Posted November 27, 201410 yr hy i've found this video and it tought if it was possible to make this in lego? http://www.hobbyexpress.com/1_10_wraith_4wd_rock_racer_rtr_1042357_prd1.htm Thanks
November 27, 201410 yr Simply put no... Here are the reasons: - No lego motor has the necessary power - Even if there would be enough power the gears would break, because of high speeds, forces of acceleration braking and bumping. - The axles/frame/suspnesion would fall apart, and even when built interlocked the pins would most likey break...
November 27, 201410 yr Author yeah so i thougt but i wanted to know if someone had made a moc like this
