Well what you need to know is simple- the inside is a mess!
LD uses ball joints and partially attached plates to build those types of structures. Illegal connections do not frighten him at all. There isn't really a good "method" or tutorial because he is more of an artist than an architect!
Wow, that is a fantastic synopsis and characterization of his, and DC's, builds. I was wondering the same thing, but what you said is a great jumping off point.
Experimentation is the best way to develop your building skills. Take small sections and try and recreate them with as many different techniques as possible. Then you can see which look the best, use the fewest parts and are the most structurally sound.
It's worth mentioning that complexity for the sake of complexity is self-defeating - usually the simplest solution is the best.
