I think I'm not the first with that kind of suspension.
It is not finished, so I'm not publishing nothing else at this moment
  • Replies 143
Got those mid sized street tires. Started to build something.
Tried to fit diffrential
Then i made some angles
Now trying to make differential part littlebit compact, to fit some middle engine.
Don't know, how it will end.
Tryed to build something american, like
Stucked on engine. I wanted to put there normal V8, but it's too big for wheels i chose. Steering wheel is allready somewhere in the middle of the car.
I'm afraid, that moving it more to front, also wont help ...
Jurss, take a look how the engine bay was made on the Lego Technic 8858 set, ok it has the V6 but has suspension and it is all in the middle. Now as Lego created new parts it could be made more efficient ...
AOW, thank You for idea, but it seems hard to implement without studded beams.
I'm looking now on some motorcycles, which have specific solutions.
  • 4 months later...
5 hours ago, Jurss said:
Haven't been here for a while.
Started to work on one idea
That's not good for your tires, did that with 9398 tires and now they will never fit on the regular hubs again.
Oh... didn't thoght about that, because they fit easy
  • 10 months later...
Because of that huge thing out on the shelfs
Will create better pictures at the weekend. Maybe make some changes also, and then make a topic.
Sorry for late reply, but you can try using 9398 Tires on 8448 wheels ow wheel futuristic wheel. If you use wheel futuristic, you can fill 94.8 balloon tire with 42000 tire :wink:
For that project (which is unfinished/disasambled nad waiting for inspiration) that was the needed size, because on the original car (Renault R5 turbo rally) front wheels are pretty narrow, rear little bit bigger diameter, but much wider.
I understand what you mean (as we can see this on following image)
6003181f9892044521374b62db0e4a81--renaul
I have replied you in original topic about tires, because original had same rim diameter at front and rear, just rear tire is "more fat" :wink:
