zeki Posted January 13, 2015 Posted January 13, 2015 Latest firetruck done in LDD in the past month. Truck is inpired by Multistar type vehicles and American quint pumpers. Truck has a crew of 6, pump with 1600 l/min pump, it holds 1500 l of water and 300 l of foam, all necessery equipment for firefighting and technical rescue. Front view. It has 4 equipment compartments and a ladder acces directly after the cabin. Back view. Pump compartment. Bird's eye view Ladder extended. 2 inspirational vehicles. Multistar Quint Engine Aerial Have a nice day Quote
lightningtiger Posted January 13, 2015 Posted January 13, 2015 AWESOME digital fusion design of German and Yankie fire trucks......are you going to brick build it too 'zeki' ? Brick On LDD On 'zeki' ! Quote
alexb420 Posted January 13, 2015 Posted January 13, 2015 I like it! It has a very European look to it. :) Quote
scottwb2010 Posted January 13, 2015 Posted January 13, 2015 Nice design zeki. Would like to see a brick built version of this with one less locker between the axles to resemble the multi-star. Look forward to seeing a brick built version of your LLD aswell. Reminds me its about time I updated my Scotsburgh FD with its Scania Bronto Allrounder ARP. Quote
zeki Posted January 14, 2015 Author Posted January 14, 2015 Yes lightningtiger the model will also be brick built. scottwb2010: I have chosen this leinght in order to accomodate 2 ladder basis on top of the firetruck. If the model would be shorter it would be imposible. Also if you desire all the equipment in the truck that is in the description the 3 lockers per side would not be enought. Thanks for the comments. Quote
scottwb2010 Posted January 15, 2015 Posted January 15, 2015 Hi zeki. I wish TLG would bring out a ladder probably about 1/2 t3/4 as long again to the ones they produce just now. The current ladders are OK when you build a Pump Fire Engine, but when you build an engine that requires longer ladder like a Turntable Ladder truck you have to join 2 ladders together which doesn't always work well and creates a weak point. Quote
