JLiu15 Posted August 21, 2023 Posted August 21, 2023 On 8/16/2023 at 8:19 AM, 1gor said: That would be very kind I remember that you made offroader with multiple steering modes and Claas tires on Defender wheels in black (but without dish) with planetary reduction hubs Thank you I actually went with regular Racing Medium rims in the end for that MOC. Quote
howitzer Posted August 21, 2023 Posted August 21, 2023 New Elementary did some analysis on the new worm gear and it's mating parts, including a way to drive the worm gear with normal gears: https://www.newelementary.com/2023/08/lego-parts-73763-73764-3863-worm-gear.html Quote
apachaihapachai Posted August 21, 2023 Posted August 21, 2023 Made a custom wheel hub to use Wheel 20 x 30 Balloon Medium (6582) with the WPL RC tires. You need to open up Technic Steering Wheel Hub with Planetary Gear Reduction (46490) and cut Technic Bush 1/2 Smooth with Axle Hole Semi-Reduced (32123). Works surprisingly well. Also avaliable in .io format here Quote
1gor Posted August 21, 2023 Posted August 21, 2023 4 hours ago, JLiu15 said: I actually went with regular Racing Medium rims in the end for that MOC. I'll probably also use regular wheels because Defender wheels are really expensive...but everything when time is right Quote
Aleh Posted August 21, 2023 Posted August 21, 2023 Don't know where to ask better. I have PS5 controller and Liebherr LR set, have Brick COntroller2 app. How to adjust all this? Any tutorial would be appreciated! Quote
Aleh Posted August 21, 2023 Posted August 21, 2023 Another separate question:I need some help and advice. I need to build two lego train rounds, not ovals, rounds! We can use 16 of this track https://rebrickable.com/parts/53400/vehicle-track-train-plastic-rc-trains-curved/ and will get a round of 68cm diameter, but a need a bit larger. Let's say 80 cm. Any ideas? Should be compatible with axles on these wheels https://rebrickable.com/parts/57999/train-wheel-spoked-with-technic-axle-hole-and-rubber-friction-band/ Quote
Zerobricks Posted August 21, 2023 Posted August 21, 2023 1 hour ago, Aleh said: Don't know where to ask better. I have PS5 controller and Liebherr LR set, have Brick COntroller2 app. How to adjust all this? Any tutorial would be appreciated! I recommend asking in Brickcontroller2 topic. 20 minutes ago, Aleh said: Another separate question:I need some help and advice. I need to build two lego train rounds, not ovals, rounds! We can use 16 of this track https://rebrickable.com/parts/53400/vehicle-track-train-plastic-rc-trains-curved/ and will get a round of 68cm diameter, but a need a bit larger. Let's say 80 cm. Any ideas? Should be compatible with axles on these wheels https://rebrickable.com/parts/57999/train-wheel-spoked-with-technic-axle-hole-and-rubber-friction-band/ Maybe ask in train subforum? Quote
Aleh Posted August 21, 2023 Posted August 21, 2023 38 minutes ago, Zerobricks said: I recommend asking in Brickcontroller2 topic. Maybe ask in train subforum? Didn't assume such topic exists. And I asked in train topic too. Thanks Quote
2GodBDGlory Posted August 21, 2023 Posted August 21, 2023 6 hours ago, apachaihapachai said: Made a custom wheel hub to use Wheel 20 x 30 Balloon Medium (6582) with the WPL RC tires. You need to open up Technic Steering Wheel Hub with Planetary Gear Reduction (46490) and cut Technic Bush 1/2 Smooth with Axle Hole Semi-Reduced (32123). Works surprisingly well. Also avaliable in .io format here Neat concept! Is the cut half-bush going inside the hub? If so, by using the old, toothed variant of it, you could get the CV joint a little closer to where it needs to be without cutting anything, because on it the axle-hole portion of it doesn't go the full length, so it can overhang the rounded part of the CV joint axle. FYI, if you buy generic planetary hubs from AliExpress, they come unglued, so they could be used as an easier (and cheaper) basis for this project, since you don't need to cut them open. Quote
apachaihapachai Posted August 21, 2023 Posted August 21, 2023 8 minutes ago, 2GodBDGlory said: Neat concept! Thanks! 8 minutes ago, 2GodBDGlory said: using the old, toothed variant of it Too bad I got 0 of them :D 8 minutes ago, 2GodBDGlory said: FYI, if you buy generic planetary hubs from AliExpress I actually used exactly these chinese hubs. Lego ones are too expensive to destroy for sure. Quote
