Showing results for tags 'removeable roof'.
https://sellfy.com/p/xuuhtq/ https://rebrickable.com/mocs/MOC-30506/Dugald_Lego/lego-technic-koenigsegg-regera-pdf-instructions/#comments https://youtu.be/FcyOmARJhdE Well the teardown of my Koenigsegg Regera is done, instructions are being tested and video is released. Huge thanks to my brother Lachlan Cameron for your amazing teardown photos and killer video edit. Thanks to Justin Wong for being the Guinea pig for the build and your patch notes along the way. Hey all, soo it's been a very long while since I've posted anything. Probably over two years now, however I have been busy in my spare time. For over two years now I've been working on the Koenigsegg Regera. By far my most challenging build to date, especially considering I've been working on Both and HOG and an RC at the same time. The HOG will be Dark Azure/Black centre with White accents and interior. So may I present to you the Regera, it's still a work in progress but everything is pretty well there. It's missing seats, stickers and a few things need adjusting but for the most part it's all there. This car will be on display at the Bricks in the Six Lego convention this weekend so I thought I'd share some early pictures before ones get taken and shared from the show. As always there will be a Video and instructions to follow. But first I need to get the HOG model finished as well. Either way here's some pictures a list of functions. The drivetrain is simple, on the RC it's just drive and steer, no gearbox as the real car is direct drive. 4 L motors for drive and one servo for steering, with a fake V8 in the back, the suspension is where it starts to get interesting, the rear is triplex suspension, unequal length control arms, with integrated sway bar like the real thing, the front is also unequal length suspension, cantalievered with torsion bar and sway bar, the front also raises and lowers a stud and when raising up flaps under the front valance deploy and tuck back up when the car lowers back down. The interior the seats slide and recline, the steering moves up and down in the centre console there's a lever which is a brand new concept which allows you to switch between opening, the left door, the right door, or both doors at the same time. Now when you're opening those doors which are Synchro dihedral the mirrors will fold in as the doors open out and upwards just like the real car. The front and rear clam shells will open as well and there's a lever in the back which will allow you to open the front, the back or both at the same time. On the rear clamshell is the rear wing which is on a cam that raises upward and outward and raises out of the back. The roof is removable like the real car, and can store underneath the front clamshell while still leaving enough room for a tote bag. There's also a manual and an RC model the manual model has two gears the dash the first is to open the doors, and the other to steer. The RC model has drive and steering that's hooked up to the fake V8, the doors and the clam shells are also motorized being able to switch between the front and rear or both at the same time. It also has LED lights front and rear. So overall this is a very in-depth detailed and accurate model in sense of functions.
- 144 replies
- koenigsegg
- regera
(and 6 more)
Tagged with:
