R0Sch Posted April 4, 2024 Posted April 4, 2024 Sadly not many new Technic parts got added to PaB since my last parts update in November 2023. Nothing from the January sets. :( Quote
SNIPE Posted April 11, 2024 Posted April 11, 2024 I got 2 of 3803 recently and they are one of the most impressive parts ive seen in a while, only downside is that 2L axle pins dont fit over the bars all the way which makes them "out of system" however, system pieces, axle holes, and pin bar holes fit over the 4 bars just fine while staying in system and the pinhole is just awesome for making custom connectors Quote
Erik Leppen Posted April 12, 2024 Posted April 12, 2024 For people that don't know all part numbers by heart: @SNIPE is talking about this: Quote
R0Sch Posted April 16, 2024 Posted April 16, 2024 There is a blogpost on Stonewars that shows a couple of interesting new Technic elements that have approved/pending patent applications by LEGO and are most likely to appear in future sets. Below are the interesting bits for this theme. The 3x3 macaroni piece is already available in 2 colors in the upcoming Dreamzzz sets. Quote
Jockos Posted April 16, 2024 Posted April 16, 2024 Wow, thanks for the info! They all look interesting. I guess the macaroni piece would be mostly suitable for decorations in Technic sets, and the green ones for City cranes. From the remaining 3 I can't imagine what the middle one would be useful for. Quote
1gor Posted April 16, 2024 Posted April 16, 2024 Those parts in upper line (small and in white) are very very usefull. Now let's hope they will be in black Quote
jovel Posted April 16, 2024 Posted April 16, 2024 Is there something that should fit into that green thing? Quote
Jim Posted April 16, 2024 Posted April 16, 2024 3 minutes ago, jovel said: Is there something that should fit into that green thing? Exactly my thoughts. Was wondering the same thing. Quote
2GodBDGlory Posted April 16, 2024 Posted April 16, 2024 Ooh, cool! The 3x13 frame could be handy, but the one I'm most interested in is the axle with pinhole connector in the top right! I feel like that's a part I've wanted many times 2 hours ago, jovel said: Is there something that should fit into that green thing? The original article suggests that this part could be used with it, for some kind of gear drive from below:https://www.stonewars.de/wp-content/uploads/2024/04/LEGO-neue-teile-anmeldungen-02.jpg Quote
Stereo Posted April 16, 2024 Posted April 16, 2024 (edited) 73763 worm gear has the same 1 stud spacing of teeth, and would fit neatly in the 6 stud gap of the 8 stud long frame piece. So it'd be a very easy to build crane arm, you run axles through the center hole until the end section where there's a worm gear. The 6x13 diagonal I suppose could be used to brace frames at a larger scale? Lots of sets use the 3x5 L beam and 5x9 (32009) beam to keep things square, this is another option to do that, the actual 5x8 diagonal it represents doesn't seem like a special triangle to me. It's not a pythagorean triple, 4x8 would have matched up with wedge plates but I don't think this does. The existing 2637 16 long link I suppose can only do the 9-12-15 triple so maybe this fills a gap in diagonal lengths, between the 6-4 bent liftarm (which does 3-4-5) and 16 link. Edited April 16, 2024 by Stereo Quote
SNIPE Posted April 16, 2024 Posted April 16, 2024 (edited) the pinhole with axle 3 will be a game changer, 2L friction pin with bar hole would have been better but oh well Edited April 16, 2024 by SNIPE Quote
Thirdwigg Posted April 16, 2024 Posted April 16, 2024 51 minutes ago, SNIPE said: the pinhole with axle 3 will be a game changer, 2L friction pin with bar hole would have been better but oh well Game changer? How so? It's an interesting part no doubt, and I can see application, but I cannot yet imagine a use that could not have been done using other parts? Quote
gyenesvi Posted April 16, 2024 Posted April 16, 2024 6 minutes ago, Thirdwigg said: Game changer? How so? It's an interesting part no doubt, and I can see application, but I cannot yet imagine a use that could not have been done using other parts? I do sometimes (frequently) find myself in need for a pinhole with a 2L axle or a 2L pin. But not so much a 3L axle yet.. So probably better than nothig, but not as good as if things were systematic and progressing in proper steps. I wonder though if these are only templates, and the actual patents cover a family of parts in different sizes, instead of just exactly one size. Patents tend to be as generic as possible. The 3x13 frame does definitely seem useful for smaller models where the 3x19 is too long to fit. The diagonal thing is also interesting, but seems large at first sight. Quote
