Showing results for tags 'scalawag sloop'.
She's done. It took a bit more time than I thought. I was a bit slow to get back to her after she missed out on BDP approval. But the new design is significantly better. Back angle. Much cleaner. Forgive the missing parts/mismatched colors. Here's the cloth conversion proof. Th square sail is unfortunately a custom (reasoning is below). The good news is that it is the same dimensions as the square sail from the Eldorado cutter. This means with some recoloring and a little crafting, you can easily convert it to a merchant or imperial vessel. Just about everything that bothered me about the build has been fixed except the following: 1) The brickbuilt gaff sail's connection has some stress and is likely illegal. To me, the simplicity of the design and the angle of the gaff are more important than a little stress on a technic 4 axle. 2) To get the sexy front hull curve without gaps on the outside, I needed to use jumper plates. so there's a little half step offset on the wall behind the ladders. There's probably a way of using some technic technique, but whatever, it's behind muskets, ladders, rigging, and similar color parts, nobody cares. 3) The front cannon has a stud that attaches into a round tile with technic hole. Illegal. 4) I wanted to get the part to lot ratio of 3:1. Couldn't get there. The double build and specialized ship parts killed the dream. Overall price is shockingly good. If you cut the dragon plume, muskets, swords, and make the cannon/swivel black you can hit 10 cents per part before shipping. 5) The curved up aft section. I love them, but it's a stupid number of plates and the bottom part (brown wedge and black wedge plate keel) doesn't attach well to the top part of the section (one 2x3 plate). Thankfully the rest of the attachment holds it into place. The build is solid. A kid could play with it. The back might get lose with rough play, but I'm not worried about a kid picking it up. You can pick the build up by the mast and it holds. but I wish it was more satisfying. 6) Some parts of the instructions need callouts instead of individual pages. Moving them, moved other things. I'm so tired of instructions. I left them in. 7) My original goal was to use a renegade runner style sail plan with no custom pieces, only the fore/aft sails from the Barracuda. There may not be a good way given how small they cut the gaff sail. The gaff is either comically low compared to the fore or ridiculously high compared to the stern. To make matters worse, the zip hoses TLC uses for rigging now are almost too long for this ship. Without a square sail, the rigging is way too high. This forced my hand, there needs to be a custom sail. Perhaps the saddest part is that the OG plan was to do a fore/aft for the sloop, then lengthen the hull and add a square sail for a bluecoat version. Now they'll look too similar. There you have it. She's done. More photos here. Instructions can be found on my rebrickable Thanks for your support! Let me know what you think!
Welp, here she is! Background: The Scalawag started as an attempt to get effective hull curves on a smaller frame, and I think I've nailed it. Originally, I had 1x6x3 1/3 (part 6060) arches for the front, but those weren't available for the BDP, but using round plates and tiles worked out. Some of my favorite pirate ships have been smaller form: the original Imperial Guard Flagship (6271), the Renegade Runner (6268), the Armada Flagship (6280). This was an attempt to make a ship that fused those with the smaller ship type from the IGTP and Eldorado. I also wanted a ship that could populate some of the harbors we have (Eldorado, Tortuga, and Barracuda Bay). Essentially, I wanted to "add" masts/sails to those ports. So the ship needed to be small enough to dock there without overwhelming the port. Speaking of Barracuda Bay, I wanted a sloop that can interact with the harbor. Not everyone could get 2 copies of it. One extra note: this ship should easily fit the gaff/jib PoBB sail if you want to go all cloth. And those are the easiest sails to leave out of the bay anyway. I tried to keep the overall aesthetic in line with TLC. I didn't want it to look like a crazy moc next to PoBB or Eldorado. Rudder is controllable from a tiller up top. Note the gentle upward slope of the stern. I don't think it's illegal, it was approved after all! The build is solid and stable, through and through. It should be playable, though the cannons can be a little weak. There will be stickers to add patches to the hammock piece. And yes a figure can sleep in the hammock with the stern deck in place! How would a pirate decorate his sleeping quarters? I don't think this one will be approved, but it's worth a shot! Here's a back-up incase the other is too racy! The build is pretty stable. I'm waiting on a bricklink order to confirm that the stays support the mast well enough, but the mast design was based on Lego's 3 in 1 Viking Ship, so the theory is sound. The curved hull is sturdy enough to allow figures to connect to it; it isn't overly fragile. Let me know what you think! And please vote here:
- 17 replies
- bricklink designer program
- lego pirates
- (and 5 more)
