo motor for steering - 1 M-motor for outriggers - 1 M-motor for lifting the container - 1 M-motor for tilting the cabin - 1 rechargeable battery box - 3 IR receivers - 1 set of led lights - 1 x 20 cm extension cable Bricksafe: http://bricksafe.com/pages/Chilekesh/42024-rc (*.lxf file can be found here). Rebrickable: http://rebrickable.com/mocs/Chilekesh/42024-container-truck-motorized-rc Any suggestions on improvements are very welcome. Cheers and happy building!
Hi everyone, Here's my modification of 8416, fully motorized and remote controlled. An additional function is the working & tilting steering wheel. The PF elements used are: - 1 M-motor for driving - 1 Servo motor for steering - 1 M-motor for lifting - 1 M-motor for tilting the lifting assembly. - 2 IR receivers - 1 Rechargeable battery box Rebrickable: http://rebrickable.com/mocs/Chilekesh/8416-fork-lift-motorized-rc Bricksafe: http://bricksafe.com/pages/Chilekesh/8416-motorized (*.lxf file can be downloaded here). Any suggestions on improvements are very welcome. Happy building!
Hi, Here's my modification of 42008 Service Truck set, fully motorized and remote controlled. I decided to keep the original functions (including pneumatics) exactly as they are while adding some extra features as well. The additional functions are driving, tilting of the driver's cabin, headlights, steering and working-tilting steering wheel. I tried my best to keep the original looks (with some visual improvements though) and made the structure as rigid as possible. The PF elements used are: - 1 L-motor for 8x4 driving (with single, shared differential) - 1 M-motor for steering - 1 M-motor for tilting the cabin - 1 M-motor for functions (included in the original set) - 4 M-motors for switches - 2 for pneumatic switches and 2 for mechanical switches - 4 IR receivers - 1 Rechargeable battery box - 1 Led light set, - 2 x 20 cm extension cables, one for the large motor and one for the battery box. Rebrickable: http://rebrickable.com/mocs/Chilekesh/42008-service-truck-full-rc Bricksafe: http://bricksafe.com/pages/Chilekesh/42008-rc (*.lxf file can be downloaded here) Any suggestions on improvements are very welcome. Cheers and happy building!
Hi everyone! Fortunately I have the time to share here my newest creation! It's a train and it's the model of an ICE 3. It is 196 stud (157 cm) long and contains more than 3300 pieces, two IR receivers, two battery boxes and two train motors. Hope you like it! Oh, and another important information is, that it will be visible on Zusammengebaut 2016 in November and on Bricks am Meer in April 2017 in Germany!At first please watch these two videos! The first one shows a crash. The place, where I made the video, wasn't horizontal, and on the slope the train got a too high speed The records of the second one were made after I repaired the train. Well, I can say it is quite stable construction, despite the building techniques of the front. During the crash, only the boogies fell down! I'm really happy, that it is ready! It took me almost a year to build and become satisfied with the result. You may know, if someone build a train, the front is the most important thing. If it's not good, it's unnecessary to build the other sections. Everything started with an LDD model from a front-idea. I built something in the program, but I didn't like it. Later it came always into my mind and didn't allow me to be calm. So I started to develope the construction. Some month later it looked nice enough to order some parts and make it in real life. It contained so many interesting and strange techniques, that it was a real challenge to put the bricks together in the program, and with real bricks it was hard, too. And the real 3D model was ugly! But I said, that it has to be possible to find out something, which makes the model better. So I made some changes, and some more, and some more, and finally I liked it, and I thoght that I found the maximum! I stored the train (only the front section) and some other parts on the table in the middle of our house. And one night, I couldn't sleep. I woke up and went out to the table to do something. And I don't know why, but I put an element into the middle of the front. And I said 'wow'! It was perfect (for me of course, for you, I still don't know, but I will read the comments :) )! Some gaps disappeared, some sections got new positions. That element made so big changes on the overall look, that it was incredible! I felt high, but next day I was very sleepy. :D More pictures are available here: http://www.moc-pages.com/moc.php/433076 Thanks for watching!
