Dafgek81 Posted February 4, 2015 Posted February 4, 2015 Hello people, Here's me again with a maybe stupid question, but I just don't roam the entire forum, because I am only interested in Technic. But what is the length of a stud? Quote
Tommy Styrvoky Posted February 4, 2015 Posted February 4, 2015 (edited) A stud is 8mm wide x 9.6mm tall Edited February 4, 2015 by Tommy Styrvoky Quote
DrJB Posted February 4, 2015 Posted February 4, 2015 P3K ... that is indeed the best answer ever! Quote
Dafgek81 Posted February 4, 2015 Author Posted February 4, 2015 Thaks, so if I am right, a stud is 7,8 mm long, but 2 studs is 15,8 mm. I am still a little confused, even with the picture that D3K posted. Quote
DanFraser Posted February 4, 2015 Posted February 4, 2015 It's because the physical width of a brick of 1 stud is 7.8, but there is a 0.2mm gap between brisk stacked together. 7.8 x 2 = 15.6 but as that gap and its 15.8. Quote
D3K Posted February 4, 2015 Posted February 4, 2015 My understanding of the system (I may be wrong): The base dimension - P - is defined as 8 mm, and that is the distance between two studs/pinholes. The width of a brick (or liftarm, for that matter) is P-0,2 (i.e. 7,8 mm). This is to allow some "breathing space" between pieces, so they don't jam. Quote
Dafgek81 Posted February 5, 2015 Author Posted February 5, 2015 So how does it translate to the precies length of say 10 studs, 20 studs, 30 studs.... Quote
m0dulo Posted February 5, 2015 Posted February 5, 2015 So how does it translate to the precies length of say 10 studs, 20 studs, 30 studs.... number of studs * width of one stud - 0.2mm for example, with p = the width of one stud = 8mm : 10 * p - 0.2mm = 79.8mm 20 * p - 0.2mm = 159.8mm 30 * p - 0.2mm = 239.8mm Quote
