1gor Posted December 27, 2019 Posted December 27, 2019 (edited) 11 minutes ago, pleegwat said: How about one of these https://www.bricklink.com/v2/catalog/catalogitem.page?P=2711#T=C press the studs into the liftarm. This one could be useful but it is to wide and is rubbing on tire; that was first thing that crossed my mind. Thanks for help It has to be 3 studs wide, but small liftarms 1 x 3 using axle 2 and 2 thin bushes is not stuff enough... Edited December 27, 2019 by I_Igor Quote
Void_S Posted December 27, 2019 Posted December 27, 2019 About new 42108's Differential part. Sariel's review with the new diff "stress test" when it opens (disengage the diff<->red gear combination) under heavy load when not secured enough inside the frame, makes the idea of using axles with stops ("stops" inside the diff - I remember these was an idea) very hard to be implemented. It's clear that it can't be done when the diff is inside the frame, so it must be super-embraced if the axles with stops are planed for use... Don't really like the idea to have the "heavy-duty-ready" thing made of two parts but it still fits the TLG idea (I still believe that's some plan here on that) to make the constriction self-disengageble rather than parts-damaging when something goes wrong. Quote
SNIPE Posted December 28, 2019 Posted December 28, 2019 (edited) 3 hours ago, Void_S said: About new 42108's Differential part. Sariel's review with the new diff "stress test" when it opens (disengage the diff<->red gear combination) under heavy load when not secured enough inside the frame, makes the idea of using axles with stops ("stops" inside the diff - I remember these was an idea) very hard to be implemented. It's clear that it can't be done when the diff is inside the frame, so it must be super-embraced if the axles with stops are planed for use... Don't really like the idea to have the "heavy-duty-ready" thing made of two parts but it still fits the TLG idea (I still believe that's some plan here on that) to make the constriction self-disengageble rather than parts-damaging when something goes wrong. use the new linear clutch (from 42100) to disengage drive to the diff. Edited December 28, 2019 by SNIPE Quote
Maaboo the Witch Posted December 30, 2019 Posted December 30, 2019 Does anyone else here think that we need this part in white? I mean, like right now? Quote
1gor Posted December 30, 2019 Posted December 30, 2019 2 minutes ago, Maaboo35 said: Does anyone else here think that we need this part in white? I mean, like right now? Not a bad idea, but if there will be a Liebherr mining dump truck it could be white and gray, but excavator that is influenced by Terex could have it (it is his could have any connections to upcoming backhoe which is still in domain of speculation; at least until Nuremberg you fair...) Quote
SNIPE Posted December 31, 2019 Posted December 31, 2019 (edited) On 12/27/2019 at 2:06 PM, I_Igor said: This one could be useful but it is to wide and is rubbing on tire; that was first thing that crossed my mind. Thanks for help It has to be 3 studs wide, but small liftarms 1 x 3 using axle 2 and 2 thin bushes is not stuff enough... Use those bracket pieces with a tile The bracket piece has a minifig torso hole and a stud and comes in two variants, one has thicker walls. There also one with a pin instead of a stud. Edited December 31, 2019 by SNIPE Quote
1gor Posted December 31, 2019 Posted December 31, 2019 2 hours ago, SNIPE said: Use those bracket pieces with a tile The bracket piece has a minifig torso hole and a stud and comes in two variants, one has thicker walls. There also one with a pin instead of a stud. Do you have a link or images of part? Thanks Quote
SNIPE Posted December 31, 2019 Posted December 31, 2019 3 hours ago, I_Igor said: Do you have a link or images of part? 18986 48724 28974 42446 also check out 47501 Regards, Snipe. Quote
johnnym Posted January 15, 2020 Posted January 15, 2020 The new tyres (69 x 28 (68.7 x 27 S on BrickLink), element ID: 6262361, design ID: 52985 from 1989 Bat Mobile (76139)) are (finally?) available from shop.lego.com - here in Germany for EUR 2,43 per piece. Let's see for how long... Quote
TechnicRCRacer Posted January 16, 2020 Posted January 16, 2020 The new City set 60249 Street Sweeper has two of the blue clutch gears and retails for only $10! Quote
Carl86 Posted January 16, 2020 Posted January 16, 2020 1 hour ago, TechnicRCRacer said: The new City set 60249 Street Sweeper has two of the blue clutch gears and retails for only $10! saw that as well and directly got one for me and my son haha Quote
Ctan Posted January 16, 2020 Posted January 16, 2020 6 hours ago, TechnicRCRacer said: The new City set 60249 Street Sweeper has two of the blue clutch gears and retails for only $10! You can get it from Lego bricks and pieces for less than a 1$ each. Quote
