Posted January 1, 201510 yr This is my solution : Because of the lag this is not followed properly, it is necessary to get the file premiet pin!
January 1, 201510 yr Could you not have used jumper plates to give you the half stud offset? i have done something similar, but I just left the half stud gap, as it seems small enough for the trains to cross without bother.
January 1, 201510 yr Author I do not try. With This system, no shock when the train crossed the rail. Edited January 1, 201510 yr by Godzilla91210
January 1, 201510 yr I wouldn't be comfortable cutting vintage tracks. You can also cut flex track to make the connection since no one seems to like flex track. I think the bits to cut off is above the yellow line.
January 1, 201510 yr Hi guys, We have even a more simple solution! SEE LINK BELOW Just snap the pins into the holes and away you go.... they are .25 cents a piece and you get 4 for $1.00. I will have Eric add more to the inventory if you need a bunch. NO cutting needed. The rails align. Blue as well as 4.5 volt gray track. I hope this helps Happy New Year Mike ME Models Edited January 1, 201510 yr by mike44
January 1, 201510 yr Corrected link for above: http://www.me-models.com/store/product_info.php?cPath=22_57_61&products_id=146
January 1, 201510 yr Verry verry nice, but i dont have the track métal 9v! Its the same track as rc track but without the metal on top.
