Jundis Posted May 23, 2023 Posted May 23, 2023 58 minutes ago, R0Sch said: I guess it's made of the same softer plastic, but based on my engineering judgement the weakest link is still the fragile chain clamp that now has to hold up against side forces too. I see very few use cases where this element might work besides some simple toyfair duck hunting game mechanism My thought exactly. This is a very, very specialized part. Could also maybe be used in some City sets for special conveyor belts or lifts. At least, there are multiple pieces of this type included. Hopefully also some spare parts :-) Quote
Davidz90 Posted May 23, 2023 Posted May 23, 2023 1 hour ago, R0Sch said: I see very few use cases where this element might work besides some simple toyfair duck hunting game mechanism. I guess it could be used to connect two chains side by side to make a thread. Also, it will be amazing for all sorts of mechanisms that use belts to encode something (mechanical calculators, calendar, all sorts of things that perform a sequence of motions/operations). Quote
1gor Posted May 23, 2023 Posted May 23, 2023 8 hours ago, kbalage said: Which is quite interesting as I couldn't find any sets with black versions, do you know where it came from? Honestly I bought them 15 years (or more ago) as I remember seller told me thst they were in one older set as alternative; some old sets like 851 had sometimes black 24 crown gears; maybe they were prototypes like onced black 4L differentials (that were on sale on bricklink at that time) 9 hours ago, Jundis said: Thanks for the link, Igor! Cool tractor, btw :-P Thanks buddy, STX steiger was long ago my favorite challenge, but it is only display model. Quote
astyanax Posted May 23, 2023 Posted May 23, 2023 2 hours ago, 1gor said: they were in one older set as alternative; Ah yes, in the same way, I have 4 of in Black, which came with 8880 Super Car when I bought it in 1994. But Rebrickable vehemently denies this part exists in Black... Quote
Glaysche Posted May 24, 2023 Posted May 24, 2023 This is some more detail about the new truss part from New Elementary: Quote
howitzer Posted May 24, 2023 Posted May 24, 2023 2 hours ago, Glaysche said: This is some more detail about the new truss part from New Elementary: Too bad there's not much analysis on the dimensions and angles of this new part. I wonder if the middle holes in the diagonal section are in any way in system or not. --- Apparently there's also 1x10 Technic Brick in DBG in the Ninjago City Markets, which should be new. Quote
Jockos Posted May 24, 2023 Posted May 24, 2023 (edited) 5 hours ago, howitzer said: Too bad there's not much analysis on the dimensions and angles of this new part. I wonder if the middle holes in the diagonal section are in any way in system or not. --- Apparently there's also 1x10 Technic Brick in DBG in the Ninjago City Markets, which should be new. Seeing the picture I think they are in system. 5M wide and 6M away from both ends. Edited May 24, 2023 by Jockos Quote
Philo Posted May 24, 2023 Posted May 24, 2023 Yes, on grid. Using some perspective corrections I come up with this: Quote
Jurss Posted May 24, 2023 Posted May 24, 2023 (edited) (may post could have been wrong) Edited May 24, 2023 by Jurss Quote
Philo Posted May 24, 2023 Posted May 24, 2023 1 minute ago, Jurss said: That is not Pythagoriam triangle. The diagonals don't have an integer length indeed. But the holes are on grid... Quote
gyenesvi Posted May 24, 2023 Posted May 24, 2023 On 5/23/2023 at 8:54 PM, astyanax said: Ah yes, in the same way, I have 4 of in Black, which came with 8880 Super Car when I bought it in 1994. But Rebrickable vehemently denies this part exists in Black... Interesting, my 8880 has these in grey. It's the towball pins that are black in there. Are you sure it came from that set? Or maybe there were different version wrt packaging? Do you have the instruction booklet? In which color does it list those parts? I don't have access to mine right now, but I do have it somewhere.. Quote
howitzer Posted May 24, 2023 Posted May 24, 2023 10 hours ago, Philo said: Yes, on grid. Using some perspective corrections I come up with this: That makes sense, thank you! Quote
