Gabor Posted June 27, 2015 Posted June 27, 2015 Great and absolutely recognisable alternative model! The functions are cool! Quote
JamesJT Posted June 27, 2015 Author Posted June 27, 2015 It isn't supposed to move. If it did move then it wouldn't transfer the movement to the solar panel on the satelite (or you would need a second mechanism to open the solar panels). Looks to me like a linear actuator bracket should go there and is probably missing from LDD. A few parts have been removed by Garrond to better illustrate his question. Quote
Garrond Posted June 28, 2015 Posted June 28, 2015 (edited) It isn't supposed to move. If it did move then it wouldn't transfer the movement to the solar panel on the satelite (or you would need a second mechanism to open the solar panels). The thing is it stops that big cogweel in fixed place - is that a desired output? My result is nonmovable panels :( I put there an normal axle - maybe that's a problem? Edited June 28, 2015 by Garrond Quote
JamesJT Posted June 28, 2015 Author Posted June 28, 2015 Yes, trust me, it is supposed to be fixed. I just checked my model against the LDD file, it is exactly the same. Mine works just like in the youtube clip. Quote
niknarjc Posted July 8, 2015 Posted July 8, 2015 I really like your Shuttle. It looks great. You did a good job filling all the technis holes for a smooth finished product. I looked through you Flickr photos too. Wow, great stuff. I really like your aircraft. Quote
JamesJT Posted July 24, 2015 Author Posted July 24, 2015 I have re-designed my shuttle without the "C-Model" limitations. I am going to put this version on Lego Ideas. lego 113 by James Tillson, on Flickr lego 108 by James Tillson, on Flickr lego 114 by James Tillson, on Flickr lego 106 by James Tillson, on Flickr lego 112 by James Tillson, on Flickr I also made a new video but it is only slightly better than my original. Quote
MaxSupercars Posted July 24, 2015 Posted July 24, 2015 (edited) Hello James, I'm a big fan of space and I like Space Shuttle. Your shuttle as Model C is really very good and inspiration for me. But when I would have no limitations I would make same details in other way: - The front nose - better design, this looks unfinished - It's technic but I'm missing the windows - Inside of the wings - liftarms should be in one direction - The rudder - the upper part without those 3L half thin liftarms - 2 small support engines are missing - better satellite - etc ... That were the first details that I would change if I rebuild it... :) But as I said, your C basic model looks really good... :) What you made perpect (!!!) is control of landing gears and satellite via rear engines... :) Max... Edited July 24, 2015 by MaxSupercars Quote
PROlego Posted July 25, 2015 Posted July 25, 2015 Another fan of space here and although I've stated previosly that this is not my favourite vehicle and I'd prefer to have a model of the venerable Soyuz I'd like to build this (probably a Buran version which won't need the parts for the SSMEs but should have a second robotic arm) if I get enough parts soon. I don't like the nose, though. I know it is pretty hard to change it but now it reminds me of the nose of Sierra Nevada's Dream Chaser or ESA's Hermes because it's "roundy" instead of "pointy" (very scientific description here hehehe). The rest is great IMHO. Quote
Graydingo Posted July 26, 2015 Posted July 26, 2015 Love the control scheme! Very clever and playable! Say. Where's that moving platform MOC for the shuttle? Is that the right scale? Quote
zux Posted July 26, 2015 Posted July 26, 2015 Cool one! I am going to put this version on Lego Ideas. What about rebrickable? Quote
JamesJT Posted July 27, 2015 Author Posted July 27, 2015 (edited) The project is published and "gathering support" The Scale of this model is 1:78. it would look too small on the MOC platform. I didn't put it on rebrickable because I don't have instructions, just the LDD file. I am happy with the design but I'm sure Lego's own designers could do a much better job. If it gets 500 supporters before it is deleted in 12 months time I will be amazed. Edited July 29, 2015 by JamesJT Quote
PeterF Posted July 27, 2015 Posted July 27, 2015 Well, you're of to a good start at least :-) I like the model a lot. It also seems quite realistic as a LEGO set, not a 20k-piece MOC. The only thing that I think could be better is the movie. P.S. there are lots of MOCs on rebrickable with only a 3D file no instructions. Quote
redik Posted September 16, 2015 Posted September 16, 2015 The project is published and "gathering support" The Scale of this model is 1:78. it would look too small on the MOC platform. I didn't put it on rebrickable because I don't have instructions, just the LDD file. I am happy with the design but I'm sure Lego's own designers could do a much better job. If it gets 500 supporters before it is deleted in 12 months time I will be amazed. Hello JamesJT, can you share the LDD file (from 42025 parts) - redik@orangemail.sk And BTW excelent mod... Quote
JamesJT Posted September 16, 2015 Author Posted September 16, 2015 Done. Don't forget to edit your message and remove your email address. Please post some pictures if you build it. Quote
tbob74 Posted September 18, 2015 Posted September 18, 2015 (edited) Beautiful, I will give my support to Lego Ideas. Edited September 19, 2015 by tbob74 Quote
PeterF Posted September 19, 2015 Posted September 19, 2015 I have built this model a while ago. Great model, poor pictures I'm afraid. In my opinion the use of panels in this model is better than in the A model. The functions are also really clever. The model looks much better in real life, and I can advise anyone who has the set to build it. Just don't use the build instructions function in LDD, just use the build view and the hide tool. In this picture the shuttle was apparently deploying the satellite while preparing for landing (facepalm). Quote
plethorabricks Posted September 25, 2015 Posted September 25, 2015 This model is really cool. I like how you used the blue beams for the stand. In the A-model of the set, that portion of the cargo plane looks like it's being "de-rezzed" or it's part of one of those fade-to-wire-frame pictures or something. Quote
Daxit Posted December 3, 2015 Posted December 3, 2015 Great model ! Can I add myself to the list of those wanting the LDD (I'm a newbie, so can't PM yet) Quote
JamesJT Posted December 3, 2015 Author Posted December 3, 2015 Thank you. PM me when you have enough posts. Quote
craiv Posted December 26, 2015 Posted December 26, 2015 (edited) Hi James, this is beautiful, been looking forward to an alternate build and as I'm moving the disassembled model to my new flat in the UK this would be a great excuse :) - just registered to get the LDD, if you don't mind sending it over to *redacted* Will take some proper build photos in exchange! cheers :) Edited December 27, 2015 by craiv Quote
pgplay Posted December 27, 2015 Posted December 27, 2015 Hi James, Are you still gathering support for the shuttle? Can you post a link? Great build btw. Quote
JamesJT Posted December 27, 2015 Author Posted December 27, 2015 Still very slowly gathering support. It is on target to hit 1000 and get a 6 month extension but thats all. https://ideas.lego.com/projects/110466 Quote
craiv Posted December 27, 2015 Posted December 27, 2015 James, thanks for the model - you're a star. I have supported your project and I'll do my best to share with friends and colleagues :) Quote
winterhur1 Posted January 7, 2016 Posted January 7, 2016 Very nice model! I would like to built it. I send a PM to you. Quote