gyenesvi Posted August 21, 2023 Posted August 21, 2023 14 hours ago, apachaihapachai said: Made a custom wheel hub to use Wheel 20 x 30 Balloon Medium (6582) with the WPL RC tires. You need to open up Technic Steering Wheel Hub with Planetary Gear Reduction (46490) and cut Technic Bush 1/2 Smooth with Axle Hole Semi-Reduced (32123). Works surprisingly well. This sounds interesting, but I don't quite understand what is happening here. I understand that the goal is to use the hub with an axle, instead of a 3 pin wheel mount. But do you keep the planetary reduction or do you throw that away? Does the pivot point of the CV joint fall exactly where it is on the original hub? What is the purpose of that cut bush? Also, in the video in the RB model, you seem to be using it with a 3-pin connected wheel hub, instead of what is shown here.. Quote
apachaihapachai Posted August 22, 2023 Posted August 22, 2023 7 hours ago, gyenesvi said: I understand that the goal is to use the hub with an axle, instead of a 3 pin wheel mount. The goal is to create a hub with the axle connection. 7 hours ago, gyenesvi said: But do you keep the planetary reduction or do you throw that away? The reduction is gone, yes 7 hours ago, gyenesvi said: Does the pivot point of the CV joint fall exactly where it is on the original hub? Yes 7 hours ago, gyenesvi said: What is the purpose of that cut bush? To better secure the CV joint in the correct place. Quote
apachaihapachai Posted August 22, 2023 Posted August 22, 2023 7 hours ago, gyenesvi said: Also, in the video in the RB model, you seem to be using it with a 3-pin connected wheel hub, instead of what is shown here.. Relevant video Quote
gyenesvi Posted August 22, 2023 Posted August 22, 2023 Thanks for the video link. 2 hours ago, apachaihapachai said: To better secure the CV joint in the correct place. I think I roughly get it's construction now. So the bush is inside the hub behind the black disk? What is holding the CV joint/axle and the black disk from sliding outwards together with the whole wheel? Is there a disk inside as well, or just outside of the hub's rim? Furthermore, on your image above, I can see some kind of a spacer on the red 2L axle that comes out of the CV joint's male part. What/why is that? If the CV joint's head is in the same position as in the original planetary hub, than that no spacer would be required there (assuming the rest of the construction is normally positioned parallel with the A-arms). Quote
apachaihapachai Posted August 22, 2023 Posted August 22, 2023 47 minutes ago, gyenesvi said: Thanks for the video link. I think I roughly get it's construction now. 48 minutes ago, gyenesvi said: I can see some kind of a spacer on the red 2L axle that comes out of the CV joint's male part. What/why is that? If the CV joint's head is in the same position as in the original planetary hub, than that no spacer would be required there (assuming the rest of the construction is normally positioned parallel with the A-arms). The drive shaft isn't parallel with the arms in my particullar case. That's why I'm using spacers on the 2L axle. You are right. When the shaft is normally positioned the spacers won't be neccesarry. Quote
gyenesvi Posted August 22, 2023 Posted August 22, 2023 (edited) 44 minutes ago, apachaihapachai said: The drive shaft isn't parallel with the arms in my particullar case. That's why I'm using spacers on the 2L axle. You are right. When the shaft is normally positioned the spacers won't be neccesarry. Thanks for the explanation, I get it all now! Nice construction. One more question, what is the advantage of the axle based solution for you? From the model itself, as originally built with the old wheel hubs, it seems that the same RC tire (is it the same?) can be used with the 43mm Arocs wheels (as your video shows on RB). Furthermore, to work with the new CV joints, this whole custom made hub could just be replaced with the new non-planetary wheel hubs from the Audi, right? BTW, I like the tires you are using. Do they fit the Arocs wheels well? What is their diameter/width? Do you have a link to them? Edited August 22, 2023 by gyenesvi Quote
