Yes, conversion to .obj with your files works but as you have pointed out there are no studs - initially I thought you are talking just about the top parts with logo-on-stud yet now as I actually test it I see you really meant whole studs, ah, pity. :sceptic:
Anyway, maybe there still is some way how to add them correctly to each of your brick (at least manually but that would be terrific work to do), so yea it'd be still great if you could make all those "normal" bricks once too. :classic:
Edited by bublible
  • Replies 99
Posted Images
Maybe it's better that you first find a way to add the studs, and then I will spend time creating the parts.
You can try to create your own stud in obj format and add it then to my parts converted to obj.
Yes, creating a stud is absolutely not a problem: I just load let's say 1x1 LDRAW brick into Blender and in Edit Mode I delete all except the stud BUT the main problem is how do I find exact position(s) for the respective stud(s) on the brick(s)? That would really be challenge... :sceptic:
Edited by bublible
Update: 2015/08/11
Download link on first page.
973p61: Minifig Torso with Gold Ice Planet Pattern
973p62: Minifig Torso with Silver Ice Planet Pattern
991: Electric RC Race Buggy Motor - Axle Bush
2440p67: Hinge 6 x 3 Radar/Blade/Spoiler/Panel with Ice Planet Pattern
2713: Technic Ski
3039pc8: Slope Brick 45 2 x 2 with Ice Planet Controls Pattern
3068bp61: Tile 2 x 2 with Ice Planet Logo Pattern
3069bp61: Tile 1 x 2 with Ice Planet Control Panel Pattern
3298p61: Slope Brick 33 3 x 2 with Ice Planet Logo Pattern
3626bp61: Minifig Head with Ice Planet Moustache and Eyebrows Pattern
3626bp62: Minifig Head with Ice Planet Messy White Hair Pattern
3626bp65: Minifig Head with Ice Planet Female Red Hair Pattern
4218b: Roller Door Normal
4219b: Roller Door with Handle
4474p61: Windscreen 6 x 4 x 2 Canopy with Ice Planet Logo Pattern
6119: Minifig Helmet Visor Ice Planet
93598: Windscreen 2 x 3 x 2 on 2 x 4 Base
93598pk0: Windscreen 2 x 3 x 2 with 2 x 4 Base with Green Eyes on White Background Pattern
98283: Brick 1 x 2 with Embossed Bricks
99301: Slope Brick 33 3 x 3 Double Concave
168275a: Sticker 2.7 x 3.7 with Spyrius Machinery
168295a: Sticker 5.4 x 7.9 with Holographic Stripes and Red Triangles
u1125: Hinge Plate 1 x 2 with 1 Large Finger
u1126: Hinge Plate 1 x 2 with 2 Fingers at Outer Edges
ls20 - LSynth Technic Pneumatic Hose - End Piece
ls21 - LSynth Technic Pneumatic Hose - Cross Section
ls40 - LSynth Technic Flexible Axle - End Piece
ls41 - LSynth Technic Flexible Axle - Cross Section
ls50 - LSynth Technic Flex-System Hose - End Piece
ls51 - LSynth Technic Flex-System Hose - Cross Section
ls60 - LSynth Short Straight String Segment
  • 2 months later...
Awesome job!!!
Could I make a request for a part that doesn't seem to exist (if there's to be any updates of your library, that is)?
It is part "4867 Tail Plane" (see link http://brickset.com/parts/4188568)
I can't seem to find it anywhere, so chances are that it doesn't exist as an include file for the LGEO library yet.
Edited by junaz
Thanks!
I can create it.
I can't tell you when, I need to find time to release a new update (I have 65 new parts to release).
Stay tuned...
