TechnicRCRacer Posted June 2, 2020 Posted June 2, 2020 6 hours ago, Ngoc Nguyen said: Defender wheel arch in white is coming in the new Mindstorms set. New Mindstorms set?!? Are they releasing the SPIKE system in a regular consumer form? Quote
SNIPE Posted June 2, 2020 Posted June 2, 2020 On 6/1/2020 at 4:41 PM, Leewan said: NO NO NO NO NO, this is bad because you cant put a bar inside this type fo axle hole and its slightly weaker!! Quote
SamuelYsc Posted June 3, 2020 Posted June 3, 2020 On 6/1/2020 at 11:41 PM, Leewan said: Apparently the changeover catch has been updated. The main difference is at the cross axle. The tip seems rounder, but that might be due to the angle of the render. It should be in the Sián, so people who have it could make a more accurate comparison between both versions. Why don't just release a no center axle version... It is more difficult to put them side by side now... Quote
Leewan Posted June 3, 2020 Posted June 3, 2020 14 hours ago, SamuelYsc said: Why don't just release a no center axle version... Like with a round hole instead ? (Don't worry guys, it's just a small mockup I made with Mecabricks ) Quote
Jasonv24 Posted June 3, 2020 Posted June 3, 2020 I fou d this neat moc someone made and I was teying to make one myself. Does anyone know what part that is used for the head? Quote
TechnicRCRacer Posted June 3, 2020 Posted June 3, 2020 @Jasonv24 looks like this part: https://rebrickable.com/parts/89159/headwear-accessory-visor-large-with-trapezoid-top/#part_usage attached to this helmet: https://rebrickable.com/parts/93560/minifig-sports-helmet-plain/#part_usage Not sure what this has to do with Technic. Quote
SamuelYsc Posted June 4, 2020 Posted June 4, 2020 9 hours ago, Leewan said: Like with a round hole instead ? (Don't worry guys, it's just a small mockup I made with Mecabricks ) Yes! On this, you can just use a single long axle to go through a few of this. It is very good for some crazy gearbox usage. Thanks for the modeling! Quote
LvdH Posted June 10, 2020 Posted June 10, 2020 The new Mindstorms set includes at least one white Defender wheelarch, as well as what seems to be dark turqoise making a return to Technic. Quote
Touc4nx Posted June 11, 2020 Posted June 11, 2020 is there also some white bevels gears ? (On the "foot" of the left creature) Quote
Erik Leppen Posted June 11, 2020 Posted June 11, 2020 (edited) On 6/3/2020 at 8:26 PM, Leewan said: Like with a round hole instead ? (Don't worry guys, it's just a small mockup I made with Mecabricks ) I frequently use the axle-hole so I can move the actual lever to a nearby place in the model (even if only 1 or 2 studs stud sideways). You would lose that functionality if the hole was round (or it would take more space to build a structure around it to lock the axle to it.) Stated differently, the current part with 2 axleholes has 2 "input options" (one rotational and one pull-push) which are both useful. Also, someone else suggested to make the straight part with the inline axlehole longer, so the body is 2 studs long instead of 1.8something like it is now. But that would mean the part wouldn't "fit" within 2 studs when rotating. So that would also be a slight loss of functionality for no real benefit. That said, the current change to a "non-bar-fitting axhole" doesn't seem to have any use, except as a "code" for the fact that the axlehole is non-friction (similar to the red 8t gear and the long worm gear, which have the same axlehole shapes). I don't really care though. I never used a bar in that piece anyways. You can use a 2L axle or an axle pin if you want multiple side-by-side moving independently. Edited June 11, 2020 by Erik Leppen Quote
