1 minute ago, SNIPE said:
OHHHHH.
i only just noticed that the new 2x3 L beam has a stupid support band on it,   kinda like 3x3 l beam thin with support.
WHY!!!!!! and it has an axle hole which is not as bad but still!!.
The support is so it can match the curved panels.
  • Replies 5.1k
Posted Images
Then use a system curved slope! with some technic bricks added on
OR use part 48177!
Edited by SNIPE
43 minutes ago, SNIPE said:
OHHHHH.
I guess it's supposed to be usable as panel extender, like a 1L slice of 85x85p
EDIT: ah this was already said on new page which I didn't see :ugh:
Edited by astyanax
11 hours ago, SNIPE said:
OHHHHH.
My thoughts too. I can see its usefulness as a panel extender but we're also in need of more L-shaped liftarms beside the current 2x4 and 3x5 (and if you count thin ones, 3x3) and the support destroys its usefulness in many structural applications. 3x4 would've been even better but still...
7 minutes ago, howitzer said:
More usable as a decorative part, less usable as a structural part.
I wouldn't say so... I still remember some failed ideas of very compact chassis where this part was literal salvation. MOCs will show the future of this part)
it still has uses as a structural or mechanical element but its usefulness is reduced because you cant put more beams for example where the support band is like you can with a 3x3 T liftarm.
11 hours ago, astyanax said:
Has anyone ever had/seen a good use for part 48724 in a Technic build?
I don't have that part, but I have occasionally used the studded version in tight spaces in bodywork, and sometimes I suppose that pinned one would be better.
landrover 42110 and ferris wheel 10247 use this parts.
Since its hard to keep track of all the new parts and recolors and even I was starting to struggle here they are so far:
New parts:
Technic 1x3x7 panel (rectangle) in Black, Dark Bluish Gray, Yellow, Dark Azure
Technic 2x3 curved panel (rectangle) to go with #21 and #22 panels) in Yellow, Blue, Dark Azure, White, Black
Technic balloon tire for 30.4mm D. x 20mm sized rims in Black
Technic balloon tire for 43.2mm D. x 26mm sized rims in Black
Technic 2x3 L beam/half cam , thick with curved support in Black
Technic 1x15 alternating hole beam in Black
Technic 13L lambo style wheel arch  in Red
Technic wheel arch extender in Red
Technic 1x1 brick with axle hole in Light Bluish Gray
3x3 Vrick, round with recessed center and axle hole (kinda like part 68325) in Light Bluish Gray
2x2 Vrick with centre pinhole and 2x2 embedded plate  in Light Bluish Gray
6x6 Plate with 5 pinholes in cross pattern in Light Bluish Gray
Connector bracket with two axleholes and 2L deeo axle hole in White (from lego dots books)
Plate 2x2 double thickness with axle hole and flutes in black, tan
Recolors:
3713  Bush 1L in Black (YEY)
65422 Technic, Rotor Blade Large Straight with 3L Liftarm Thick in Black
39793 Biscuit joint 1x3x3 in Dark Bluish Gray
15458 Technic, Panel Plate 3 x 11 x 1 in Blue
64393 Technic Panel Fairing # 6 Long in Blue
64681 Technic Panel Fairing # 5 Long in Blue
42531 Technic Panel Car Mudguard Arched 9 x 2 x 3 in Blue (with new print)
27940 Technic pinhole with two axles in Blue
32199 Soft axle 11L in Blue
6541  Technic 1x1 brick with pin hole in Medium Azure
89523 1 x Plate Special 10 x 10 Octagonal with Hole in Medium Azure
26287 Technic Driving Ring Connector Smooth in Dark Green
65803 Technic Brick 16 x 16 x 1 1/3 with Holes in Olive Green
11946 Technic Panel Fairing #21 Very Small in Dark Turquoise
11947 Technic Panel Fairing #22 Very Small in Dark Turquoise
18945 Technic Panel Plate 5 x 11 x 1 tapered in Dark Turquoise
32524 Liftarm 1x7 in Dark Turquoise
6143  Brick Round 2 x 2 with Axle Hole in Dark Turquoise
3943b Cone 4 x 4 x 2 with Axle Hole in Dark Turquoise
50450 Axle 32L in Green
35186 Drive ring extention with 8 tabs in Green
35442 Plate with 6 Teeth in Green
26287 Technic Driving Ring Connector Smooth in Lime
56145 Wheel 30.4mm D. x 20mm with No Pin Holes and Reinforced Rim in Lime
62462 Pin joiner 2L with slot in Lime
30374 Bar 4L in Lime
3673  Frictionless pin 2L in Yellow
24116 Technic, Panel Curved 3 x 5 x 3 in Bright Light Orange
64393 Technic Panel Fairing # 6 Long in Magenta
64681 Technic Panel Fairing # 5 Long in Magenta
18945 Technic Panel Plate 5 x 11 x 1 tapered in Magenta
67142 Technic Panel Curved #50 5 x 13 tapered Left in Red
68196 Technic Panel Curved #51 5 x 13 tapered Right in Red
32065 Beam 1x7 thin in Red
18944 Technic, Panel Curved 3 x 13 in Red
15100 Pin and pinhole in Red
63869 Connector purpendular with 3 pin holes in Red
18654 1x1 beam in Red
32054 Technic 2L friction pin with axle hole in Flat Silver
56908 Wheel 43.2mm D. x 26mm Technic Racing Small, 6 Pin Holes in White
Rare color re-releases:
32250 Technic, Liftarm 3 x 5 L-Shape with Quarter Ellipse Thin in Blue
6553 Technic, Pole Reverser Handle / Axle Connector in Blue
32250 Technic, Liftarm 3 x 5 L-Shape with Quarter Ellipse Thin in Yellow
44809 Technic, Pin Connector Perpendicular 2 x 2 Bent in Yellow
3941 Brick, Round 2 x 2 with Axle Hole in Trans Red
6553 Technic, Pole Reverser Handle / Axle Connector in Red
New prints:
1x3 beam in yellow with grille print1x3x5 L beam in yellow with grille print
Other notable new parts:
Brick, specialized with built in steering mechanism and mini wheel pins in Light Bluish Gray (I think it uses "suspension" to steer somehow so it could be used as a spring box with technic vehicle axles)
Edited by SNIPE
27 minutes ago, SNIPE said:
technic 2x3 curved panel to go with #21 and #22 panels) in Yellow, Blue, Dark Azure
This is also in white in the 488.
<snip>
recolors:
<snip>
18945 Technic Panel Plate 5 x 11 x 1 tapered in magenta, light Turquoise
11946 Technic Panel Fairing #21 Very Small in light Turquoise
11947 Technic Panel Fairing #22 Very Small in light Turquoise
<snip>
Lots of new stuff indeed. I updated my panel listing (https://docs.google.com/spreadsheets/d/1MdCtQMN_kaaMzyWy_blFLJNzT05f4dCxXS1Nx3DhfDU/edit?usp=sharing) partially but going to wait for Bricklink entries for the new moulds.
I'm wondering about the quoted parts, are those really light turquoise as in Medium Bluish Green in TLG colour names? That colour hasn't appeared since 2003 at all according to Ryan Howerter's colour guide so I'm just making sure before I create a new colour entry.
oops I typed Light Turquoise by mistake. fixed.
Does anyone know if the technic airplane thingy is Orange and White with Dark turquoise or Orange and White with Medium Azure?
