Showing results for tags 'wheel hub'.
  • Search By Tags
  • Search By Author
    • Frontpage News
    • Forum Information and Help
    • General LEGO Discussion
  • Themes
    • LEGO Licensed
    • LEGO Star Wars
    • LEGO Historic Themes
    • LEGO Pirates
    • LEGO Sci-Fi
    • LEGO Town
    • LEGO Train Tech
    • LEGO Action Figures
    • Special LEGO Themes
  • Special Interests
    • The Military Section
    • Brick Flicks & Comics
    • LEGO Media and Gaming
  • Eurobricks Community
    • Hello! My name is...
    • LEGO Events and User Groups
    • Buy, Sell, Trade and Finds
    • Community
    • Culture & Multimedia
Find results in...
Find results that contain...
Date Created
  • Start
    End
Last Updated
  • Start
    End
Filter by number of...
  • Start
    End
Group
AIM
MSN
Website URL
ICQ
Yahoo
Jabber
Skype
Location
Interests
Country
Special Tags 1
Special Tags 2
Special Tags 3
Special Tags 4
Special Tags 5
Special Tags 6
Country flag
Found 1 result
  1. When you have ever built wheel hubs that use an axle to attach the wheel to - typically a 5.5L axle with end stop - then you must be familiar with the substantial slack such a connection is suffering from. If your wheel hubs have a more or less flat surface facing the wheel, like the wheel hub shown below, then it helps to fill the inside of the rim with 3 2L half beams, each attached to 2 3L axles, which are in turn inserted into the 6 pin holes of the rim. When the half beams are lowered deap enough into the wheel - you have to push them slidely away from the center of the rim to get them into place - and the 3L axles are inserted all the way into the half beams, the whole thing does not only make a tight fit, but also makes a nice flat surface together with the outer end of the axle hole of the rim. See images below. Now when you slide a belt wheel over the 3L axles on the other side of the rim, the whole thing is ready to slide over the axle coming out of the wheel hub. While doing so, make sure the 6 3L axles are not inserted further into the rim, as that would disturb the flat surface on the inside of the wheel. Slide the rim over the axle all the way. Finally, slide two extra half bushes to avoid the rim from sliding off the axle. Now the slack of the rim-axle-connection should be reduced by about 50%, while the rim rotates as smoothly as before. EDIT: I found out that using half bushes on the inside of the wheel makes an even better surface and reduces the chances on stuttering even further (I haven't experienced any stuttering sofar). The edges of the half bushes are slightly more smooth than the edges of the 2L thin liftarms that I used before. To anchor the setup I placed the three 2L liftarms on the outiside of the wheel. To finish the whole thing there are 2 options: Option 1 - For the ones living on the edge: Before sliding the rim onto the 5.5L axle, place a half bush right between the 3 short liftarms. You can't just push it into place; use an auxiliary axle to align the half bush with the rim and make sure the last part you put in place is one of the 6 3L axles. That should do the trick. This makes a tight finish (2nd image below). Option 2 - For the LEGO purists: After sliding the rim onto the 5.5L axle, place a half bush on the axle to lock up the 3 short lift arms. This makes a legal finish (3rd image below).
