-Z- Posted March 22, 2015 Posted March 22, 2015 Here is my small scale, about 1:17, rc Nissan Skyline R34. Not many functions, but does have servo steering, rear differential, opening bonnet and boot. I have tried to make it as small as possible whilst accommodating the AA battery box. Hope you like it. Quote
Coola1 Posted March 22, 2015 Posted March 22, 2015 (edited) Awesome little car, welcome to eurobricks! Do you have a video of it driving? What motor did you use for drive? Edited March 22, 2015 by Coola1 Quote
timslegos Posted March 22, 2015 Posted March 22, 2015 Great looking car for such a small scale. Does it have suspension? tim Quote
Jeroen Ottens Posted March 22, 2015 Posted March 22, 2015 A nice little car, well executed A video would be nice and of course a belly shot Quote
Rishab N Posted March 23, 2015 Posted March 23, 2015 Great little car. Did you use an RC motor to power it? Quote
5imon Posted March 23, 2015 Posted March 23, 2015 Hi -Z-, welcome to Eurobricks and good model you present here, nice and compact. The only suggestion I have is to try and make the rear part (everything that's behind the rear wheel) less box-shaped, maybe by adding some angles or curves, like you have on the side of the car. Quote
kieran Posted March 25, 2015 Posted March 25, 2015 I like, defiantly can see the real cars lines even in this scale Quote
jorgeopesi Posted March 25, 2015 Posted March 25, 2015 Welldone, my first technic car was a skyline long time ago... Quote
-Z- Posted March 26, 2015 Author Posted March 26, 2015 (edited) Thanks for the comments and the welcome to Eurobricks. Unfortunately the car does not have suspension, as I wanted to keep it simple and I couldn't see a way of fitting it in at this size anyway. I hope to progress to suspension, gearbox, etc in future MOCs. It is driven by one L motor sitting behind (in parallel to the rear axle) - this proved a bit of a headache to fit securely, as it kept trying to twist away from the differential gear when powered. It is a bit slow, but I suppose that is to be expected. I will try to find time to post a shot of the underside when I get time. Edited March 26, 2015 by -Z- Quote
__________________________ Posted March 27, 2015 Posted March 27, 2015 I like it a lot! I'll help make an LXF of this, if other people are involved, so it doesn't take too long. Quote
rm8 Posted March 29, 2015 Posted March 29, 2015 (edited) You should use more Lego system parts, I mean bricks, plates, hinges, slopes...To make it look closer to original, especially in such scale. But even without that parts, your model is lookng good and close to Sky:) Edited March 29, 2015 by rm8 Quote
