doug72 Posted May 12, 2017 Posted May 12, 2017 (edited) Re LEGO Large Tread Link (57518 / 88323 / 89501) As part of the BCE build of my I need a short section of bucket chain to bend for approx 60 degs the other way to normal. My first attempt used the grey large track links from the BWE set and it proved impossible to bend it as much as I required.Then tried the black large tread links and found they can bend backwards to a smaller diameter. Not sure if this is due to wear or not, anyone else noticed this. I have seen several GBC that use these links in this manner. Both tread link types shown in photo are bent backwards as far as possible without straining them. Edited May 12, 2017 by Doug72 Quote
Philo Posted May 12, 2017 Posted May 12, 2017 The newer links have small tabs that prevent backwards bending. If you want small diameter you have to choose older parts. Unfortunately the transition time between versions is not clear... Quote
doug72 Posted May 12, 2017 Posted May 12, 2017 15 minutes ago, Philo said: The newer links have small tabs that prevent backwards bending. If you want small diameter you have to choose older parts. Unfortunately the transition time between versions is not clear... Thanks for that explanation - I shall have to hunt through my Lego to see if have enough parts or come up with another solution to the problem. Quote
Richard Dower Posted June 9, 2017 Posted June 9, 2017 Have any new parts or recolours surfaced?....i recently bought some 1x5 thin liftarms in White, they are pretty rare: https://www.bricklink.com/catalogItemIn.asp?P=32017&colorID=1&in=A Quote
Saberwing40k Posted June 10, 2017 Posted June 10, 2017 I looked up the inventory for 75532, which @Jeroen Ottens posted a picture of, and I found some interesting recolors. Of note is the fact that Lego included both yellow and gray 3L axles, for no reason. Also, the pinhole with axle is included in two colors as well, again for no reason. Since I'm on my phone, photos will have to do, as finding and linking all new parts would be a pain. Quote
TechnicRCRacer Posted June 10, 2017 Posted June 10, 2017 (edited) That set will be mine soon enough. Thanks for sharing! Edited June 10, 2017 by TechnicRCRacer Quote
Aventador2004 Posted June 10, 2017 Posted June 10, 2017 4 hours ago, LvdH said: The DBG #2 connector is somewhat rare on bricklink. https://www.bricklink.com/catalogPG.asp?P=32034&colorID=85 I have a large pile of them, so I am all set. Quote
Leewan Posted June 10, 2017 Posted June 10, 2017 13 hours ago, Saberwing40k said: Since I'm on my phone, photos will have to do, as finding and linking all new parts would be a pain. Here they are : Bag 1 : Bag 2 : Bag 3 : And the pinhole with axle actually comes in three colours in this set : light bley, dark bley and dark brown, but it's not for no reason. Quote
Immo Posted June 10, 2017 Posted June 10, 2017 On 8.05.2017 at 0:15 PM, Erik Leppen said: The brown panels look very interesting to me. Brown is a very unusual color, I would like to have it, even though I have no idea what for yet. 1 hour ago, Leewan said: Here they are : (...) And the pinhole with axle actually comes in three colours in this set : light bley, dark bley and dark brown, but it's not for no reason. So many brown bits! For me, they scream RAT ROD, but then again, even a cold three day sandwich in my fridge screams HOT ROD to my obsessed mind Quote
AkiyamaWataru Posted June 11, 2017 Posted June 11, 2017 I just bought some 2017 and 2016 sets and I am wondering with parts are new? I know of a few like a pinhole with axle and pinhole with 2 axles. But I would like to know if there is a list for these parts. Quote
Saberwing40k Posted June 11, 2017 Posted June 11, 2017 On 6/10/2017 at 9:09 AM, Leewan said: And the pinhole with axle actually comes in three colours in this set : light bley, dark bley and dark brown, but it's not for no reason. U wot M8? I can see the differing grays, but not the dark brown. It's a completely different color than the other brown parts, and also is not visible in the finished model. Also, they're not new in dark brown in this set, they first appeared in dark brown in 42066, and that inclusion was truly inexplicable. Quote
Richard Dower Posted June 11, 2017 Posted June 11, 2017 I also recently bought some ribbed hoses in 14L length in Black, there was a Star Wars set from 2016 that had them.....some old Technic sets such as 8285 used them, so if you want brand new parts or replacements they are available now: https://www.bricklink.com/catalogItemIn.asp?P=78c14&colorID=11&in=A 1 hour ago, Saberwing40k said: U wot M8? I can see the differing grays, but not the dark brown. It's a completely different color than the other brown parts, and also is not visible in the finished model. Also, they're not new in dark brown in this set, they first appeared in dark brown in 42066, and that inclusion was truly inexplicable. Exactly....they should have used Red or LBG.....WTH would they used Brown for a Technic part? Quote
