Posted April 29, 20159 yr Presenting another Danish shunter...DSB Litra MH 322 History: The Danish State Railways (DSB) diesel shunter Litra MH were built in great numbers by Frichs in Denmark from the year 1960 to 1965. In all 120 shunters were built to replace the steam shunters still being used. The shunters were repainted in the 80's to black and red from the original dark green. The last shunter was decommissioned in 2001. ©Hans Stückler My model: Scale: 1:54ish Lenght: 26 studs Width: 7 studs Bricks: 455 Motortype: PF Model built: 2012-14 The stickers are homemade with self-adhesive labels printed by a copy shop and then cut by myself to fit. The upper part is primarily constructed with plates and tiles, in general only a few standard bricks are used in the construction. The model is run by PF and requires one 9v battery connected by custom adapter to the Power Functions M-Motor. Pull and speed are acceptable. The shunter pulling a white Litra Gs wagon. Edited June 7, 20222 yr by dtomsen Per the Site Guidelines, please keep embedded images to a maximum of 1,024 x 768 pixels
April 29, 20159 yr Wow, really great job there! Nice to see some danish trains :-) PS: On a web-technical note, the lego-pictures in PNG are 3x the file size of the first JPG.. and even though I'm currently in a high-tech hotel in Dubai, it took 10 minutes to get the PNG's and 1 min for the JPG.. Slow server at 'staticflicr.com' contra blogspot or file sizes ??
April 29, 20159 yr Nice work. Does the middle wheel float above the tracks? I just wonder cos it is sort of flanged on both sides so if it touched it could cause problems.
April 29, 20159 yr Author Nice work. Does the middle wheel float above the tracks? I just wonder cos it is sort of flanged on both sides so if it touched it could cause problems. Yep, the middle wheel does indeed float above the tracks and is this part which actually works just fine from the side as blind drivers for the standard sized train wheels Edited April 29, 20159 yr by dtomsen
April 30, 20159 yr That is a lovely shunter and the use of the 9V is very innovative. As far as the speed being in the "acceptable" category, I am always reminded by Cale that trains are not supposed to be fast.
April 30, 20159 yr That is a great little model. The amount of detail that you packed in is very impressive.
April 30, 20159 yr Very nice model, dtomsen. Very nice to see some homely trains I do remember Litra MH from my childhood, as I lived in a town where DSB used some shunters. They were green at the time, and the bigger ones, Litra MT, I remember as being red and black.
May 1, 20159 yr That's a great little model. Looks like the V60's Danish cousin. I like how you've managed to make it modular to make is easy to change the battery. Have you tried running it? I built a KoF that's using the same 9V battery but it doesn't last very long...
May 2, 20159 yr Great model perfect design!!! How long does that 9v battery last on average I thought just 1 9v battery would drain itself pretty fast? Good Job!!! -RailCo
May 2, 20159 yr Author Have you tried running it? I built a KoF that's using the same 9V battery but it doesn't last very long... Yeah, the battery doesn't last very long, about 30 min on a good day...can't have it all :-) Edited May 2, 20159 yr by dtomsen
May 3, 20159 yr Author how do you manage to fix the batterie? The rear of the upper part is the exact same width (and length) inside as the battery.
May 4, 20159 yr Author it is a lego part? Half of it is You can read more about the custom adapter here Edited May 4, 20159 yr by dtomsen
August 22, 20186 yr Author ---Updated 22.08.2018--- A few pictures of the model in the original dark green livery The stickers are this time wet transfer decals and cannibalised original LEGO stickers. Pulling a litra HK wagon from the same era: Edited June 7, 20222 yr by dtomsen
