Has been a while since I last showed some of my creations. I recently did an alternate model for the 42123 set with a special functionality and wondered if something like that could not also be done with the parts from 42093. And this is the result, the MDB attaccabrighe - an Italian fastback with gull-wing doors and a high-powered supercharged I4 engine (currently not fully color correct because of unavailable parts and also still WIP):
Now about the special functionality: It's engine is swappable! So far you can use an I3, a V6 and a V8 as replacement engine for the stock I4 engine (all engines also compatible with the AMX 4s). The original I4 of the AMX 4 Turbo and the original V5 of the AMX 4 Biturbo can't be used unmodified in the attaccabrighe though, as it's engine bay is 2 studs narrower than the one of the AMX 4s and the V5 also requires a different crank shaft. The engines are attached to either two axle holes or two pin holes.
The attaccabrighe will eventually be made available on Rebrickable and also receive a selection of aftermarket parts (like the ones for the AMX 4s) and maybe also some OEM modifications (e.g. wide rear wheels!)
Sports cars like the AMX 4s or the attaccabrighe of course also need an opponent apart from themselves. And there is one car that has enough potential to keep up with them - the MM Hammond Executive. More on that one later, for now just one picture showing a WIP model aside the attaccabrighe:
