Hello all,
I can finally present you my new bridge.
It is 304 studs long, so that's more than 2.4m (or almost 8 feet) and I used about 12500 bricks:
The thought of making a bridge started years ago and the design also took quite some time with a lot of design iterations in LDD. I can still see where I can make some improvements though ...
But for now I consider it finished.
It was inspired by a bridge I used to cross quite often in my student days. (Link)
To be honest I first thought of using the railway bridge on the other side of that city but that would have resulted in an even larger bridge...
I have seen many other truss LEGO bridges using the TECHNIC bricks but I wanted to have a cleaner look:
And I am also satisfied with the cross bracing on the top and bottom
In the end it has some sagging in the middel of about four plates.
It seems a lot but considering the span it actually poses no problems for my trains.
I am also busy with the design for the sides of the bridge. There is still some space to fill. The idea is to make a road underneath with a bicycle path next to it.
But what do you think? Feel free to comment.
Wow, that is something else! Nice one!
Thats an amazing project!
Thank you.
Very well done. Can it pass the milk jug test?
--Tony
Of course it can:
But the 2.4 liter jug is the biggest we have here so I hope you don't mind I added the book and the "stroopwafels" to compensate for the difference compared to the gallon milk jugs you have.
Awesome. How much does it sag with trains on it?
I haven't really noticed any additional sagging with trains on it. I guess it is like with real bridges. The weight of the bridge itself is most important.
Holy fu- *oh2*
That is awesome! Although i feel like that's mostly because of the gigantic scale, the build itself kind of repetitive but it looks stunning though.
Edited by WoutStopmotion
Thank you all for your nice comments!
This is just amazing, well done! Are you going to use it in a layout?
I would love to, but I guess it needs some more work on the sides first.
4 plates? Good engineering! how do you move it?
Good question. I am already wondering how to move it from the living room to the study/LEGO room...
Very impressive, maybe the best design I've seen so far.
What do you think, can it hold two of my Stadler FLIRTs? (around 8 kg-s :D )
Thank you and it should hold beautiful FLIRTS without a problem. It will sag it bit further but nothing disastrous.
