Jim Posted October 6, 2014 Posted October 6, 2014 MODEL TEAM VOTING TOPIC This topic will be used as a voting topic for the Model Team contest. VOTING RULES AND REGULATIONS Voting scheme uses the old Formula One style point distribution (10, 6, 4, 3, 2 and 1 POINT) You need to assign 10 points to the 1st place, 6 points to the second and so one. You need to vote for 6 ENTRIES (no more, no less) Clearly mention the ENTRY NUMBER and the NUMBER OF POINTS per entry that you vote on. If you joined Eurobricks after the start of the contest, you can be banned from voting (when vote rigging is suspected) You may NOT vote for your own entry. In the event of a tie for any place the Technic Staff will decide which entry wins. Our decision is final. Questions about voting can be asked in the Model Team Contest Information. For example (entries randomly chosen for example): --- comments can be placed above the votes 5: 10 (no comments here please) 6: 6 1: 4 9: 3 7: 2 3: 1 Or comments can be placed below the votes ---- NOTES Please use this exact notation NUMBER: VOTES (with a colon). Please use this thread only for voting. You may explain why you made your choice, but any general discussion should take place in the Model Team Contest Information Topic. Comments should be placed ABOVE or BELOW the votes. Please don't comment on the same line as the votes. VOTING CRITERIA The idea about this contest is to create a Model Team model which reflects the old school Model Team style using a modern approach. Indirectly this means you need to look at the following criteria: Design Functionality Color scheme Parts used Playability ENTRIES All entries can be found in the entry thread: Please visit the entry topic to see all entries. 1. 1980 Red Trans Am 2. Renault FT-17 Tank 3. James Bond Lotus Esprit 4. 1973 Renault 17 5. VW T1 Dragster 6. 1930s Ford Rat Rod 7. Ford Fiesta [MK6] ST150 8. Octan GT 9. Three-axle Compact Crane 10. Camper Tricycle 11. SMC Roadster Good luck!
Jim Posted October 6, 2014 Author Posted October 6, 2014 The bike is probably the most original build, but since the contest is Model Team, I feel that 3, 7 and 1 should be on the podium. 3: 10 7: 6 1: 4 8: 3 10: 2 6: 1
kinggregus Posted October 6, 2014 Posted October 6, 2014 Amazing Entries! 3: 10 2: 6 9: 4 8: 3 7: 2 1: 1
Mikuri Posted October 6, 2014 Posted October 6, 2014 (edited) 7 : 10 8 : 6 3 : 4 5 : 3 9 : 2 4 : 1 It was hard to decide @_@ Good job everyone! Edited October 6, 2014 by Mikuri
Erik Leppen Posted October 6, 2014 Posted October 6, 2014 So many great entries, it's hard to pick favorites here. Well done to all! 2: 10 3: 6 1: 4 11: 3 5: 2 6: 1
