I can recognize my bulldozer in your MOD. I like that you've added more articulation to blade but I don't understand what are thouse slant beams in rear for...
The very next days i made this moc. It is a non real model but i had an idea about what to. Pieces are only from 42006 so details are not easy to bee construct especially from a begginer like me.
Edited by Electricalchief
That's actually quite nice. Of course the string isn't original part from 42006. Have you considered motorizing it?
It's really neat how you've preserved the feel of other crane and bulldozer sets while making your mocs. This set may get overlooked because it is yellow and treaded and not powered / RC like some of its predecessors. Do you think you could approximate the 8043 B-model with this set?
The string it is not a lego piece. But it works very well with the wog. Also as you can see the boom goes up and. Down full path very easy. About 8043 b model looks good idea, i will try it, but i dont know if i will made it good. At the moment, pieces of this set is use to improve 42009 crane for better look.
@tomik, just out of interest, did u do a PF or RC version of that dozer? And did you consider doing a tilting blade as @electricalchief has done?
I haven't done remote controlled version of my dozer due to lack of space for battery box and motors. I think it would be much bigger model for RC.
And I was thinking about tilting blade but I haven't found the way how to do it.
@tomik thanks for the response, and I can see why you couldn't do it. I will attempt to make it soon.mare there step by step instructions on rebrickable?
Yep, there is link to my web on rebrickable or you can go directly here.
Real nice crane electricalchief...I also like the turning of the blade adding on to Tomik's design. Those liftarms in back are a bit odd, but like you said you wanted it to your liking.