Leewan Posted June 12, 2017 Posted June 12, 2017 18 hours ago, Saberwing40k said: U wot M8? I can see the differing grays, but not the dark brown. It's a completely different color than the other brown parts, and also is not visible in the finished model. Also, they're not new in dark brown in this set, they first appeared in dark brown in 42066, and that inclusion was truly inexplicable. Top of the second picture you posted, above the trans-red parts. There are only two of them, they're used to attach some panels, so they're indeed nearly invisible. And, FYI, they actually first appeared in 2016. (: Quote
Zerobricks Posted June 12, 2017 Posted June 12, 2017 Anyone else spots a new showel design? Image taken from brickset: https://brickset.com/article/28139/review-70915-two-face-double-demolition Quote
zux Posted June 12, 2017 Posted June 12, 2017 (edited) 20 minutes ago, Zero (Zblj) said: Anyone else spots a new showel design? That's the same piece found in 42061, just DBG. Edited June 12, 2017 by zux Quote
Zerobricks Posted June 12, 2017 Posted June 12, 2017 Just now, zux said: That's the same piece found in 42061, just DBG. Oh, forgot about that set, my bad. Quote
Saberwing40k Posted June 12, 2017 Posted June 12, 2017 5 hours ago, Leewan said: Top of the second picture you posted, above the trans-red parts. There are only two of them, they're used to attach some panels, so they're indeed nearly invisible. And, FYI, they actually first appeared in 2016. (: Oh, okay. Nevertheless. What I meant was I can see a reason for the other colors , but not the dark brown. I know where they are in the inventory. Quote
Leewan Posted June 12, 2017 Posted June 12, 2017 Oh, I understand. Yeah, a pair of dark bley pinholes with axle could have been used instead, especially since they're right next to dark bley 42003's. If the 3L perpendicular connectors were reddish brown rather than dark bley, a brown pinhole with axle would have made sense, but in the present case, it seems a bit random, just like the differently coloured 3 and 4 axles (although it might be because they're in different bags, so it would rather be due to the production process). Quote
Richard Dower Posted June 12, 2017 Posted June 12, 2017 1 hour ago, zux said: That's the same piece found in 42061, just DBG. Yes, i belive i commented on, and pointed out said part several pages back. But i said it was LGB. It is still a new mold design internally. 20 minutes ago, Leewan said: Oh, I understand. Yeah, a pair of dark bley pinholes with axle could have been used instead, especially since they're right next to dark bley 42003's. If the 3L perpendicular connectors were reddish brown rather than dark bley, a brown pinhole with axle would have made sense, but in the present case, it seems a bit random, just like the differently coloured 3 and 4 axles (although it might be because they're in different bags, so it would rather be due to the production process). Um...note to TLG....can we PLEASE just get this part in Black ffs!...thanks. Quote
bonox Posted June 13, 2017 Posted June 13, 2017 hell, it's way better than the blue of the basic 3L pin. I'd be clamouring for that first! Quote
ColletArrow Posted June 13, 2017 Posted June 13, 2017 9 hours ago, Richard Dower said: Um...note to TLG....can we PLEASE just get this part in Black ffs!...thanks. I'm afraid that won't happen, as the very similar 18651 (Axle Pin 3L with Friction Ridges Lengthwise and 2L Axle) exists solely in black. TLG's colour-coding policy means that we will never get two so similar parts in the same colour; at least they're both dark tones, not bright yellow or something. Quote
Ivan_M Posted June 16, 2017 Posted June 16, 2017 Full inventory of 75532 Scout trooper is available at BL: https://www.bricklink.com/catalogItemInv.asp?S=75532-1 There are some interesting re-colors like drive ring extension in black: And axle with pin hole in DBG: For me the best news is re-appearance of #2 connector in DBG, 2 pieces are in this set, this color appears after 11 years! Quote
Jim Posted June 16, 2017 Posted June 16, 2017 3 minutes ago, Ivan_M said: Full inventory of 75532 Scout trooper is available at BL: https://www.bricklink.com/catalogItemInv.asp?S=75532-1 There are some interesting re-colors like drive ring extension in black: I bought a handful of these when I was in Legoland Germany Quote
Ivan_M Posted June 16, 2017 Posted June 16, 2017 It seems you were not the only one as BL is swarmed with this color already, which would be strange given this color appeared recently and it is available in no more than 4 sets Quote
Aventador2004 Posted June 16, 2017 Posted June 16, 2017 2 hours ago, Jim said: I bought a handful of these when I was in Legoland Germany Ha, no quoting pictures! Those look good in black. Quote
