  • Replies 5.1k
Posted Images
53 minutes ago, SNIPE said:
How about this combination: (92911 and 55889), it looks like it might actually snap into place and has a pin hole
no, it does not snap :sad:
17 hours ago, msk6003 said:
Is that yellow round part fit into spike ballcaster hub?
I think the spike prime ball caster socket is the same dimentions as the techcnic one but sure, try it anyhow
No, ball socket of Spike caster is larger. 19mm vs. 18mm for EV3 edu steel ball.
1 hour ago, Touc4nx said:
I was wondering if there was any uses of this part alone ?
250x250p.jpg?1579398251.3162136
Because I have two left unassembled...
Yes, as n slide-able frictionless female axle joiner for prop shafts etc.
New parts and recolors april-aug 2020
New parts:
?????? Technic Control+ Angular Motor in Dark Bluish Gray/Light Bluish Gray/Red (x1 in 42114)
?????? Technic Disc Brake in ? (x? in 42107)
?????? Spring with Shock Absorber in ? (x? in 42107)
?????? New rotor blades in ? (x? in 42113)
?????? New panels 3x13 in ? (x? in 42113)
?????? control+ dumb battery box in ? (x? in 42114)
?????? cement mixer panel curved in ? (x? in 42112)
37429  Leaf with 3L friction pin in Lime (x2 in 41251)
New / rare / re-released colors:
39790 Technic Frame 11 x 15 in Dark Bluish Gray (x1 in 42111)
90370 Minifigure, Utensil Microphone in Light Bluish Gray (x2 in 42111)
35186 Technic Driving Ring Extention in Light Bluish Gray (x1 in 42111)
42531 Technic Panel Arched  9 x 2 x 3 in Light Bluish Gray (x1 in 42114)
46882 Technic, Panel Car Mudguard 15 x 2 x 7 in Yellow (x2 in 42114)
11947 Technic, Panel Fairing #22 in Yellow (x? in 42114)
11946 Technic, Panel Fairing #21 in Yellow (x? in 42114)
24119 Technic panel 3x7 in Yellow
Previous unlisted parts:
55889 Ball with Pin Hole
50407 Plate, Round 2 x 2 Thin with Threads
40145 Plate, Round 2 x 2 Thin with Rotation Stem
46296 Clikits Bead, Ring Thick Small with Hole (fits over a stud, axle or pin, is the 0.5L thick.
Other interesting parts:
31352, 85345, 6292, 31351 (Fits on any 4x4 round/curved system piece or possibly 4266)
x1228 Duplo Tread, Thick Cleats
duptread Duplo Tread, Thin Cleats
2713 Conveyor Belt 14 Tread Links
Edited by SNIPE
[08/04/20] added 90370 & 39790. [11/04/20] added 37429 & 2713
  • 4 weeks later...
Technic recolors:
39367pb02 Technic 5Lx5Lx2L Spike Prime Wheel in Red with glued on tyre in Black (x1 in 80011)
18588  6 stud shooter barrel in Pink (x1 in 80009)
66155 Wheel with pin holes and 3 spokes in Green (x2 in 80006)
32054 Technic friction pin 2l with axle hole in Pearl Gold (x4? in 80007, x2? in 80011)
2958 Technic 3Lx3Lx0.5L disc with axle hole in Dark Turquoise (X2 in 80008)
?????? Technic ?L lifarms in Magenta (x2 80011)
6538c tTchnic 2L axle joiner smooth in Dark Purple (x1 in 80011)
18944 Technic curved 3x13 panel in Dark Green (x2 in 80013)
64782 Technic 5x11 panel in Dark Green (x2 in 80013)
24119 Technic round panel 3lx2lx7l in Dark Green (x2 in 80013)
55981 Wheel 18mm D. x 14mm with Pin Hole in flat gold (x6 in 80012)
5186 Technic drive ring extension wth 8 teeth in Light Bluish Gray (x1 in 42111)
5186 Technic drive ring extension wth 8 teeth in Black (x6 in 75275 )
39790 Technic frame 11x15 in Dark Bluish Gray (X1 in 42111)
2815 tyre 4x4x0.5L 3x3mm inner diameter in Metallic Gold (x1 in75969)
42610 Wheel 11mm D. x 8mm Black (x2 in 75276)
Technic new parts:
?????? technic disc brake in Falt Silver (x2 in 42107)
?????? technic shock with internal spring in Flat Gold (x2 in 42107)
?????? technic motorbike windscreen, flexable in Trans Clear (x1 in 42107)
?????? projectile shooter brick with hole in Black (x1 in 17103, x1 in 76153)
?????? projectile for projectile shooter brick with hole in Light Bluish gray and Black tip (x1 in 17103, x1 in 76153)
65186   Vehicle, Base 4 x 10 x 1 2/3 with Four Side Pin Holes in Dark Red (x1 in 71701)
65186   Vehicle, Base 4 x 10 x 1 2/3 with Four Side Pin Holes in Green (x1 in 76152)
?????? slope 2Lx3Lx1B with spinjitsu hole in Black (x1 in 70686, x1 in 70685)
?????? spinjitsu plate with bars and two studs in Black (x1 in 70686, x1 in 70685)
Sources:
https://youtu.be/_1Lyq_tu7ZM
https://youtu.be/vOo2oDhCY0s
https://youtu.be/RYcuT83P2hA
https://youtu.be/7r0m_jzpQ9E
https://youtu.be/VPRhwgbS9VA
Regards, Snipe
Edited by SNIPE
added more new or verified upcoming parts/recolors
9 hours ago, SNIPE said:
5186 Techni drive ring extension wth 8 teeth in Light Bluish Gray (x1 in 42111)
It will also be available in black (at least x6 in 75275) :
:classic:
:classic:
Looks like least 4x of 42610 wheel in black too.
:classic:
Oh wow nice find.
Almost every technic part is available in black now! :)
Edited by SNIPE
Indeed, but I didn't mention them since they're already available in 75276. Well, they're still new for this year. :grin:
68327 Wheel 41mm D. x 15mm Technic in Light Blueish Gray (x1 in 75551)
or this:  68325 Brick, Round 4 x 4 with Recessed Center  in Light Blueish Gray (x2 in 75551)Brick, Round 4 x 4 with Recessed Center  in Light Blueish Gray (x2 in 75551)
This can techally be made into a nice and thin 4X4 lego wheel with a tyre over it.
I also had no idea a spike prime rechargable battery came out in 2020 in yellow:
Edited by SNIPE
6 minutes ago, I_Igor said:
@SNIPE nice find! 68327 Wheel 41mm D. x 15mm Technic in Light Blueish Gray looks very interesting but I wonder which tire can be fit in it?
not sure but the inside diamiter is 4L and the outside is probalby 5L or just over.
I wonder if we can put rollers in the space around the inner rear  and make a bearing turntable.
As for the smaller wheels, any duplo tyre can fit on it fine because those fit any 4L round part.
Wheel is ideal for truck front wheel (at least)...
Now I will wating this come in black for little drift car....
I don't remember, so You can try to combine curved slopes.
What is overall lenght? Maybe 7 stud long panel can be used or their combination?