TechnicRCRacer Posted January 17, 2020 Posted January 17, 2020 16 hours ago, Ctan said: You can get it from Lego bricks and pieces for less than a 1$ each. I know, but I wanted the other parts as well (printed decorations!) and I don’t have to wait a week for it to ship. Quote
Ivan_M Posted January 24, 2020 Posted January 24, 2020 There is #3 connector in DBG for a first time in this color in set 42103: Quote
TechnicRCRacer Posted January 24, 2020 Posted January 24, 2020 1 hour ago, Ivan_M said: There is #3 connector in DBG for a first time in this color in set 42103: That’s probably the only reason I will pick up the set, aside from the lime long panels. Quote
SNIPE Posted January 24, 2020 Posted January 24, 2020 6 hours ago, Ivan_M said: There is #3 connector in DBG for a first time in this color in set 42103: Well spotted. Quote
SNIPE Posted February 6, 2020 Posted February 6, 2020 (edited) heres some more technic / semi- technic parts as well as recolors, and later appended part numbers/colors: #65635 Technic brick 2L x 1B x 6L with axles holes and cutout in Dark Bluish Gray #46882 Technic panel, wheel arch in Yellow #????? Technic panel mixer screw in Yellow, White #65200 Container, Book Cover Binding, 16 x 6 x 1 in Magenta #????? Tire 14mm D. x 4mm Smooth in Black #65202 Vehicle, Base 6 x 10 x 1 with 2 x 4 Recessed Center and 2 Holes in Black #65634 Vehicle, Base 6 x 12 x 1 with 5 x 4 Recessed Center and 8 Holes in Black #66727 Rim, dia. 18X12 w/ 4.85 Hole & Stud in Silver Metallic, White, Black #????? ???-new Technic panels 3x13-??? in some sort of Green #2972b Train Base 6 x 34 Split-Level with One Hole at Each End in Dark Bluish Gray late 2019/early 2020 parts with appended part numbers: #39367pb02 Wheel 56 x 14 Technic with Axle Hole and 8 Pin Holes with Fixed Black Rubber Tire in White/Black #65413 Technic, Gear 28 Tooth Double Bevel with Pin Hole in Red #52985 Tire 68.7 x 27 S in Black #40918c01 Technic Linear Actuator Long, in Light Bluish Gray/Red/Dark Bluish Gray #46834 Technic, Clutch Connector Female / Outside in Dark Bluish Gray #46835 Technic, Clutch Connector Male / Inside in White #46891 Technic Digger Bucket 10 x 19 in Dark Bluish Gray #66155 Wheel 30.4mm D. x 20mm with Center Axle Holes Motorcycle in Flat Silver #65417 Boat Hull Unitary 36 x 7 x 5, Base (Catamaran Half) in Lime Green #65418 Boat Hull Unitary 36 x 7 x 4, Top (Catamaran Half) in Dark Blue 50018c Minifigure, Weapon, Bar on Front, Stud on Back in Flat Silver 50018e Minifigure, Weapon with Bar and Stud in Flat Silver 50018a Minifigure, Weapon with 3 Mechanical Arms in Flat Silver 50018d Minifigure, Weapon with 2 Mechanical Arms in Flat Silver Edited February 6, 2020 by SNIPE Quote
SNIPE Posted February 6, 2020 Posted February 6, 2020 OH, OH if this works in real life it will be awesome. Quote
Ngoc Nguyen Posted February 6, 2020 Posted February 6, 2020 Just now, SNIPE said: OH, OH You might be onto sth Quote
Aleh Posted February 6, 2020 Posted February 6, 2020 On 1/16/2020 at 6:32 PM, TechnicRCRacer said: The new City set 60249 Street Sweeper has two of the blue clutch gears and retails for only $10! He he, reminded me an old sweeper 6649 from 1995 which I own since I was 6 years old :) Quote
Philo Posted February 6, 2020 Posted February 6, 2020 2 hours ago, SNIPE said: if this works in real life it will be awesome. Interesting, but I see no way the turntable assembly could work. The 20t bevel fits nicely IRL, but what could be the application? (once inserted the 20t no longer meshes properly with 12t bevel) Quote
SNIPE Posted February 6, 2020 Posted February 6, 2020 (edited) On 2/6/2020 at 3:10 PM, Philo said: The 20t bevel fits nicely IRL, but what could be the application? (once inserted the 20t no longer meshes properly with 12t bevel) oh it doesnt mesh ? dang. EDIT: Oh, it does, cool! Edited February 11, 2020 by SNIPE Quote
Ngoc Nguyen Posted February 6, 2020 Posted February 6, 2020 1 hour ago, Philo said: Interesting, but I see no way the turntable assembly could work. The 20t bevel fits nicely IRL, but what could be the application? (once inserted the 20t no longer meshes properly with 12t bevel) You can insert a 20z bevel gear instead and there should be enough space for it to mesh with a 12z half gear. Quote
SNIPE Posted February 6, 2020 Posted February 6, 2020 (edited) The half gap space in the 28 tooth idler gear can be useful: if you put a wheel with an axle hole and with tire inside of it it could act as a 28 tooth overload clutch gear too Edited February 11, 2020 by SNIPE Quote
Philo Posted February 6, 2020 Posted February 6, 2020 36 minutes ago, Ngoc Nguyen said: You can insert a 20z bevel gear instead and there should be enough space for it to mesh with a 12z half gear. Yes, using a 20z bevel inside differential gear works fine with a 20z or a 12z bevel. Quote