SNIPE Posted April 16, 2024 Posted April 16, 2024 (edited) I think the diagonal thing will be too bendy to make much difference... also diagonals waste a lot of space but Yeah, I meant that I will use it like a 2L pin with pinhole (but with axle at least 1 axle hole Here is why this 3L axle part will be awesome: normally to attach a mini turn table to a 5x7 frame you use 2 3L axles going thru the turn tables 2 pinholes and then you use purpendicular axle connectors along with 4 vertical 3L axles to clamp it all in place , but you dont have any room for other stuff so bummer. With this part you still have 1L of free axle space on either side of the turntables pinhole, how AMAZING IS THAT¡¿!?¡¿!?¡¿!?¡¿!! Edited April 17, 2024 by SNIPE Quote
SNIPE Posted April 17, 2024 Posted April 17, 2024 OK here is what I mean: I kinda was able to replicate the new parts using shock 6L absorber ends with a few caveats: Quote
gyenesvi Posted April 17, 2024 Posted April 17, 2024 And what would that contraption be useful for? I guess you can always find a usage that requires a specific part, sure. But I guess probably it would be easier to find more uses for a pinhole with 2L axle. If we call a connection that connects two things in whatever way a basic connection (most existing connectors are like that), then the next logical class off connectors is one that merges two basic connectors into one. And in this case, that would be one unit longer axle or pin on the pinhole. Quote
SNIPE Posted April 23, 2024 Posted April 23, 2024 (edited) 8 hours ago, JTS said: Does anybody know if 35189 fits into 32495? it fits but doesnt stay in Funnily enough, in 2011 I was the first person to think of using just the outside hub so I had no choice but to break the inner hub in order to remove it then again for another one so I had 2 for the front wheels. I then put the subpart on bricklink after admin approval. I wanted to put 3L UV joints in it, which worked but the whole thing was very flimsy. Now, technic has evolved much more thankfully. Edited April 23, 2024 by SNIPE Quote
The Shuttlefan Posted April 23, 2024 Posted April 23, 2024 PSA: 40747 Daffodils contains a whopping 56 of Axle 2M in Black for just £12.99! There are also 28 in 40725 Cherry Blossoms for the same price. Quote
R0Sch Posted April 23, 2024 Posted April 23, 2024 4 minutes ago, The Shuttlefan said: PSA: 40747 Daffodils contains a whopping 56 of Axle 2M in Black for just £12.99! There are also 28 in 40725 Cherry Blossoms for the same price. The Dune Ornithopter also uses 48x 2M axles in black but for some reason they had to add 31x in red too just to add a little color for the fans. Quote
R0Sch Posted April 24, 2024 Posted April 24, 2024 The Minions Mansion will include a bright light orange pneumatic hose. The buildable Gru brings for the first time a light nougat Bionicle eye and 71479 the same part in dark blue. That 3x3 macaroni elbow element already comes in 4 different colors in Dreamzzz. Quote
jovel Posted April 28, 2024 Posted April 28, 2024 On 4/16/2024 at 12:37 PM, R0Sch said: There is a blogpost on Stonewars that shows a couple of interesting new Technic elements that have approved/pending patent applications by LEGO and are most likely to appear in future sets. Below are the interesting bits for this theme. The 3x3 macaroni piece is already available in 2 colors in the upcoming Dreamzzz sets. I think that part in the top right corner is in a new orange city excavator. Quote
Zerobricks Posted April 28, 2024 Posted April 28, 2024 1 hour ago, jovel said: I think that part in the top right corner is in a new orange city excavator. Looking at the leaked photo, it does indeed look something like that, but it looks a bit thin for an axle...Maybe it's a 3,2mm bar? Either way it's still very useful! Quote
Zerobricks Posted April 29, 2024 Posted April 29, 2024 On 4/28/2024 at 6:40 PM, jovel said: I think that part in the top right corner is in a new orange city excavator. You were right Another very useful part! Quote
R0Sch Posted April 30, 2024 Posted April 30, 2024 (edited) New Technic parts. Unfortunately the 45° knob gear is out of stock. But here's your chance to stock up on yellow Z28 and banana gears. :) P.S. That 3M cross axle connector is Neon Yellow and only used once in 60414 City Fire Station. P.P.S. For reasons unknown to mankind, Technic bricks and some rims are not listed under the Technic category lol. The dark blue 12L brick and blue 56904 rims from the buggy are also available. Edited April 30, 2024 by R0Sch Quote