msk6003 Posted June 11, 2020 Posted June 11, 2020 1 hour ago, Touc4nx said: is there also some white bevels gears ? (On the "foot" of the left creature) That is 56903 wheel with tire. Quote
TechnicRCRacer Posted June 11, 2020 Posted June 11, 2020 The new mindstorms is dark turquoise!! I’m gonna have a lot of fun when it hits Bricks and Pieces. Quote
SamuelYsc Posted June 12, 2020 Posted June 12, 2020 17 hours ago, SNIPE said: Here's page1: set mumber 51515 Interesting. The middle yellow-red text said "Incoming on June" Quote
astyanax Posted June 12, 2020 Posted June 12, 2020 On 6/10/2020 at 11:29 PM, LvdH said: The new Mindstorms set includes at least one white Defender wheelarch, as well as what seems to be dark turqoise making a return to Technic. Do you have a source that says dark turquoise? The photo looks like regular green to me... Quote
zux Posted June 13, 2020 Posted June 13, 2020 11 hours ago, astyanax said: Do you have a source that says dark turquoise? The photo looks like regular green to me... Review states the color is Teal [TLG], which is also Dark Turquoise [BL]. The color can also be clearly seen on official pictures. Quote
astyanax Posted June 13, 2020 Posted June 13, 2020 8 hours ago, zux said: Review states the color is Teal [TLG], which is also Dark Turquoise [BL]. The color can also be clearly seen on official pictures. Right, I had seen the review, but it only mentions the motors as having teal parts, not the other bricks. I never imagined TLG would mix teal and green though.... Quote
N-4K0 Posted June 13, 2020 Posted June 13, 2020 It looks like regular BrickLink Turquoise to me. What I have seen as BL Turquoise. Quote
TechnicRCRacer Posted June 13, 2020 Posted June 13, 2020 Now that I look closer, there are SO many recolors! Teal (Dark Turquoise) is probably my favorite TLG color and it’s amazing to see it return to Technic! Also the SPIKE baseplate returns again in this set. Quote
SNIPE Posted June 14, 2020 Posted June 14, 2020 (edited) XL FRAMES IN BLACK!!!!!!! white+dark turquoise = technic ambulance based on the same scale as set 42111 Edited June 14, 2020 by SNIPE Quote
Zerobricks Posted June 14, 2020 Posted June 14, 2020 7 minutes ago, SNIPE said: XL FRAMES IN BLACK!!!!!!! white+dark turquoise = technic ambulance based on the same scale as set 42111 They are same as in Defender and Sian. Quote
SNIPE Posted June 14, 2020 Posted June 14, 2020 Just now, Zerobricks said: They are same as in Defender and Sian. no I just counted the holes. its 11x15 in black X2 Quote
Zerobricks Posted June 14, 2020 Posted June 14, 2020 Just now, SNIPE said: no I just counted the holes. its 11x15 in black X2 Sorry, I thought you were refering to the 7x11 which is in the chest of the bot. You are correct! Quote
SNIPE Posted June 14, 2020 Posted June 14, 2020 (edited) I might as well do another update since it's been a while since the last one and a lot has changed: New technic parts: 68196 technic curved, tapered panel right 5L x 13L x 1L in Lime (x2 in 42115) 67142 technic curved, tapered panel left 5L x 13L x 1L in Lime (x2 in 42115) 67141 technic mudguard 15L x 5L x 2L round in Lime in lime (x4 in 42115) 65422 technic blade 19L x 3L x 1L in Lime (x2 in 42115) 865777 Wheel 62.3mm D. x 42mm with 20 spokes in Mettalic Gold (x4 in 42115) 68196 technic curved, tapered panel right 5L x 13L x 1L in Dark Bluish Gray (x? in 42113) 67142 technic curved, tapered panel left 5L x 13L x 1L in Dark Bluish Gray (x? in 42113) New molds: 51149 Changeover catch in Red (formerly 6641) ?????? Shock absorber Extra Hard 6.5L in Yellow, Red? (formerly 731c04) ?????? Differential with Closed Center, 28 Bevel Teeth in Dark Bluish Gray (formerly 62821b) 61408 Beam 1L x 3L with axle holes & pin with Squared Hole (formerly 33299) Technic Recolors: x136 wishbone suspension arm in Lime (x4 in 42115) 18654 1L x 1L beam in Lime (x30 in 42115) 15100 Pin with pinhole in Lime (x24 in 42115) 22961 Axle with pinhole in Lime (x10 in 42115) 87082 Pinhole with two opposing pins in Lime (x15 in 42115) 32013 #1 connector in Lime (x10 in 42115) 32034 #2 connector in Lime (x2 in 42115) 32016 #3 connector in Lime (x14 in 42115) 32015 #5 connector in Lime (x2 in 42115) x346 Bionicle tooth 1L x 1L x 3L in Lime (x11 in 42115) 63869 cross block with 2 pinholes and one axle hole in Lime (x7 in 42115) 15458 Technic panel 3L x 11L x 1L in Lime (x5 in 42115) 64394 panel #13 in Lime (x5 in 42115) 64680 panel #14 in Lime (x5 in 42115) 64392 panel #17 in Lime (x1 in 42115) 64682 panel #18 in Lime (x1 in 42115) 24116 panel curved 3L x 5L x 3L in Lime (x2 in 42115) 18944 panel curved 3L x 13L in Lime (x2 in 42115) 32054 friction pin 2L with axle hole 1L in Lime (x6 in 42115) 6538c axle joiner 2L in Lime (x7 in 42115) 32580 hose soft axle 7L in Lime (x3 in 42115) 32235 hose soft axle 19L in Lime (x8 in 42115) 60483 Beam 2L with axle hole in Lime (x45 in 42115) 35189 Technic disk brake in Light Bluish Gray (x1 in 42107) 18654 1L x 1L beam in Dark Turquoise (x? in 51515) 32523 3L beam in Dark Turquoise (x? in 51515) 32140 4L x 2L beam bent in Dark Turquoise (x? in 51515) 32316 5L beams in Dark Turquoise (x? in 51515) 40490 9L beam in Dark Turquoise (x? in 51515) 41239 13L beam in Dark Turquoise (x? in 51515) 60484 Technic, Beam 3L x 3L T-Shape Thick in Dark Turquoise (x? in 51515) 6536 cross block 1L x 2L in Dark Turquoise (x? in 51515) 42003 cross block with two pinholes and one axle hole in Dark Turquoise (x? in 51515) 32034 #2 connector in Dark Turquoise (x? in 51515) 32474 technic ball - bionicle without thru hole in Dark Turquoise (x? in 51515) 55889 ? ball/wheel with pin hole, in Black (x? in 51515) 49283 wire clip in Dark Turquoise (x? in 42115) 46882 mudguard 15L x 2L x 7L in White (x2 in 51515) 39790 11L x 15L frame in Black (x? in 51515) 39369 Technic baseplate 11L x 19L x 1L in Dark Turquoise (x? in 51515) 39793 Biscuit connector in Dark Turquoise (x? in 51515) bb1142c01 (probably bb1142c02 when released) Spike prime hub in white and Dark Turquoise (x1 in 51515) 54696c01 (probably 54696c02 when released) Spike prime M motor in White and Light Bluish Gray (x4 in 51515) 37308c01 (probably 37308c02 when released) Spike prime color sensor in White (x1 in 51515) 37316c01 (probably 37316c02 when released) Spike prime ultrasound sensor in White (x1 in 51515) 39793 biscuit connector in White (x? in 42112) 39793 biscuit connector in Light Bluish Gray (x? in 42112) ?????? Cement mixer drum half with screw conveyor and yellow print in Dark Blue (x2 in 42112) 32072 Technic, Knob Wheel in Pearl Gold (x2 in 8755) 2815 Wedge Belt Wheel Tire in Pearl Gold (x3 in 75956) Technic printed parts: ?????? 1L x 2L Beam with axle hole, With 'Lamborghini' emblem print in lime (x2 in 42115) ?????? Technic panel #1 left with fuel filler cap print in lime (x1 in 42115) rare recolors: 6538c 2L axle jointer in white (x? in 71721) 32039 2L connector in white (x? in 71721) Regards, Snipe Edited June 26, 2020 by SNIPE added 60484, 61408 and fixed error with motors Quote
