Looks good from what I remember from the show. Only thing I can see that is a bit off is it looks like the minifigs can't stand straight, they have to angle slightly. But going 4 studs wide would be too much, alas some times things can't be perfect within the bounds of Lego and the dimensions of minifigs.
Thanks, glad you guys liked it. Yeah, I've noticed that the stormtroopers are not fitting in the bays right too. Tried fixing it but 4 studs long would make the model bigger than it is. Afterall, its a version 1. ^_^
I really like this. I think you have reached a good compromise with regards to the stormtroopers positioning. There aren't a lot of pictures of the interior, namely the cockpit area... Does it have one? I do like the fact it looks close to source material too. Well done ^_^
I like the bottom edge. It really looks like it could hover quite nicely :) I agree with markus that the size is a bit over. Actually it's almost twice as big but I can't really imaginge making it much smaller with all the features. Good job!
Thanks, glad you guys like it! Yes it does have a cockpit but my camera wasnt able to take good pictures of the interior. It kept blurring because of the black tiles. I'll see if I can open the cockpit next time and show you. Yeah, i think its a little bit on the bigger side too. would this be ucs scale? It slides prety well with the two by two round plates on the bottum to get that effect. If i ever get to it, there may be a version two unless if i end up doing anoter project. :grin:
This is great! I was just rewatching the so far released episodes of Rebels and I was thinking that Lego should make this into a set, but I think you maxed it out, perfect build!
