  • Replies 83
It looks brilliant, spot on to the real thing. Although, I think the turn signals should be different. Maybe you could use some transparent tiles instead of the orange liftarms?
Yes, maybe you are right, but now i have more important works on the truck, if i have time, i will re-design the signals! Thanks the advice :thumbup:
Edited by Eraman
This is suddenly a lot more interesting! Thanks for the pics.
It's looking really good, specially from a technical perspective. It may be a bit slow if I see the gearing correct. Have you tested the speed of it?
Is there a possibility to see a pic without the side panels on the frame?
-ED-
thank you all!
-ED-
Hmm, if i have some time, i will take a picture without the side panels! (but do not show much more)
I think the speed not too fast, but it is enough for me. This is my first big and complex creation, so please be forgiving with me :blush::wink:
Edited by Eraman
I hope i can finish it at weekend (i'm waiting for the last order from bricklink today), maybe on sunday or monday i present photos the whole truck, and the next weekend i try to upload a cutted video.
That is a fantastic truck you have built, you got all the proportions and details right. I'm amazed at how low this truck is to the ground.
Thank you, it is very low, maybe a bit lower, than the real one, but i needed every space to build a massive structure. At my first attempt the base was 3 studs thick under the cabin, but the nose of the vehicle was bent very much ... so it was necessary to thicker the chassis in the front. I cannot go upwards, because the floor of the cabin is very low, so i needed to go downwards. After all the chassis under the cabin become 5 studs thick , it becomes enough rigid.
Edited by Eraman
Wow! What a great Moc! Isn't the rear a bit heavy? Does it touch the ground?
Yes, it is heavy, the LAs lift it very difficult but it works. It doesn't touch the ground. I took the photos on a sofa, it is soft so it touches it, but on flat floor everything is OK!:)
(otherwise my main aim was to built this vehicle only with LA-s, not pneumatic, and it is managed, i'm glad with the finished work yet if it is not too perfect )
Edited by Eraman
Why panels on the body are inverted inwards?
The garbage container is typically made of sheet metal and is smooth on the inside. This is done to enable the garbage to be compacted. Those ribs you see on the outside are stiffening beams for the sheet-metal construction. The author simply wanted to replicate the looks/functionality.
Edited by DrJB