apachaihapachai Posted August 22, 2023 Posted August 22, 2023 (edited) 30 minutes ago, gyenesvi said: One more question, what is the advantage of the axle based solution for you? Just to use Wheel 20 x 30 Balloon Medium (6582). Because of the stem inside the deep part you can't efficiently use them with standart 3-pin hubs. Why exactly these old rims? Because of the much better fitment of the RC tires and better proportions for the wheel as a whole. 30 minutes ago, gyenesvi said: to work with the new CV joints, this whole custom made hub could just be replaced with the new non-planetary wheel hubs from the Audi, right? If you want to use the 43mm Arocs wheels then sure. 30 minutes ago, gyenesvi said: BTW, I like the tires you are using. Do they fit the Arocs wheels well? What is their diameter? Do you have a link to them? Just google WPL tires. They are very cheap ~68mm chinese tires. You can find them in wide variety of the tire treads. As mentioned above you can fit them on 43mm Arocs wheels but the tire will be slightly deformed. TBH there are a lot of options if you want to use RC tires. Edited August 22, 2023 by apachaihapachai Quote
gyenesvi Posted August 22, 2023 Posted August 22, 2023 11 minutes ago, apachaihapachai said: Just to use Wheel 20 x 30 Balloon Medium (6582). Because of the stem inside the deep part you can't efficiently use them with standart 3-pin hubs. Why exactly these old rims? Because of the much better fitment of the RC tires and better proportions for the wheel as a whole. Thanks for explanation, that makes sense. 11 minutes ago, apachaihapachai said: Just google WPL tires. They are very cheap ~68mm chinese tires. You can find them in wide variety of the tire treads. As mentioned above you can fit them on 43mm Arocs wheels but the tire will be slightly deformed. Found some, thanks :) 11 minutes ago, apachaihapachai said: TBH there are a lot of options if you want to use RC tires. I know, I have a bunch already :) Quote
Ngoc Nguyen Posted August 24, 2023 Posted August 24, 2023 Is there a way to keep the 2x3 Tile with clip in place? I'm using a bar with clip but it looks like it's an illegal connection. Quote
howitzer Posted August 24, 2023 Posted August 24, 2023 GBC people will be delighted to know that there's a new neon yellow ball available now in the new Friends Sports Center set: Quote
Ngoc Nguyen Posted September 1, 2023 Posted September 1, 2023 I opened my first 1:5 Technic motorbike today and the tires make me feel like Shangchi lol Quote
1gor Posted September 1, 2023 Posted September 1, 2023 7 minutes ago, Ngoc Nguyen said: I opened my first 1:5 Technic motorbike today and the tires make me feel like Shangchi lol Why, set(s) has only 2 (driving) rings; not 10 ...and only 2 tires... Quote
R0Sch Posted September 5, 2023 Posted September 5, 2023 There are some new Technic parts available as of September on B&P from the LR and Peugeot: Quote
SaperPL Posted September 7, 2023 Posted September 7, 2023 I noticed a little detail about 71708 part - put 15100 (pin with pin hole) into the pin hole on the shorter edge of 71708. Try to turn the pin around. When inserted from one side, it's like snapping in place for every 90 degree rotations inside the pin hole, but only from one side of the 71708, on the other side it's either weaker or non existent. I checked it through few of those 71708 and all have it, but not always on the same side. There's no visible difference of that pin hole from the others. I wonder if someone else can confirm this on his pieces. Quote
astyanax Posted September 7, 2023 Posted September 7, 2023 58 minutes ago, SaperPL said: I noticed a little detail about 71708 part - put 15100 (pin with pin hole) into the pin hole on the shorter edge of 71708. Try to turn the pin around. When inserted from one side, it's like snapping in place for every 90 degree rotations inside the pin hole, but only from one side of the 71708, on the other side it's either weaker or non existent. I checked it through few of those 71708 and all have it, but not always on the same side. There's no visible difference of that pin hole from the others. I wonder if someone else can confirm this on his pieces. I tried with part 15100, which is the old mold and has very high friction. Indeed there seems to be some 'snapping' feeling when rotation it in a pinhole -- not just in part 71708, although it's stronger there (maybe because 71708 is made from different plastic). Quote