Update: 2015/11/12
973p2d - Minifig Torso with Windsurfboard Pattern
973p64 - Minifig Torso with Spyrius Pattern
2362b - Panel 1 x 2 x 3 with Hollow Studs
2446p51 - Minifig Helmet Modern with Black, Blue and Silver Unitron Pattern
2739a - Technic Steering Link 6L Type 1
2852 - Technic Engine Connecting Rod
3068bp0d - Tile 2 x 2 with Black Dot and White "E" on Red Disc Pattern
3068bpc1 - Tile 2 x 2 with Yellow Horizontal Stripes and "SOLAR CHARGE LEVEL" Pattern
3626bp03 - Minifig Head with Standard Grin Pattern
3626bp68 - Minifig Head with Silver Sunglasses and Red Headset Pattern
3678 - Slope Brick 65 2 x 2 x 2 without Centre Tube
3678a - Slope Brick 65 2 x 2 x 2 without Centre Tube
3678b - Slope Brick 65 2 x 2 x 2 with Centre Tube
3857 - Baseplate 16 x 32 with Square Corners
4162p0z - Tile 1 x 8 with "Louvre" Pattern
4507 - Hinge Plate 1 x 6 with 2 and 3 Fingers On Sides
4515 - Slope Brick 10 6 x 8
4864ap04 - Panel 1 x 2 x 2 with Palm Tree Pattern
6041 - Propellor 3 Blades 3.5 Diameter
6075 - Minifig Surf Board 2 x 10
6083 - Panel 3 x 8 x 7 Rock Triangular
6255 - Plant 1 x 1 x 0.667 Round with 3 Large Leaves
14719 - Tile 2 x 2 Corner
15712 - Tile 1 x 1 with Clip (Thick C-Clip)
30162 - Minifig Tool Binoculars Town
30375 - Minifig Mechanical Torso
32005 - Technic Steering Link 6L Type 2
32187 - Technic Transmission Driving Ring Extension
32250 - Technic Beam 3 x 5 x 0.5 Liftarm Bent 90 Quarter Ellipse
32529 - Technic Pin Joiner Plate 1 x 2 x 1 & 1/2
41763 - Slope Brick Curved 6 x 1 Inverted
41764 - Wedge 2 x 6 Double Inverted Right
41765 - Wedge 2 x 6 Double Inverted Left
42023 - Slope Brick Curved 6 x 1 Inverted
45590 - Technic Axle Joiner Double Flexible
47455 - Technic Brick 2 x 2 with Hole, Half Rotation Joint Ball Vert
47457 - Slope Brick Curved 2 x 2 x 2/3 Triple with Two Top Studs
I've authored the part. It will be part of the next update (in a few days)
Update: 2015/11/28
4289 - Boat Mast 2 x 2
4867 - Tail Plane
47755 - Wedge 4 x 3 Curved with 2 x 2 Cutout
48171 - Technic Brick 2 x 2 with Hole, Half Rotation Joint Ball Vert
48729 - Bar 1.5L with Clip
57518 - Technic Chain Tread 38
57520 - Technic Sprocket Wheel 25.4
59230 - Minifig Mechanical Arm Straight
60470 - Plate 1 x 2 with Clips Horizontal (Open U-Clips)
60470a - Plate 1 x 2 with Clips Horizontal (Open U-Clips)
60470b - Plate 1 x 2 with Clips Horizontal (Thick C-Clips)
60592 - Window 1 x 2 x 2 without Sill
60601 - Glass for Window 1 x 2 x 2 without Sill
62712 - Brick 2 x 2 with Ball Socket and Axlehole
64276 - Technic Beam 2 Liftarm with Ball Joint
87079 - Tile 2 x 4 with Groove
87079p08 - Tile 2 x 4 with Black "WALL" Pattern
90195 - Panel 1 x 2 x 2 Hollow Stud with Arched Windows Opening
92013 - Brick 2 x 2 with Ball Socket and Axlehole
98282 - Car Mudguard 4 x 2.5 x 1
98286 - Hinge Plate 2 x 4.5 Top with Technic Pin Hole
99021 - Technic Pneumatic Hose Connector with Bush
u66 - Sheet Plastic 6 x 12 Triangular
u66c01 - Sheet Plastic 6 x 12 Triangular (Formed Shape 1)
u66c01 - Sheet Plastic 6 x 12 Triangular (Formed Shape 2)
u66p01 - Sheet Plastic 6 x 12 Triangular with Blue and Red Triangles and Blue Lines Pattern
u66p01c01 - Sheet Plastic 6 x 12 Triangular with Blue and Red Triangles and Blue Lines Pattern (Formed Shape 1)
u66p01c02 - Sheet Plastic 6 x 12 Triangular with Blue and Red Triangles and Blue Lines Pattern (Formed Shape 2)
u151 - Rubber Belt Square 15 / 1.2
  • 2 months later...
