Posted October 13, 201410 yr Hello, I like Efferman's Cat D11 so I'm going to make it pneumatic i modified the inside, remove the gearing, there will be a small pneumatic pump at the moment I'm here:
October 14, 201410 yr Author do you want to add a electric pump or manual it will be manual with 20:12 gear ratio, but if the performance will be not so good, i change it to the big manual pump
October 14, 201410 yr Author the small one can be hidden in the base, and you can operate with the exhaust pipe or the air filter for the bigger one i have some idea, i want to be it invisible
November 13, 201410 yr Author Helo, the model in Ldraw more or less is finishd. Right now I'm making the tubing for the pneumatics. LSynth need a lot of patient :)
November 13, 201410 yr Looks very nice, I like the place you hid the handpump. the first mounting point of the cylinders have looked better I agree, also if possible I would try to lower the switches one stud so the cabin looks clean.
November 14, 201410 yr Author the first mounting point of the cylinders have looked better It is possible, but i can't put closer the cylinders to the grille, because of the tubing. Or I can increase the distance between the big cylinders, but then i have to think about where can I put the tubing, now it is guided under the structure I will make few solutions Looks very nice, I like the place you hid the handpump. I agree, also if possible I would try to lower the switches one stud so the cabin looks clean. Possible, but the tubing are very tight at the switches already
November 14, 201410 yr Author The room for the tubing between the top inlet and the grill could be tight
November 14, 201410 yr Would it fit to have the big cylinders turn 90 degrees inward in the picture you made in the first post so the outlets face the grill? Outwards probably creates problems with the mini pumps? I still think the mounting point in the first picture looks the best, but I understand the tubes would then touch the tracks. You'd have to think of a different way to mount the cylinders besides the grill while keeping them in the same place as your first picture. I also think the tubing would look pretty nice with some tubes coming out of the chassis besides the grill. Looking at you last picture, seems like there is plenty of space to lower the switches. I see 4 studs of space. That's 1 more stud than I had in my wheel loader and I had to consider a driveshaft running through the middle too :D
November 14, 201410 yr Author Would it fit to have the big cylinders turn 90 degrees inward in the picture you made in the first post so the outlets face the grill? Outwards probably creates problems with the mini pumps? I still think the mounting point in the first picture looks the best, but I understand the tubes would then touch the tracks. You'd have to think of a different way to mount the cylinders besides the grill while keeping them in the same place as your first picture. I also think the tubing would look pretty nice with some tubes coming out of the chassis besides the grill. Looking at you last picture, seems like there is plenty of space to lower the switches. I see 4 studs of space. That's 1 more stud than I had in my wheel loader and I had to consider a driveshaft running through the middle too :D If I turn the cylinders 90 degrees, then the upper connection point were impossible, or very strange. I lowered the switches one stud, now better, but I can't because the tubing. At the weekend I will try these at the real model and will see.