Finally i found some time to present you my latest MOC here. -> the 34,8 km/h black speed record racer It is the fastest 2-motor LEGO-rc-car until now (june 2017). While developing i was aiming for the highest speed you could reach with only 2 buggy-motors. To reach the goal, i had to: - reduce weight as much as anyhow possible - reduce the rolling resistance as much as possible (using only 3 as thin as possible wheels [only frontwheel could be better for indoor use: 2815 + 4185, but doesnt work outdoors]) - reduce axle-beam friction; just 3 studs in total (5 to protect the motor bearings) - find the best gearing - reduce air-resistance, and keep center of gravity as low as possible -> so here are the specs: Including panels in studs: length 55 , wide 21, height 12 (wheels) -> weigth: 650gChassis only (ready to race) : length 42 , wide 21, height 12 (wheels) -> weigth: ultralight 621g (without speed computer)Ground clearance: 0,5 studsGearing: 2:1 up at the fast output of the buggy-motorsTop speed: 34,8 km/h I know some of you dont trust the LEGO-speed-computer, so i also didnt at first. I startet measuring with gps with my heavy weighted mobile phone (more then 150g), but i didnt like the idea, to add 25% of weight to the model just for speed meassuring. Thats why i decided to buy a speed-computer (21g) [ could get one for 15€] just to try how accurate it is. And SURPRISE... it is really really accurate. I made a lot of comparing runs with GPS-phone (speedo app in 1 second mode) AND speed computer together attached to the car. The biggest difference i could ever meassure was 0,3km/h. You can see some pictures of this at the end of my video. (In my next video i will make some videos of this, not just pictures). Here are some pictures and the building instructions as Lego-digital-designer-file: https://rebrickable.com/mocs/MOC-8658/Summse/348-kmh-black-speed-record-breaker-worlds-fastest-remote-controlled-2-motor-lego-car/#comments I hope you like it :) TechnicSummse And finally here is the video :) -> Its the first video i ever made
Hi, I'm looking for a reliable remote controllable 5+R sequential gearbox or ideas how to build one. If it would have a neutral as well it would be perfect. Please share your ideas and if you are aware of any kind of existing solution please share the link. Thanks, Zoltan
- 9 replies
- gearbox
- remote controlled
(and 1 more)
Tagged with:
What do you kindly think? (For God’s sake I don’t think there is an already created topic for this! If there is, I am so sorry, again ) Best Regards, Idris
- 4 replies
- remote
- remote controlled
- (and 5 more)
This is an alternate build of the Lego Set 42100, Liebherr 9800. Parts list used in the MOC is listed so you can opt to just buy the required parts instead of buying set 42100.Motorized features include: Tank drive for both tracks Arms upward/downward movements Head turn Head tilt Body tilt Manual play features include: Upper and lower eye flaps can be moved to show facial expressions. Finger movements. Limited manual arm movements Here's a link to the YouTube video to showcase its movements: RJ's Johnny 5 YouTube Video If anybody is interested, building instructions are available at Rebrickable.
- 9 replies
- moc
- remote controlled
- (and 10 more)
Finally, the 2022 LEGO 10300 Back to the Future Time Machine the DeLorean - motorized with powered up ★ Building Instructions on Rebrickable (klick) ★ Features remote controlled motorization - fast driving, 40° steering angle - No scratching gears or rubbing tires Cockpit untouched not flying, but you can still modify it for Back to the future I, II and III version easy to reach Battery box for charging and switching on Off Battery box, Motors and Cable well hidden to not change the looks LED light kit fits in (discount code included) will add Instructions to make your own adapter to power the light kit from the buwizz instead of a seperate battery polygons very close to the movie (not flat as LEGO did it) Multi language instructions: ►english ►deutsch ►italiano ►française ►español ►čeština ►русский The Partfinder: An Inventory of left over parts in all bags to find the without scrubbing through all bags while buildingfor building from scratch Buwizz Profile - my programming for the buwizz included. ★ Details 40° of steering angle with virtual pivot point to not rub against that narrow frame Driven by upgeared large motor No Batteries in the interior, it is still there. Hood is still opening. switch the car on and off and charge from below I added a fix for the gull wing doors to stay up. Also I took the liberty to change the colors of some red/orange/tan bricks that you could see when opening the doors. I will put the bricks needed into the spare parts of the inventory. No instructions for the lights included, but they come with the Light kit. AND: I bought all my light set from Game of Bricks. And (after talking to them) I can give you a discount for a light kit for any of my motorizations. The code is included in the downloads.
i just created some Lego battlebots maybe im hosting a little competition in Singapore during December holidays so far i have made a literal tank of a battlebot (brick on the floor with rotating cylinder) and it works decently here is it going against a smaller bot https://www.instagram.com/s/aGlnaGxpZ2h0OjE3OTYyNzUxNzczNzYxNjg4?igshid=MDJmNzVkMjY= thats the fight of 3 rounds also the smaller one got completely demolished lol
- 1 reply
- battlebots
- rc
(and 2 more)
Tagged with:
Hi everyone! This is my newest creation, a remote controlled minifig scaled monorail, which is not fast, not modern, not streamlined, but old, dirty and slow. Despite or because of these fact, I hope you like it! The video: Maybe you remember my RC STS crane (http://www.mocpages.com/moc.php/380083). The temperature was +1°C in that video, in this video it was +42°C! The bridge and the other things under the track contains approx 1000 bricks! On the last Malug meeting we made a bridge building competition and after that we got the bricks. What a cool thing, without them, the train destroyed the track. And an advice: if you build a monorail, don’t make the video in a rock-garden. Find a flat and horizontal table, and your life will be very comfortable! :D (to make the scenes with the bridge took more than 4 hours, I had to rebuild the whole track after every failed record) The Track looks simple, but it has to be strong and stable, because the train’s centre of gravity is in a high position. Of course the technic pieces are the best for it! The blue 2L pins are necessary. If we use only the small pins (with stud on one of its ends) the system part of the track can leave the technic part easily. Behind the windows: I found out the method I used, while I was building my RC Mercedes Citaro (http://www.mocpages.com/moc.php/349750). The main feature of this method is that the model has an only-technic module inside, and it is covered by system elements and walls. The inside modul is completely independent, it can work perfectly without the system parts. In my Mercedes I used this only at the driving mechanism. The main advantage of the construction is the stability. The technic pins and liftarms (built in three directions) are strong enough against the forces caused by motors and gear ratio (and crashes…). More pictures: http://www.mocpages.com/moc.php/392844
- 19 replies
