  • Replies 5.1k
Posted Images
13 hours ago, astyanax said:
+O beam coming in red in 42153 NASCAR Next Gen Chevy Camaro, finally!
technic-q2-2023-wave-new-parts-42152-421
Also, 98989 is coming in Black in 42155 The Batman Batcycle.
Unfortunately no. Balasz's video shows the parts list, the +O beam in red it is not used.
You can also spot it at around 4:50 in the video.
I would like to use a flexible part to model the safety belt on a car's seat.
The part should start from the bottom left corner and connect to the axle hole in the top right corner.
Any suggestion?
Any suggestion?
I don't know if it would work here, but I used some motor cables to simulate that one time.
New part, it's like part 18677 but 1 module longer and without semi hollow studs:
Edited by SNIPE
Yesterday when building my 42155 I noticed that both 32198 gears were not completely straight when turning the axle. Before contacting CS I checked the gears I already had in my colkection and those where not straight as well. I don't think I am the only one who has this problem. The 42155 works fine so it is hard to notice the problem.
I also noticed it in my 42155, but it works and now when build is complete problem is no longer visible, so I don't bother.
Happened to me several times in the past. Very annoying in applications where low friction is crucial.
7 minutes ago, mpj said:
12t double bevel gears in dark bluish grey in set 75363
Not normal 12t. That is this part.
250x250p.jpg?1658333244.676594
And looks like still LBG I think?
Edited by msk6003
I wish TLG would update the mould of many of the windscreen pieces they've made and make more of them with pinholes to be "compatible" with technic pieces and models.
As a fan of Star Wars and starships and a primary Technic builder I've gotten into doing starships with technic parts and although there are many windscreen/canopy type pieces, I feel like many more of them should be made with pinholes in the back, like these:
https://www.bricklink.com/v2/catalog/catalogitem.page?P=45705#T=C
https://www.bricklink.com/v2/catalog/catalogitem.page?P=41881#T=C
Especially seeing as some of these bigger windshield pieces have a 1L thickness in the back regardless, I think they should be fitted with pinholes to make them more versatile.
Didn't know this part existed! Sorry
I'm afraid that wouldn't be possible in the near future regardless of the technology. My main concern is that it would either be milky (like in 42148), or a one-off piece, like the 1:8 supercar rims. And would block the accessibility of the interior. And last but no least it would break the consistency in looks of previous models
Found myself needing a rounded off clip version of the exoforce robot hand peice https://img.bricklink.com/ItemImage/PN/85/48729a.png
As the spikes on the end make it hard to put in smaller bar gaps at 90 degrees when this part fits perfectly https://img.bricklink.com/ItemImage/PN/3/11090.png
I prefer being purist but had to cut the stud end of this robot arm for my project. https://img.bricklink.com/ItemImage/PN/9/4735.png
It a bit loose but it works none the less. Though I wish lego made a purist form of it. (Wouldn't be that hard even)
Edited by Takanuinuva
For accessibility, I think the pinholes could be facing down so the windshield could be removed upwards if need be, to make it easier.
For the 2 pieces I linked, I have some of the first one and I use 2x of the "pin with pinhole" part inserted in the windshield and then attached to a liftarm with a 3L pin.
I don't use any studded bricks in the front to hold it closed and I've only used it for a few SW-inspired fighters, but I would like to have more options that could be attached with pins which I personally prefer.
In regards to the plastic and how the trans-clear panel appears to be kinda frosted, I have no idea why they did it that way. The windshield parts, even the ones that have pinholes, are clear and I can only assume it's a different type of plastic, maybe for strength reasons?
But the trans-clear/colored liftarms were all made with clear plastic AFAIK and they should be sturdy enough... but maybe it's different since they are made thicked due to being liftarms.
I created a small MOC which shows 8 ways to create half stud offsets using the following Technic parts:
Excluding thin liftarms and non contemporary parts, did I miss any parts you think?
