roland Posted November 24, 2015 Posted November 24, 2015 Would it be possible to optionally turn off camera-relative rotation, though? LDD used to have absolute rotation, and I hated it when they changed to relative.In prefs/editor there are options for this, but a minor bug prevents turning it individually on/off. This will be fixed in beta 2 though. I remember that when I started using LDCad for the first time, it wasn't turned on by default. Again, in the view menu, make sure that it has a green "PS" instead of a read "GS". And, again, this is also personal preference Part snapping is disabled by default as I consider it a guidance tool, also not all parts have the needed extra info so usage can be confusing for new users if they have zero experience working with grids first.Roland, I think there may be a bug with the escape key. According to the hotkey list, pressing it should deselect any current selection. However, that doesn't seem to work. Ctrl+Shift+a works to deselect, but that's a lot more awkward to use. I'm used to just hitting "esc" to deselect parts.I can't replicate this are you sure the mouse cursor was inside the editing area when you pressed esc ?I see your descriptions of UI items at the bottom of the page as I mouse over them. Would it be possible to also put those descriptions in tooltips? This is planned for a future version. The hint in status bar thing was intially to lighting the rendering work but this is less and less a problem on modern graphics hardware. Quote
Classicsmiley Posted November 24, 2015 Posted November 24, 2015 I can't replicate this are you sure the mouse cursor was inside the editing area when you pressed esc ? If by editing area you mean the area with the parts, yes, my mouse is in that area. My mouse can even be directly over a selected part, and pressing esc has no effect. Quote
Matrix2507 Posted November 24, 2015 Posted November 24, 2015 sorry for butting in, im kind in a hurry. could anybody tell me if how to select multiple parts like drag selection or like LDDs option to select all part that are touching eachother ? I just made a big cannon in a vertical position and i just realized i have no way of rotating its entire barrel on its pivot point because of all the parts involved D: thanks you http://i.imgur.com/e8gJ3mk.png Quote
Philo Posted November 25, 2015 Posted November 25, 2015 (edited) At the moment, LDCad is missing area selection and connected selection. You have to control+click on all parts you want to select (if by chance you simply want to select everything, ctrl+A works...). Otherwise, it may be easier to make the selection in a source window (requires LDCad 1.5 beta) Edited November 25, 2015 by Philo Quote
Matrix2507 Posted November 25, 2015 Posted November 25, 2015 Otherwise, it may be easier to make the selection in a source window (requires LDCad 1.5 beta) whats that ? (i have 1.5beta) Quote
Philo Posted November 26, 2015 Posted November 26, 2015 See In the source window you can select several parts (click then ctrl+click) or range of parts (click then shift click) even if they are hidden by other bricks. Quote
roland Posted November 26, 2015 Posted November 26, 2015 If by editing area you mean the area with the parts, yes, my mouse is in that area. My mouse can even be directly over a selected part, and pressing esc has no effect.What os are you using? Anyone else having this problem?sorry for butting in, im kind in a hurry. could anybody tell me if how to select multiple parts like drag selection or like LDDs option to select all part that are touching eachother ?I just made a big cannon in a vertical position and i just realized i have no way of rotating its entire barrel on its pivot point because of all the parts involved D: Like Philo wrote at the moment you use hold down ctrl to extend the seclection and or use the source window to reach obstructed things etc. I do have a selection rectangle planned for 1.6 though. See In the source window you can select several parts (click then ctrl+click) or range of parts (click then shift click) even if they are hidden by other bricks. Please note that clip is from one of the earliest Alpha versions I will make a better clip using the current version to really demonstrate the current state of things once 1.5 is definitive. Things to know: open a source window from the view menu, dock the window by pressing ctrl when roughly at the place you want it to be. Quote
Classicsmiley Posted November 26, 2015 Posted November 26, 2015 What os are you using? Anyone else having this problem? I'm using Windows 8.1 Pro. Quote
Matrix2507 Posted November 26, 2015 Posted November 26, 2015 oh thank you, i was going mad trying to know how to dock windows xD also, nice to know youll add draw select soon. sorely needed feature if you ask me Quote
roland Posted November 26, 2015 Posted November 26, 2015 (edited) I'm using Windows 8.1 Pro.Are you running photoshop in the background? As a quick search led me to an known issue with it on windows 8.1 it seems to be 'stealing' the esc key event for some reason. Edited November 26, 2015 by roland Quote
Classicsmiley Posted November 27, 2015 Posted November 27, 2015 No, I don't even have Photoshop installed. Quote
zux Posted December 12, 2015 Posted December 12, 2015 Hi there, I'm new to digital building. After reading over various topics over internet, installation, configuration and tweaking I have LDCad working fine (with bunch of other software) on my Linux OS machine. I seem to have installed the latest beta version which is running fine and helps me to progress. However I managed to break single feature on first launch and unable to get it back - both Color and Part bins are detached (and randomly placed on next launch) and I didn't find a way to attach them back. One of the YouTube videos posted in this thread shows it is easily fixed on Windows machine. However nothing even close happens in Linux. Switching "Locked docked windows" between Yes and No gives no result. I wonder if this is a bug or there is way to fix it? Quote
