Showing results for tags 'string actuator'.
Hello! I made some experiments nowadays, also this string operated actuator for heavy equipments: http://www.brickshelf.com/cgi-bin/gallery.cgi?f=534220 (this last picture is from another model, just shows the working method) The working pricniple is very simple and effective: the winch in the end of the housing (yellow) pulls out the liftarm construction (gray) with string(s). This isn't realistic, but think about TLC's actuators, they aren't also. I made it for heavy equipment, like crane booms, excavator arms, etc. For raising a big boom, pneumatic has no chance, Lego actuators also. There are two ways after that: custom actuators/custom pieces, or built actuators. I think string is "legal", it can be made also with Lego strings (but would be expensive), so it's 100% legal. The extension is 15 stud (can be a few studs more, but that would be in the "limit zone"). With longer construction it can be even 30 studs (more would cause deflection). I wanted to make it as small as possible, it's 3,8 studs wide, 3 tall. The length can be chosen freely (as long as you want - you just need longer liftarms, or more). The final version in my projects will have bley thin liftarms instead of these black ones, so it will be looking like a real cylinder from a distance. There is 4 paralell strings in this actuator, and at the beginning of the housing there is a little pulley to decrease friction ( http://www.brickshelf.com/gallery/mbmc137/Ideas-Technologies/Extrem-Cylinder/003.jpg ). Strings are very good for smart techniques, this actautor doesn't requires much additional space for motorizing, just make a gearing with a motor after the winch's axle. Of course, you can change the strength of the actuator with stronger/weaker strings. The one in the pictures can create about 100 N of pushing force. This is a bit more than a 10 kg vertical lifting. The backward movement is done by the gravity, but it's not impossible to modify it to pull back the inner part (you can add another string, like 8421's boom extension works). What do you think?
