aeralure Posted June 18, 2015 Posted June 18, 2015 :: important :: Is every Kawashita member connected to the group PM's "mission log" and "board transmissions"? Working for me too. Thanks for setting this up! Quote
Graham Gidman Posted June 18, 2015 Posted June 18, 2015 (edited) :: important :: Is every Kawashita member connected to the group PM's "mission log" and "board transmissions"? Yes, I am. Edited June 18, 2015 by Graham Gidman Quote
aeralure Posted June 18, 2015 Posted June 18, 2015 (edited) I'm experimenting with making a new Kawashita sig banner for personal use - but - if anyone wishes to use it I am absolutely happy with sharing it around. If there's any issue with it, the way the images are working in the sig editor, I need to make it three pieces. I'm hoping board staff won't mind if I include a few small thumbnails with what is there? The poles that make up 2 of the 3 parts are super tiny size-wise. Anyway, feel free to drag the three parts to your desktop and use, make suggestions, and/or ask me to post them somewhere etc. Edited June 18, 2015 by aeralure Quote
Kodan Black Posted June 18, 2015 Posted June 18, 2015 Just wanted to point out that your head CEO has your corporation's name spelled wrong in their signature. Quote
Mike S Posted June 18, 2015 Posted June 18, 2015 Just wanted to point out that your head CEO has your corporation's name spelled wrong in their signature. That is our secret code within a code. Can't give you the cipher though, you being Octan and all.... Quote
kabel Posted June 18, 2015 Posted June 18, 2015 oh man, what would an eb building game be without all that trash talk, especially if it involved half the dudes playing GoH too ... Quote
aeralure Posted June 18, 2015 Posted June 18, 2015 It's easy enough to slide the poles the other way so that the banner is first and the sigfig image is second. Might be that's what I do, so there could be two versions. Might do that later and then post the images for both, although this one is all set. Quote
narbilu Posted June 19, 2015 Posted June 19, 2015 Just wanted to point out that your head CEO has your corporation's name spelled wrong in their signature. That was how it was called before launch changed it... Quote
kabel Posted June 19, 2015 Posted June 19, 2015 That was how it was called before launch that's what I'd say too if I was illiterate! Quote
Commander Turtle Posted June 19, 2015 Posted June 19, 2015 that's what I'd say too I was illiterate! There's something ironic about this post... Quote
Commander Turtle Posted June 19, 2015 Posted June 19, 2015 You missed a word while trash talking our Esteemed Leader's spelling Quote
aeralure Posted June 19, 2015 Posted June 19, 2015 (edited) A little refinement on my banner and I offer it here for anyone in a few flavors. Feel free to use them if you want or to offer any suggestions. 3-part Banner Due to the way the sig editor works, this one uses 3 images so that the pole can be extended above the AG sigfig image. You set it up in two rows of two images, the two pole images on top and then the sigfig and banner in the second row. It aligns nicely, but the downside to this solution is you are using 4 of your 5 allowed sig images, which may be an issue to some. I'm considering other options too. The two poles: The banner (including both spellings): Standalone Banner This is the one to use if you need the space for three other images. Comes in standard size and narrow. Narrow would fit inline a bit better with the AG sigfig image. Standard Narrow Kawashita Signature This version makes sense to include as well. It's simply the banner itself, sans the Samurai-style pole work. This version sits inline with the AG sigfig image better: These are of the original height and work too: Edited June 19, 2015 by aeralure Quote
Mike S Posted June 19, 2015 Posted June 19, 2015 A little refinement on my banner and I offer it here for anyone in a couple flavors. Feel free to use them if you want or to offer any suggestions. Nice! Quote
Niloc Posted June 19, 2015 Posted June 19, 2015 (edited) Really nice aeralure, thanks! Fitting slogan. I took the banner without poles. I like it like that Edited June 19, 2015 by Niloc Quote
aeralure Posted June 19, 2015 Posted June 19, 2015 (edited) Oh of course! I hadn't thought about that for some reason. I'll edit my post with a simple sig banner variant in a few moments. That way the option exists and you don't have to have the cut outs or the pole on the right, unless you want them, because that's cool too actually. I may do that as well. Edited June 19, 2015 by aeralure Quote
mccoyed Posted June 19, 2015 Posted June 19, 2015 Really wish I knew how to implement this. I have a lot of trouble with the EB signature editing. Quote
aeralure Posted June 19, 2015 Posted June 19, 2015 (edited) Really wish I knew how to implement this. I have a lot of trouble with the EB signature editing. The board's sig editor is a little bit tricky, depending on what you want to do with it. If you want the one with the poles, do note that you only have one image left as the sig editor only accepts 5. Means to have 3-4 thumbnail images like you do, they would have to all be as one image linking to one place. Might be a deal breaker in that way. Just fyi. To set the one up with the poles, clear you sig for starters (just to make it easy). First image to put in is the the pole with nothing on it. On the same line, with the cursor right at the end of the pole, place the pole with the banner parts. Hit Return. The cursor will now be on the next line, below both pole parts. Put the AG sigfig image here. Finally, with the cursor right at the right of that image, place the lower banner part. In effect you are taking 4 images and placing them in two rows, with the first row shallow but the second row taller. That's basically the trick to align them in this sig editor - the rows have to be the same height, hence why I had to cut the images up for that version. For the other versions, it's simply place the cursor where you want it and put your image in. I made a couple heights so hopefully one aligns with your other images the way you like. For your current sig, one solution is to display only three thumbnails like you do (they will still each be able to link to different locations), and then in the second row, before or after the sigfig image, place one of the banners without the extra pole part. Makes a total of 5 images which is the most you can have. I had really wanted to be able to place 10 (lol). Was hoping I could, because the image size is so tiny on the poles. I was then going to place 3 small spacers (couple bytes each) on that row, and then on row two three small thumbnails. Total row height would have been 110 pixels and total kbs less than most sigs. It's just the editor makes a hard fast rule at a 5 image limit rather than total bandwidth. Edited June 19, 2015 by aeralure Quote
Blackhawk STX Posted June 20, 2015 Posted June 20, 2015 :: important :: Is every Kawashita member connected to the group PM's "mission log" and "board transmissions"? I'm in! Quote
Dragonfire Posted June 20, 2015 Posted June 20, 2015 Thanks aeralure! Oh, and I am connected to both PMs. Quote
aeralure Posted June 20, 2015 Posted June 20, 2015 You're welcome everyone! Glad you enjoy them. I had fun making them. Quote
