Posted March 20, 20159 yr First, let me start by saying that I must give credit where credit is due and I mostly copied this build as best I could from this link https://www.flickr.c...N06/6937426891/ Second, I hope this is ok. I've always wanted to attempt this but I'm not very creative. I also wanted to make this my own by altering some things and not trying to make an exact copy. Level 4 (top): reserved for the 75034 Death Star Troopers set with gun. Level 3: Emperor's chair with window (will be accompanied by Royal Guards from 75034) Level 2: Stormtrooper's area? I'll place some Stormtroopers from set 75078. Level 1 (bottom): instead of the trash compactor, I opted to go with a docking bay that will either have the Falcon 75030 or the Tie Interceptor 75031 microfighter. Side view Side view with bay door open Back view Top view I'd like some suggestions and feedback. Especially on the top. I've had a rough time lining things up in LDD. Thanks. Edited March 20, 20159 yr by TK924
March 20, 20159 yr Good attempt. I would recommend adding a cannon and some play features to make it more striking.
March 20, 20159 yr Author Thanks. Again, I mostly copied from another design. And, I plan on adding this cannon (gun) to the top level.
March 22, 20159 yr One question on LDD. Is there any way to extract a parts list from LDD? Not directly, but there are a few ways to do it. If you use a PC, you can download LDD manager, which will concert your LDD file into a parts list ready for BrickLink. Otherwise, there are some websites that let you do the same thing, namely the BL Moc Shop when your are testing 'Moc-ability' Hope this helps!
March 22, 20159 yr Author Not directly, but there are a few ways to do it. If you use a PC, you can download LDD manager, which will concert your LDD file into a parts list ready for BrickLink. Otherwise, there are some websites that let you do the same thing, namely the BL Moc Shop when your are testing 'Moc-ability' Hope this helps! Thanks! I'll try it out!
March 23, 20159 yr I reckon you could take this to the next level and really make it something special :) good work.
March 23, 20159 yr Author I reckon you could take this to the next level and really make it something special :) Any suggestions on how I could do that? Edited March 23, 20159 yr by TK924
March 23, 20159 yr One question on LDD. Is there any way to extract a parts list from LDD? Not directly, but there are a few ways to do it. If you use a PC, you can download LDD manager, which will concert your LDD file into a parts list ready for BrickLink. Otherwise, there are some websites that let you do the same thing, namely the BL Moc Shop when your are testing 'Moc-ability' Hope this helps! Actually, it's possible to create a parts list directly from LDD : click on File, then on Export BOM, and you'll get a spreadsheet containing your parts list.
March 23, 20159 yr Actually, it's possible to create a parts list directly from LDD : click on File, then on Export BOM, and you'll get a spreadsheet containing your parts list. Oh yeah! I totally forgot about that. I prefer just to have an XML since I can directly upload it to BrickLink.
March 24, 20159 yr Any suggestions on how I could do that? I'd say just expand and experiment man! Try to fit as many little details in and pop in some figures; stormtroopers for level 2 and maybe the emperor himself in level 3? These are just some minor suggestions, its all up to you! :) Edited March 24, 20159 yr by JackoBoy
April 6, 20159 yr You could add in the final dual I and II You get the emperor, his thrown, luke and a few imperial troops. You could also add a picture of a space battle facing the window in the emperor's room to make it look like he can see the battle going down outside
