Showing results for tags 'tow truck PFS technic'.
Hello everyone, I open this new topic to talk about my last Moc: a European towtruck 8X2 ... which has some special features;) That's the beast: http://imageshack.co...7705/Ulstoa.jpg Specifications? simple. -Make A truck, compact, with lots of features, playable. -A Reliable mechanical, without risk equipped with clutch (1) stop point, etc ... It is designed and destinated for my children -Make My son happy as a king when he spends hours with his friends towing everything imaginable I chose this scale for inventory reasons first, then because it's the scale that stuck best to the famous cars ta bo towned;) This Moc use 84 toothed parts (+/- 5 close;)), 4 driving rings , a single medium PFS motor and two sets of LEDs Motorized functions: -front winch -tilting cab Main crane: Lifting Main crane: extension Main crane: winch Rear stabilizers Secondary tow arm: lifting Secondary tow arm: lowering the towing plate -The Motor M drives the fake V4 engine via a differential -Leds Front and rear The manual features: -direction Via HOG on two axles with different angles -Opening doors -locking the Winch -fake engine connected to the rear wheels via two differentials, one for the axle itself, the other connected to the motor M (see below) The mechanical design is fairly standard in itself. The M motor drives the 4 gearboxes and the crown of the center differential itself connected to the fake engine. This design allows a rotation of the fake engine when the PFS is on, which is quite realistic. When you push the truck, the fake engine also rotates. There is no interaction between the two entries this means that rolling the truck is NOT powered. For the rest? Well lot of gears, Multiple intersections and not only axles! it had to go around linear actuators too! Finally? extra gameplay, an ultra fluid mechanics ( you can rotate the kinematic chain of each function from their arrival until the BV effortlessly by hand!) Two other photos waiting to get my good camera and .. the sun and a video that certainly brighten things;) http://imageshack.co...8197/g2nXPT.jpg http://imageshack.co...5432/ErF752.jpg
