Epic Technic Posted December 19, 2014 Posted December 19, 2014 Here is the complete SBrick LDD model: http://www.brickshelf.com/gallery/Epic-Technic/stuff/sbrick_model.lxf Quote
TheItalianBrick Posted December 19, 2014 Posted December 19, 2014 EDIT: On a side note, I see a potential "flaw" in the SBrick's design: You cant use the lower outputs (lowest "stair step") on the brick to power two motors for each output without using an extension wire true...but it still works anyway using the extended wire...so we will be fine Quote
Seasider Posted December 19, 2014 Posted December 19, 2014 Can you post the dimensions of an s brick in the rules so we can make a space for it as it says the model must be ready for an s brick ... Or if we place 2 ir units side by side is that the same size and attachment ? Also on the 4 function motor thing, if you went for a tracked of skid steer does that count as 2 functions. I think it does, I think your intention is for separate functions and this fits that. As with a car you'd have drive and steering, with a tracked you have drive to 2 tracks, so both the same Quote
Epic Technic Posted December 19, 2014 Posted December 19, 2014 Can you post the dimensions of an s brick in the rules so we can make a space for it as it says the model must be ready for an s brick ... Or if we place 2 ir units side by side is that the same size and attachment ? Here is an LDD file for it: http://www.brickshelf.com/gallery/Epic-Technic/stuff/sbrick_model.lxf Quote
TheItalianBrick Posted December 19, 2014 Posted December 19, 2014 Also on the 4 function motor thing, if you went for a tracked of skid steer does that count as 2 functions. I think it does, I think your intention is for separate functions and this fits that. As with a car you'd have drive and steering, with a tracked you have drive to 2 tracks, so both the same not a big deal as you will anyway use 2 motors, 2 IR/sbrick slots, and 1 remote control....so it's clearly defined as 2 functions itself. Let's see is as "one motor powers a track therefore it's a function, the other motor powers the other track so therefor it's another function!" Quote
D3K Posted December 19, 2014 Posted December 19, 2014 (edited) Also on the 4 function motor thing, if you went for a tracked of skid steer does that count as 2 functions. I think it does, I think your intention is for separate functions and this fits that. As with a car you'd have drive and steering, with a tracked you have drive to 2 tracks, so both the same I think the easiest way to put it is "you must use four (no more, no less) of the outputs on the SBrick(s), regardless of the amount of motors." There really is no room for misinterpretation there. Edited December 19, 2014 by D3K Quote
Tommy Styrvoky Posted December 19, 2014 Posted December 19, 2014 (edited) I'm guessing that there can't be a 5th PF motor attached directly to the battery box for a fake engine... Or what about LEDs? I shall finally be able to enter one of my tanks into a contest. Edited December 19, 2014 by Tommy Styrvoky Quote
Jim Posted December 19, 2014 Author Posted December 19, 2014 I'm guessing that there can't be a 5th PF motor attached directly to the battery box for a fake engine... Or what about LEDs? I shall finally be able to enter one of my tanks into a contest. Be aware that the MOC should be new. No existing ones. LEDs have been described in the rules. LEDs are okay, but they don't count as a function. Quote
Tommy Styrvoky Posted December 19, 2014 Posted December 19, 2014 Be aware that the MOC should be new. No existing ones. LEDs have been described in the rules. LEDs are okay, but they don't count as a function. I'm just planning, as most of my models feature this function, now I will find a solution using differentials. Quote
Jeroen Ottens Posted December 19, 2014 Posted December 19, 2014 I suppose a video showing the functions is mandatory this time? Quote
Erik Leppen Posted December 19, 2014 Posted December 19, 2014 It's in the original post Jeroen. Please read before you write. ;) Same goes for Tommy's LED question by the way. It was answered before you asked. Quote
JGW3000 Posted December 19, 2014 Posted December 19, 2014 Jim, great contest, and I may have time to build this time. Just to be clear, the 41999 has four motors, but two are for drive, one for steering, and one for winch - this would qualify if it was new, but is this 3 functions or 4 - I'd count 4, as the two L motors are not connected by gearing, but are connected to the same IR receiver socket. My plan is to build with two IR receivers, to test the functions, these could be replaced by one S-brick with no change in aesthetics. Quote
Jim Posted December 19, 2014 Author Posted December 19, 2014 Just to be clear, the 41999 has four motors, but two are for drive, one for steering, and one for winch - this would qualify if it was new, but is this 3 functions or 4 - I'd count 4, as the two L motors are not connected by gearing, but are connected to the same IR receiver socket. This is something we need to finalize. I'd like to think of Driving as a single function, independent of using 1 or 2 motors. (this conflicts with my current rules I guess) Skid steering/driving is a tough one as well. Although using two motors in skid steering will take care of driving AND steering, ending up in using two motors for two functions. Quote
Eraman Posted December 19, 2014 Posted December 19, 2014 (edited) It's a good contest again! I don't understand exactly: "When using a gearbox, your model can have more than 4 functions (6 for example, like the 8043 Excavator). The model needs 2 PF IR Receivers which can be replaced by one or two SBricks." .... Model needs EXACTLY 4 powered functions (no more, no less)." Which is the right? i think this is the best solution: use exactly 4 PF motor, and make minimum 4 function powered by the motors. If you want to use gearbox, you CAN use it, with it the functions limit will be max 8(or 6 if 1 motor change the gears). I have a question: can we build extra MANUAL funtions(above the 4 power function)? For example: cabin tilting, headlight tilting, etc.? Edited December 19, 2014 by Eraman Quote