roland Posted December 12, 2015 Posted December 12, 2015 I seem to have installed the latest beta version which is running fine and helps me to progress. However I managed to break single feature on first launch and unable to get it back - both Color and Part bins are detached (and randomly placed on next launch) and I didn't find a way to attach them back.You can redock them by dragging the part bin to the left and while still holding down the left mouse button press the ctrl key to dock it. Next do the same with the color bin window but drop it on the top of the part bin window.The 'lock docked windows option' is there only to prevent accidental undocking like you probably experienced here. You can also reset all configuration to the defaults by deleting the main.cfg file located in the config folder. The config folder will be located in the same place the executable is or If you used the linux setup script it will be in your home folder. Quote
zux Posted December 12, 2015 Posted December 12, 2015 Robert, appreciate your quick response! Thanks for advise, I was able to dock those windows back. On another note, I wonder if it is known how large is the number of Linux users? Quote
roland Posted December 13, 2015 Posted December 13, 2015 I wonder if it is known how large is the number of Linux users?The Linux / windows version is downloaded at about a 1 to 4 ratio but but I have no clue on how many of them go on using it regularly. Quote
roland Posted December 20, 2015 Posted December 20, 2015 I've released LDCad 1.5 Beta 2. It's mostly bugfixes and some minor new features. You can download it from the usual place: http://www.melkert.net/LDCad/download Quote
Boogs Posted December 22, 2015 Posted December 22, 2015 (edited) Having some issues copy/pasting with this new version. Every time I paste, I lose at least one brick. Even starting a new model, adding just one brick, copy/pasting that one brick, It disappears. Is throws up a 'Missing LDraw file dependencies for the current model' error. http://s1.postimg.or...ldcad_error.jpg Any idea as to what's going on? Ah, noticed in the image, it's not using the full file-name, the 't' is missing from the end of 3024.da. Thanks. Edited December 22, 2015 by Boogs Quote
roland Posted December 22, 2015 Posted December 22, 2015 Any idea as to what's going on?Ah, noticed in the image, it's not using the full file-name, the 't' is missing from the end of 3024.da. It seems I broke the lines split function while fixing another issue. This caused the last character of the last line to be omited. It's fixiable by using the part dialog for the missing part and correcting the .da into .dat by hand. You could also prevent using paste by using ctrl+d or ins if you copying things withing the model it self.I might make beta 2a for this though. Thanks for reporting. Quote
roland Posted December 23, 2015 Posted December 23, 2015 I've put Beta 2a up, it only fixes the paste bug nothing else has been changed. Quote
legolijntje Posted December 25, 2015 Author Posted December 25, 2015 Hey Roland. When I load one of these 2 files made by Darats (set 5521), LDCad crashes. Do you maybe have any idea why? I'm using 1.5 beta 1b though, so not the newest version. Quote
Philo Posted December 26, 2015 Posted December 26, 2015 Both models load fine here (with beta2). Quote
roland Posted December 26, 2015 Posted December 26, 2015 When I load one of these 2 files made by Darats (set 5521), LDCad crashes. Do you maybe have any idea why?I'm using 1.5 beta 1b though, so not the newest version. Both models work for me in beta 2a and beta 1, it might be caused by a different version of some part file. Are you using the latest 1501 LDraw library? Or have you configured LDCad in some special way? In that case try loading the models after resetting the configuration but keep the original main.cfg handy so you can mail it to me if it does work with default settings. That way I can investigate the differences etc. Quote
legolijntje Posted December 26, 2015 Author Posted December 26, 2015 Both models work for me in beta 2a and beta 1, it might be caused by a different version of some part file. Are you using the latest 1501 LDraw library? Or have you configured LDCad in some special way? In that case try loading the models after resetting the configuration but keep the original main.cfg handy so you can mail it to me if it does work with default settings. That way I can investigate the differences etc. Yup, there were some problems with the parts. There were 2 parts that were outdated and a few I didn't have (stickers). I've updated everything and it loads fine now. Still, I think it would be better to load the model with a warning instead of just completely crashing when there's a problem with the parts. Quote
roland Posted December 26, 2015 Posted December 26, 2015 Still, I think it would be better to load the model with a warning instead of just completely crashing when there's a problem with the parts. Yes, I would like to know the root cause of this in order to fix it for the definite 1.5 version. Could you mail me the problem parts and other related things needed to get it crashing. Quote
legolijntje Posted December 27, 2015 Author Posted December 27, 2015 Yes, I would like to know the root cause of this in order to fix it for the definite 1.5 version. Could you mail me the problem parts and other related things needed to get it crashing. Well, I'd like to, but to be honest, I don't have much information... I viewed the model in LDview and one of the stickers was looking weird (aside from missing a few stickers). So, Darats (the file author) said I probably had an older version of one of the stickers. I realized I didn't had the newest parts library and hadn't updated the unofficial files in a while. So to solve both the wrong and the missing stickers, I just updated everything at once. It also solved LDCad's problem, but that was completely 'unintentional'. I planned to take a better look at that after fixing the stickers. I wasn't expecting to fix LDCad by just updating a few parts So, I can't tell you a lot more than that It's highly likely though, that one of the (missing) stickers was the problem. The other parts are all very general parts and have probably been in the official library for a while now. In LDview, the only problems I had (before upgrading the parts) were stickers. Quote