Update: 2016/02/28
286: Minifig Suitcase Joiner Tab
336: Technic Pneumatic Cylinder 2 x 2 Piston Rod 5.5L
337: Technic Pneumatic Cylinder 2 x 2 Piston Rod 4L
757: Hose Flexible 12L Top 1 x 1 x 2/3 with Stud
2435: Plant Tree Pyramidal 3 x 3 x 4
2437: Windscreen 3 x 4 x 1 & 1/3
2489: Barrel 2 x 2 x 1.667
3003p0a: Tile 1 x 8 with White Winged Lion Pattern
3081a: Window 1 x 2 x 2 Classic with Solid Studs
3081ac01: Window 1 x 2 x 2 Classic with Solid Studs (Complete)
3081b: Window 1 x 2 x 2 Classic with Long Sill
3081bc01: Window 1 x 2 x 2 Classic with Long Sill (Complete)
3081c: Window 1 x 2 x 2 Classic with Short Sill
3081cc01: Window 1 x 2 x 2 Classic with Short Sill (Complete)
3082: Window 1 x 2 x 2 Classic Glass
3587: Tail 2 x 5 x 3.667 Plane
3626bpw1: Minifig Head with Thick Moustache, Angry Eyes, Wavy Mouth, Long Hair and Stubble Pattern
3626c: Minifig Head with Closed Hollow Stud
3861: Door 1 x 4 x 5 with Panes
3899: Minifig Cup
4162p10: Tile 1 x 8 with "Venice" Pattern
4449: Minifig Suitcase
4449c01: Minifig Suitcase Open
4466: Exhaust Pipe Twin Inlet 11L Left
4467: Exhaust Pipe Twin Inlet 11L Right
4528: Minifig Frypan
4617: Propellor 3 Blade 5.5 Diameter with Technic Peghole
4617a: Propellor 3 Blade 5.5 Diameter with Freestyle Pinhole
4617b: Propellor 3 Blade 5.5 Diameter with Technic Peghole
14417: Plate 1 x 2 with Ball Joint-8
14769p06: Tile 2 x 2 Round with Round Underside Stud with Black and Dark Bluish Grey Grid Pattern
22961: Technic Axle with Perpandicular Pin Hole
32474: Technic Ball Joint with Axlehole Blind
42610: Wheel Rim 8 x 11.2 with Centre Groove
44674: Car Mudguard 3 x 4 Overhanging
49668: Plate 1 x 1 with Tooth In-Line
50943: Car Engine 2 x 2 with Air Scoop
56890: Tyre 12/57 x 10 Balloon
62361: Car Mudguard 6 x 1.5 x 1 with Arch
88393: Brick 1 x 2 x 5 with Groove
90398: Minifig Statuette
92690: Bar 1L with Top Stud and Two Side Studs
821472hc01: Sticker 1.0 x 2.8 with Black and Light Grey Grid on Transparent Background (Right) (Formed)
821472ic01: Sticker 1.0 x 2.8 with Black and Light Grey Grid on Transparent Background (Left) (Formed)
You may want to put the lg_xxxx.inc files in your usual LGEO directory and the xxxx.inc files in another folder
Somehow I don't understand this a bit vague statement (absolute exactness would be rather expected so one will not do anything wrong): what directory/ies?
There are actually 2 folders inside LGEO directory:
  • "lg" (logic tells me you probably wanted to write "put lg_xxxx.inc files into lg folder inside LGEO directory", but as nothing is as it may seem it'd be really nice having it written like that)
  • "ar" (having no clue what is this one about)
So where should one put those "xxxx.inc" (STL) files - should we create new folder (cos that is as I understood it at first), or use some other already existing folder ("ar")? :wacko:
See, many of us can be really not aware of LDRAW exact structure so it'd be much more helpful if this part (sentence) was written/described in more detail than that...
I found your brick models looking really extra HQ compared to anything else I saw - mainly when it comes to rounded parts, like dishes etc., great :blush::thumbup: - I would really like to use them as I am making new script that would actually replace all LowRes "curved" meshes/bricks of original LDD in BlueRender (SunFlow script) with your HQ ones (being almost there! First idea was completely replace LDD bricks with your ones but then I realized two other things which prevented me from doing it: 1. you did not make all bricks yet, 2. there is not any known option how to translate LDD flexes to LDRAW ones, therefore I decided to go with replacing only those rounded parts) - but this uncertainity about placing your files make things really hard to "get going", if you understand me. :sceptic:
Waiting for your soon answer, Darats! :wink:
Edited by bublible
ar folder stands for Anton Raves library which was an old alternative to povray. Just ignore it.
Then you can do whatever you want with the folder as long as you declare them in Povray.
What I suggest it to copy all my lg_xxxx.inc file into your lg folder (where the other lg_xxxx.inc files are), and to copy the xxxx.inc files into another folder (eg "STL Parts") and then declare it in PovRay.
To declare a folder into PovRay:
Edit the "povray.ini" file to add the folders you want at the very end of the file.
This is what I have a the end of my povray.ini folder:
Library_Path="D:\Lego"
Library_Path="D:\Lego\lgeo"
Library_Path="D:\Lego\lgeo\lg"
Library_Path="D:\Lego\lgeo\STL Parts"
If you still get trouble, feel free to ask.
Then:
I'm reworking every part one by one by hand, so I can get the quality as high as I want but it's a very long job, I'm only focussing on parts that are not in the current LGEO library or that looks bad in that one. You can make requests but I cannot give any delay.
As my library is currently a beta version and it aiming at being part of the official ldraw AIOI, I don't want to spend too much time explaining things. When it will be ready, it will be integrated to the ldraw package and no more manipulations will be needed.
One more thing: you seem to want to make a script for bluerender. So, you shouldn't need any of the povray stuff but only the library files. So, I don't understand why this folder issue gives you a problem.
You will also see that my parts are made for povray, so you might get trouble when there will be patterns or studs in the parts because of the way I'm creating them using csg operations. You may have to learn a bit the povray code format, but it's quite easy and straight forward. If you make scripts, you should be able to deal with it.
Darats, your parts are really beautiful, I've already used them in my renders. Thanks a lot!
I have a small addition, if you would like to add this part to your library: 3069bp01: Tile 1 x 2 with Letter Pattern
I did not find it for lgeo, so I modified one of your patterned parts.
Part link
Rendered image of part
I've made the part. It will be in next update, maybe this month.
Thanks. I jut found out something weird: the lgeo parts 3298p98, 3298p53 and similar look like this:
In my lg_3298 it says:
#declare lg_angle1=65.32484819;
#declare lg_angle2=90-lg_angle1;
I had to modify the rotation angle in your patterned parts to lg_angle2=24.67 (and a little translation) for the pattern to fix them.
Which would suggest that you use a different slope angle for the 3298 brick: 26.56505 (seen in your parts). Might there be any part update I have missed or you did not include (for lg_3298)?
Mmh, I need to check my files but maybe yes. You or I should have a different slope part. I know Owen did some fixes on slope parts, maybe I get his update, or you. I'll let you know. Thanks for pointing it out.
You were right, I missed the update from Owen. For others: you can download it here:
https://dl.dropbox.com/u/59864198/LDraw/Other%20Files/LGEO-Update.zip
In his part the angle is changed to what you use.
  • 4 months later...
https://dl.dropbox.c...LGEO-Update.zip
This library is not really compatible with Owen's. Darats' and Owen's "lg_defs.inc" are not in sync, and there's a good chance your model will not render in POV-Ray. Note that the AIOI includes Owen's changes by default, so we're SOL for the time being.
As I said in the forst post:
While waiting for a better solution, you will need to add :
#declare L3LDrawToLgeo = transform { matrix <0,-LG_BRICK_WIDTH/20,0, 0,0,-LG_BRICK_HEIGHT/24, -LG_BRICK_WIDTH/20,0,0, 0,0,4*LG_BRICK_HEIGHT/24> }
#declare L3LgeoToLDraw = transform { matrix <0,0,-20/LG_BRICK_WIDTH, -20/LG_BRICK_WIDTH,0,0, 0,-24/LG_BRICK_HEIGHT,0, 0,0,0> }
at the end of your lg_defs.inc file (just above the very last "}") or use my own lg_defs.inc provided in the package (but it might conflict with Owen's one on some parts).
As long as you don't overwrite Owen lg_defs.inc and only add those statements, you should be fine.
You might want to explain that in the first post. To me it seemed you were recommending people *should* overwrite Owen's file with yours. But this will likely cause weird errors without obvious (to the end user) causes.
