Posted January 18, 201510 yr Hi all After getting the 42038 Artic Truck, I played around with the track links and noticed that if you make a loop with all the tracks inverted, it can compress, but spring back to its original shape, and so I figired if I had the tracks jammed between some rollers on the underside and on the topside is a sprocket, it will have a motor per wheel and very high ground clearance. I have made a mockup of 1 wheel, it is fairly smooth running but needs stabilizing a lot, the wheel wobbles around. I think having two sprockets on the top then a roller in the middle on the underside might be better (like a triangle shape). The good thing is the wheels change shape depending on the surface it is driving on, the wheels in the mockup are quite hard to compress so just add more links to it. Heres the pics: Now since i'm too busy to start building this I'm just gonna leave the idea out here and see what happnes, I have my 42029 project on the go already... I'm sure somebody willl make something cool out of it, post ideas and builds below!. Regards, Snipe
January 18, 201510 yr I too noticed that you could make a wheel if the track was inverted. But I never thought about literally making it a wheel. Great thought!!!
January 18, 201510 yr some idea for a bike maybe? a big bike ;) (image resized...) Edited January 18, 201510 yr by darsedz
January 18, 201510 yr Hmmm, couldn't it become a good idea for something like space rovers, like Lunokhod or Curiosity? Btw, It could give enormous road clearance.
January 18, 201510 yr You've invented something like a top-roller-drive Rolligon http://www.trucksplanet.com/catalog/model.php?id=1294 http://www.unusuallocomotion.com/pages/industrial/rolligons-and-terra-tires.html
January 18, 201510 yr I think you'd have to be careful, though. Any vehicle big enough to use 4 of these might be heavy enough to break the snap connection between links. ...and a flat tire would be devastating.
January 18, 201510 yr Author I have sat on it and it did not break, the two sides can actually meet together without it breaking :D
January 18, 201510 yr I have sat on it and it did not break, the two sides can actually meet together without it breaking :D Never thought that it could be possible.
January 19, 201510 yr I have sat on it and it did not break, the two sides can actually meet together without it breaking :D Seriously? Wow! OK then, I guess the only challenge is to make it light enough not to sag, then.
January 19, 201510 yr Hmmm, couldn't it become a good idea for something like space rovers, like Lunokhod or Curiosity? Btw, It could give enormous road clearance. No, the dust and sand will build up and block rotation. Edited January 19, 201510 yr by Omikron
January 19, 201510 yr I too noticed that you could make a wheel if the track was inverted. But I never thought about literally making it a wheel. Great thought!!! The idea has been around for a while, especially if you've been following GBCs
January 19, 201510 yr very cool - I have wrapped tracks like this to the outside of wheels before to make 'snow chains' sort of but hubless on its own - something light like a mars rover will keep these elliptical or round even but something heavy is going to require more than 4 wheels
January 19, 201510 yr Nico71's braiding machine uses an inverted track loop for the main drum. Uses 48 tracks and is about the smallest diameter you can make.
January 20, 201510 yr so have diggers but you don't stop seeing plenty of MOCs of them bring it on...
January 20, 201510 yr Author It's been done: http://www.eurobrick...showtopic=66099 No, I don't mean that. The outside of the chain ring is being driven not the inside, and the drive is on the top of the chain for huge ground clearance. There is 4 chains which act as wheels. Edited January 20, 201510 yr by SNIPE
January 20, 201510 yr ... Uses 48 tracks and is about the smallest diameter you can make ... Not always 48, it depends on whether you're using the old or new design. One of them folds back more than the other ...
January 21, 201510 yr I have used this kind of wheels, with central hub, for old-time farming equipment. They look and work great.
