April 3, 20159 yr Author I'm at a roadblock, which always happens when it comes to looks. Should I make the body in Technic pieces or sloped/tile pieces? The doors alone are 12 studs long x 9 studs high, not including the windows. If anyone has ideas, don't be afraid to share! Thank you. Glenn
April 3, 20159 yr Technic pieces all the way. Start a basic body and then once you get the shape, you can add little improvements as you go.
April 4, 20159 yr Go with slopes and tiles. It worked well on my ATS, and it allows for some better shaping than simple technic beams/liftarms.
April 5, 20159 yr Author Progress report. Wheelbase shortened 4 studs. Vehicle width narrowed 2 studs. Only has 4wd. Side is done. For now.
April 5, 20159 yr Good thing your making it in black, I doubt any other colour would look ok with those stacked beams. Keep up the good work, this is gonna really look badass when its done!
April 8, 20159 yr Author The taillights look a bit too small, but other than that it looks nice! I agree with you. I changed the size to 1x2x3. Still don't like it but I'll wait til the truck is nearly done before changing it again. Also raised the fender openings 1 stud. Looks much better now. Bed of truck is done. Working on the left side doors and front fender, then will tackle the roof and hood. More pics soon!
April 9, 20159 yr Author I made the front bumper with those parts. I made a version of the grill, but could not find a way to connect the beams for a clean look across the front.
April 13, 20159 yr Author Well, it's 95% done. Still needs back seat, left rear tail light, and a few odds and ends. As you can see in the last post, I have both XL motors connected. The middle differential splits the power to the front and back. There is a 3:1 reduction before it gets to the wheels. If I just used an xl motor to run the front axle, and one to drive the rear axle, would that eliminate the need for the power reduction? This truck is heavy, but super slow. Thanks for the comments! Glenn
April 13, 20159 yr Glenn, I admire and little bit envy You, because You have that unique skill to create beautiful design I want and I will be as good as You some day Nicely shaped design, I like it a lot
April 13, 20159 yr Author Thank you for the praise! I'm going to put a cover on the bed to hide the battery box, I just haven't decided to make a Lego one or just use black construction paper.
April 14, 20159 yr That thing is huge and looks great. What really made me realize how heavy it might be was the interior shot where I saw the floor boards. I can only imagine how much it actually weighs. v/r Andrew
April 14, 20159 yr Nice to see it almost done! If you connected each motor to an axle, I think it might run ok without any reduction other than the 20t to differential. Im not sure though, dont know how much that beast weighs.
April 14, 20159 yr Wow, this turned out great! However, I don't like the corners of the bonnet/hood. How about using long smooth panels (ID 64681) for the edges instead?
April 14, 20159 yr Wow that is a masterpiece! My only concern is that the front wheels might rub against the fenders while steering.
April 14, 20159 yr This looks really good and impressive! Like sm1995 suggested, I would add some curvature to the bonnet, if possible. Also, maybe fill up the engine bay a bit (although I guess it is already really heavy). As for the battery box: if you can move it to behind the cab, you can hide it in a tool box, like the one below.
April 14, 20159 yr Well, it's 95% done. Still needs back seat, left rear tail light, and a few odds and ends. As you can see in the last post, I have both XL motors connected. The middle differential splits the power to the front and back. There is a 3:1 reduction before it gets to the wheels. If I just used an xl motor to run the front axle, and one to drive the rear axle, would that eliminate the need for the power reduction? This truck is heavy, but super slow. If you don't couple the XL motors, each axle gets half the torque, so I wouldn't do that. Edited April 15, 20159 yr by Blakbird : Please don't quote a bunch of images for no reason.
April 15, 20159 yr Author Wow, this turned out great! However, I don't like the corners of the bonnet/hood. How about using long smooth panels (ID 64681) for the edges instead? I was going to use panels like on 9398 crawler, but could not get the front fender to look right, so removed it. Wow that is a masterpiece! My only concern is that the front wheels might rub against the fenders while steering. The front tires haven't rubbed yet, but the ball with axle connector keeps popping off the steering side. This looks really good and impressive! Like sm1995 suggested, I would add some curvature to the bonnet, if possible. Also, maybe fill up the engine bay a bit (although I guess it is already really heavy). As for the battery box: if you can move it to behind the cab, you can hide it in a tool box, like the one below. I like the idea for the toolbox. Thank you. I'll think about what to add to the engine bay, but as you said this model is relatively heavy. Nice to see it almost done! If you connected each motor to an axle, I think it might run ok without any reduction other than the 20t to differential. Im not sure though, dont know how much that beast weighs. If you don't couple the XL motors, each axle gets half the torque, so I wouldn't do that. I separated the motors and only have the reduction at the differential. Works great! Thank you everyone for you're praises and ideas! Glenn
