Showing results for tags 'sugar beet harvester.'.
  • Search By Tags
  • Search By Author
    • Frontpage News
    • Forum Information and Help
    • General LEGO Discussion
  • Themes
    • LEGO Licensed
    • LEGO Star Wars
    • LEGO Historic Themes
    • LEGO Pirates
    • LEGO Sci-Fi
    • LEGO Town
    • LEGO Train Tech
    • LEGO Action Figures
    • Special LEGO Themes
  • Special Interests
    • The Military Section
    • Brick Flicks & Comics
    • LEGO Media and Gaming
  • Eurobricks Community
    • Hello! My name is...
    • LEGO Events and User Groups
    • Buy, Sell, Trade and Finds
    • Community
    • Culture & Multimedia
Find results in...
Find results that contain...
Date Created
  • Start
    End
Last Updated
  • Start
    End
Filter by number of...
  • Start
    End
Group
AIM
MSN
Website URL
ICQ
Yahoo
Jabber
Skype
Location
Interests
Country
Special Tags 1
Special Tags 2
Special Tags 3
Special Tags 4
Special Tags 5
Special Tags 6
Country flag
Found 1 result
  1. How much can you build a model? Finally, after 16 months (sic) I can show been working on for over a year. Holmer Terra Dos T3, because of him just mentioned is one of the most advanced agricultural machines created by man. Countless of hydraulic, pneumatic and electrical steel wrapped around a big red lump. Incredible machine and doing a great impression especially live. It all started three years ago when I wanted to build Ropa Euro Tiger, but it was soon after my return to the blocks and little that my arsenal of Lego was quite poor, that I did not have the proper knowledge to the construction, so the project died. Several months later, after the construction of Bizon Z056 started this model. I thought Bizon has set limits of my patience. But now I can honestly say that Holmer moved them about the whole hectares on :) For things. By the complexity of the colossus weighing nearly 6 kg construction dragged on to the limit. If it was clean Technic probably end up a lot faster. However, I have chosen a goal that was the best possible dedicated and working Model Team. Drive: At the beginning I was hoping that just enough one engine XL , because the model had to weigh 3.5 kg , however, it soon became apparent that if I wanted to Holmer move smoothly even when the ratio 1:12.6 need to throw in another engine. The rear axle drive is located in the backside of the machine tool and the front advancing the rollers inside the machine beets . With this theme , I struggled a little bit but it was the only optimal place that allowed to apply final drives and differential on the front axle . A combine harvester Weight is another major problem when it comes to the drive. The first problem was the torsion rear axle to which it was necessary to design a new final drives ( reworked design Mistekesa ) , which allowed to apply differential in the rear axle and keep the required scale of the width of the combine. The necessary because the roller bearing wheels on the front axle falls 2.4 kg and 3.5 kg for the rear . Here was a necessary need another idea . The point , of course, the wheel PP and their capacity. Normally, about 1 kg does impressions on them but more than 2 kg removes the tire from the rim , so to cure the rear tires had to push the tires of Unimog inside. Turning: The turn is carried out in several ways. Rear axle, bolted using a worm gear driven medium. This set is quite strong and can cope with the weight of the machine but generates quite a lot of backlash to the speed at which the machine moves are relatively small problem. The front axle is rigid but right behind her Holmer breaks through two small linear actuators driven medium. This works great and the speed is adjusted accordingly so that the engine does not have a problem with the change of the direction of travel of the combine. These two functions are independent of course hence the turning radius is about 1.3 m, and in addition the machine can move so. "Dog walk" which in practice means that the rear wheels do not move the tracks of the front wheels and combine like going from a slant. Mechanisms : Those in the model is a lot, can be divided into two groups: the cleaning section and unloading. To the first belong the spinning roller scraper beets to the throat , driven medium placed under the front axle , in principle, to this day I do not know what a miracle . Another who invent and build it took me half a year the cleaning turbines. None of the concept did not seem satisfactorily until the appearance of this . Each of them consists of 65 items and is probably the best dedicated part of the whole model. All are powered by a built- in medium frame with belts in accordance with the movement of the stars in the original. For elevator drive running around the reservoir responsible for the transport of beets into it. It consists of approximately 100 pieces and is driven together with the worm ; XL motor placed in the backside of the machine. The drive itself is guided to the sprocket drive shaft above the tank , which move the elevator. The next two mechanisms that raise and lower dischage elevator . Behind this activity is responsible for working medium with gear and toothed rack . This works very nicely and is virtually invisible, what I cared about . The tape drive motor is realized in the medium located in the backside . Tapes are connected by transmission and work at one time. Finally , the mechanism of the switch that turns the entire machine in time " digging " . Switch switches the motor on medium with ratchet . Also located in the rear of the machine Pictures: Gallery: Brickshelf: http://www.brickshel...ry.cgi?f=537787 Flickr: http://www.flickr.co...otos/eric_trax/ Well, the movie. It seems to me that the model deserves a better movie but no I'm not a movie director and went like this:
