Does anybody have recommendations for removing back faces from minifigs I haev lots of powerminer heads and do not want both sides. Does the Nail Polish Remover trick from the Lego Movie actually work is was that just an urban legend any help would be great thanks.
Try just a pencil eraser first. Rub for 30 seconds and see.
Acetone / nail varnish remover will work, but may give you a bit of streakyness on the surface.
OK will do thanks
Brasso works best in my experience. It's a fine brash polish and doesn't remove the sheen of the plastic. wet the end of a rag and rub gently for about 30 seconds.
+1.
Brasso does the trick without damage.
I may try that I also tried the eraser method but that takes a while for me!
