Here is a start to my excavator project. Was planning on doing a long reach type of excavator (demolition).
Currently I have the tracks, turn table, and drive motors.
The red pins are to remove the track assembly.
I will post a new picture later with the drive motors and other progress later tonight or in the morning.
Thoughts and ideas are welcome.
It has them on the bottom. I used the small black track cog with the 3x5 triangle to ensure it doesn't slip off.
That is not what I meant,What I meant was that you should make the tracks taller/higher up.
Edited by Alasdair Ryan
Tracks look good weavil :classic:, @fasterthanlight, these type of excavators have a wide footprint for balance when working with a long boom.
Not so much though,
if the tracks are built that far apart they would have to also be wider, it just looks off-scale, thats all.
This is the what I was going for (Alasdair Ryan had it):
Caterpillar 5110B
Might have to add Pneumatics for the attachment and no extended boom, have no extension wire. Functions like the 8043 have but trying to avoid the gearbox.
Got some specs for the Cat 5110B and working on adjusting for scale.
After looking at the specs for the 5110B, it has three track width option: 700mm, 900mm, and 1000mm. 900mm was the best one for a close to even scale, 1:22.5. Using the tracks to make the scale (1:22.5) the track length was fine, but had to narrow it four studs.
I also found this:
But I also found a problem... They get bigger!
Now the real problem. I am going to be short 1 M motor at least or I could just make it a regular excavator with a really big boom.
Edited by weavil
Have you tested the speed of the tracks. Shuldn't they have been more geared down?
I have and i might gear them down a little more.
To keep the joints in position you could use a shocks spring and an 1/2 stop :3
Which joints?
You should swap m motors with l ones. M are weak :tongue:
Ummm....not really! Gear them down and they are fine. Plus I only got one L motor and need to gear down any way to make it go slower.
Two M motors--
How many track pieces are one each side?
That is a tricky question! I have about 180 of two different part numbers and four of a third numer. I mixed them to fit just right.
Those are some huge machines, got to be the biggest machines and the longest boom arms I've ever seen *huh*
Japan has the biggest UHRDS in the world,but telescopic crane booms are still bigger.
They use the blue and orange in the pic above, you can add boom sections. The one I'm doing, the cat 5110B, they modify the mount points for a 90m telescopic boom.
