I have these same tires on my 41999.... Much better than stock! Just wish they had been a tiny bit wider.
So in the end... Do you recommand those? Did you tried other brands?
@Mikuri
These tires are great as I said in the description I think. For $17 you can't pass them! And no I haven't tried any other tires. Being a student axial ripsaws, ansmaans and superswampers are quite expensive. I would prefer a lego set
Are these the same as advise on a thread Sariel started recently?
Yes, very close if not the same. Almost identical to RC4WD...
As I said on Sariel's thread, Just don't go for the 96mm version, 106mm ones are way better.
The rubber isn't as sticky as RC4WD, a quite noticeable difference in grip, but they are way better than anything Lego.
How is the grip between the tire and the rim - does it slip like those by LEGO? I hope that rubber bands are not necessary for those.
My 41999 will crawl right up the wall with these tires...I just wish would have know about the 106 mm before I purchased them. They are nice and soft. Night and Day from Lego tires
@MajklSpajkl
The grip is great, I have not noticed it slip in any situation!