SamS Posted May 25, 2023 Posted May 25, 2023 7 hours ago, gyenesvi said: Interesting, my 8880 has these in grey. It's the towball pins that are black in there. Are you sure it came from that set? Or maybe there were different version wrt packaging? Do you have the instruction booklet? In which color does it list those parts? I don't have access to mine right now, but I do have it somewhere.. Based on the Bricklink inventory's alternative parts, it looks like the pins with tow ball were replaced with black axles with tow ball in some variants of the set because in some the wheel hub holder had a pin hole, but others had an axle hole. That way the instructions could always show a black tow ball coming out of the hub holder. The sets with the black axle with tow ball also had some in light gray in other parts of the build. Quote
LvdH Posted May 25, 2023 Posted May 25, 2023 8880 came in two versions I believe. As mentioned above with the two different steering arms. One also had black 16t clutch gears. Quote
gyenesvi Posted May 25, 2023 Posted May 25, 2023 9 hours ago, SamS said: Based on the Bricklink inventory's alternative parts, it looks like the pins with tow ball were replaced with black axles with tow ball in some variants of the set because in some the wheel hub holder had a pin hole, but others had an axle hole. That way the instructions could always show a black tow ball coming out of the hub holder. The sets with the black axle with tow ball also had some in light gray in other parts of the build. 6 hours ago, LvdH said: 8880 came in two versions I believe. As mentioned above with the two different steering arms. One also had black 16t clutch gears. That's interesting to know, thanks! Quote
SNIPE Posted May 25, 2023 Posted May 25, 2023 (edited) hello edit: oops, I forgot that the 42152 fire plane also has red 7L flipflop beams. Edited May 25, 2023 by SNIPE Quote
Jockos Posted May 25, 2023 Posted May 25, 2023 Nice, red flip-flop beam! Curious if any of the summer sets will use it Quote
Erik Leppen Posted May 25, 2023 Posted May 25, 2023 (edited) The Perseverance set has the 7L flip flop in black, I thought. Somewhere in the suspension arms for the wheels. Edited May 25, 2023 by Erik Leppen Quote
LvdH Posted May 25, 2023 Posted May 25, 2023 1 hour ago, Erik Leppen said: The Perseverance set has the 7L flip flop in black, I thought. Somewhere in the suspension arms for the wheels. Correct. It shows 2 black 7L flip flop beams in the parts list. Quote
Ngoc Nguyen Posted May 26, 2023 Posted May 26, 2023 10 hours ago, Jockos said: Nice, red flip-flop beam! Curious if any of the summer sets will use it Red 7L flipflip beams appear in the Firefighting Aircraft already. Quote
Gray Gear Posted May 26, 2023 Posted May 26, 2023 Does anyone have experience with this part: I am especially interested how much play there is in the Gray gear axle (up/down/left/right), and if it is possible to push an axle through all the way or not. I'd like to use this as the only mounting point and I am Wondering if it is suitable. Quote
astyanax Posted May 26, 2023 Posted May 26, 2023 On 5/24/2023 at 9:54 PM, gyenesvi said: Interesting, my 8880 has these in grey. It's the towball pins that are black in there. Are you sure it came from that set? Or maybe there were different version wrt packaging? Do you have the instruction booklet? In which color does it list those parts? I don't have access to mine right now, but I do have it somewhere.. Finally I was able to dig up my old building instructions. They came with an additional loose 2-sided page to 'correct' steps 18 and 19. Specifically, the White wheel hubs are replaced by Light Gray ones, and the Light Gray towball-axles are replaced by Black ones. I do not know the reason for these replacements. Perhaps there was a weakness in the White wheel hubs. To be clear: my set 8880 contained all parts for either step 18. Following the corrected step 18, I was left at the end with 4 White wheel hubs and 4 Light Gray towball-axles. The new step 19 only contains some clarifications: Quote
aeh5040 Posted May 26, 2023 Posted May 26, 2023 (edited) On 5/24/2023 at 1:06 PM, Philo said: Yes, on grid. Using some perspective corrections I come up with this: From the pictures of 42157 it looks as if the distance between the holes is 5 *along the diagonal* because there is an alternating liftarm running along there, so that they would not be in-grid. It would be pretty difficult to distinguish 5 and sqrt(5*5+1*1)=5.1 from the picture. Edited May 26, 2023 by aeh5040 Quote
Erik Leppen Posted May 27, 2023 Posted May 27, 2023 That 11L liftarm is connected at only 1 end and held in place by a half pin. So it's really sqrt(26). That would make sense, because the holes are then all in grid. Quote
