Rockbrick Posted January 8, 2015 Posted January 8, 2015 A winch that pull all the shocks using a string that works parallely with it could work i'm waiting To see The other function Zblj :3 I was thinking on the same lines for adjusting the shocks you could use a pulley that you tighten loosen with strings thereby adjusting the tension and travel on the shocks (and height too) Quote
PKW Posted January 8, 2015 Posted January 8, 2015 I was thinking on the same lines for adjusting the shocks you could use a pulley that you tighten loosen with strings thereby adjusting the tension and travel on the shocks (and height too) yes also the high but during diving tests they will be more realistic giving the truck an harder shocks setup :3 Quote
Zerobricks Posted February 10, 2015 Author Posted February 10, 2015 Any progress on this monster? Had a very busy month (different non-lego project), hopefully I will manage to finish it untill deadline. Quote
Zerobricks Posted February 19, 2015 Author Posted February 19, 2015 Here's a video of the sadly failed truck, it was simply too heavy for a single XL motor: Quote
Thirdwigg Posted February 19, 2015 Posted February 19, 2015 It's always sad when a MOC doesn't work out. I like that you still made a video and presented the fact that it didn't work as you had hoped. Quote
Rockbrick Posted February 20, 2015 Posted February 20, 2015 you learn more from failed project that the ones that go well.... Quote