Jim Posted December 19, 2014 Author Posted December 19, 2014 It all depends on what the definition of a function is. Driving is a function, but this can be accomplished by using two motors. That's the caveat. You can have manual functions. I already answered that question. Quote
Eraman Posted December 19, 2014 Posted December 19, 2014 It all depends on what the definition of a function is. Driving is a function, but this can be accomplished by using two motors. That's the caveat. You can have manual functions. I already answered that question. Ok, my plan: 4 motors, 1 motor change the gears, so i will have 6 power function(with 3 motor), 1 function is steering, 1 function is driving and 4 other functions. Plus i will have 1 manual function, cabin tilting. Is it good for this contest?:) I hope, yes:) Quote
Jim Posted December 19, 2014 Author Posted December 19, 2014 I think the easiest way to put it is "you must use four (no more, no less) of the outputs on the SBrick(s), regardless of the amount of motors." There really is no room for misinterpretation there. Maybe this is indeed the best description, which boils down to using 4 motors! Ok, my plan: 4 motors, 1 motor change the gears, so i will have 6 power function(with 3 motor), 1 function is steering, 1 function is driving and 4 other functions. Plus i will have 1 manual function, cabin tilting. Is it good for this contest?:) I hope, yes:) Yup! That's cool Quote
Eraman Posted December 19, 2014 Posted December 19, 2014 (edited) It all depends on what the definition of a function is. Driving is a function, but this can be accomplished by using two motors. That's the caveat. You can have manual functions. I already answered that question. Hmm, otherwise, use only one motor for driving, if it isn't enough, make lighter(smaller) model. Or the driving will be an exception when you can use 2 motors, other function have to be powered only one motor. Maybe this is indeed the best description, which boils down to using 4 motors! Right, i agree with you, max 4 motors with 2 Sbrick, and fuctions are minimum 4, maximum unlimited!:) Edited December 19, 2014 by Eraman Quote
pint14 Posted December 19, 2014 Posted December 19, 2014 Just to be sure, it's not allowed to use more than 4 motors? For example i can ONLY use 1 motor for driving, 3 other for functions. Bassicly 1 motor per function? Quote
D3K Posted December 19, 2014 Posted December 19, 2014 (edited) Maybe this is indeed the best description, which boils down to using 4 motors! Not necessarily, I actually meant you can use two or more motors on one output if you so desire, but you are limited to the four outputs of one SBrick. Seeing as it is an "SBrick contest", this will help showcase the possibilities of the SBrick (not having first hand experience, I have no idea how it performs with more than one motor attached to a single output). In effect you will still be limited to one function per output, as it's rather difficult to power two different functions with the same output EDIT: So in my oppinion, if someone wants to power 10 motors from one output, please go ahead.. I don't think the maximum number of motors will be the deciding factor on who wins, rather the opposite Edited December 19, 2014 by D3K Quote
Jim Posted December 19, 2014 Author Posted December 19, 2014 How about "Use exactly 4 motors (and do with them what you want)"? This is more or less what you mean. Quote
Eraman Posted December 19, 2014 Posted December 19, 2014 (edited) How about "Use exactly 4 motors"? This is more or less what you mean. nothing (i can not delete post ) Edited December 19, 2014 by Eraman Quote
Erik Leppen Posted December 19, 2014 Posted December 19, 2014 (edited) Why not "Just make a model that fits nicely with the same way of operation of 42030 or 8043". Is that so difficult to interpret? We can endlessly debate about the details, but let's adhere to the spirit of this contest, right? To be honest, I am having an idea, but it requires a manual function (or five controls). So that means currently I can't do it. And I don't even really care if it's "allowed" - it's not in the spirit of the contest to have a manual function. If you build something that's not in spirit, you won't get as many votes. It looks like the spirit is to build a remote-controlled model that has four controls. So, I say: let's just build a remote-controlled model that has four controls. Edited December 19, 2014 by Erik Leppen Quote
Eraman Posted December 19, 2014 Posted December 19, 2014 Why not "Just make a model that fits nicely with the same way of operation of 42030 or 8043". Is that so difficult to interpret? We can endlessly debate about the details, but let's adhere to the spirit of this contest, right? To be honest, I am having an idea, but it requires a manual function (or five controls). So that means currently I can't do it. And I don't even really care if it's "allowed" - it's not in the spirit of the contest to have a manual function. If you build something that's not in spirit, you won't get as many votes. It looks like the spirit is to build a remote-controlled model that has four controls. So, I say: let's just build a remote-controlled model that has four controls. Why don't you use gearbox, like me? Quote
Milan Posted December 19, 2014 Posted December 19, 2014 Why don't you use gearbox, like me? Somebody will use gearbox, somebody will make one or more manual functions, some will stick to 4 functions. Great thing is that we have a choice. Quote
